Cera Skrevet 21. november 2004 Del Skrevet 21. november 2004 Er vel litt flaut dette spørsmålet, men jeg kommer ikke særlig langt i Halo 1. Er helt i begynnelsen, dreper et par monstre og går over broen, opp bakken og setter meg inn i en bil (som er forferdelig og kjøre), prøver og kjøre inn i den bygningen, men så kommer jeg ikke videre? Skal jeg inn i bygget? Hvor skal jeg kjøre? Hva skal jeg gjøre? Lenke til kommentar
SGE7000 Skrevet 21. november 2004 Del Skrevet 21. november 2004 det her skal vel være under spillforum, eller???? kan ikke hjelpe deg, har runna halo 1, men husker ikke så godt at jeg vet hva du skal gjøre, nei Lenke til kommentar
mago Skrevet 21. november 2004 Del Skrevet 21. november 2004 (endret) her kan du laste ned veiledning http://www.gamefaqs.com/computer/doswin/game/13511.html tror du mener halo levelet (2) du må hoppe over en avsats med jeepen Go down the rocky slope and turn to your right into a small cave. If you can't find it immediately, Cortana will give you a Nav point to follow. Anyway, as you get close, Cortana will tell you that the cave is not a natural formation. Continue through the so called cave turning and shifting around until you reach a jump in the path. Gain as much speed as possible by falling down the ramp and heading back. Use the slope as a ramp to make it. Continue through until you reach a big room infested by Covenant. The easiest way to kill them(if you have a gunner)is to run over them with your gunner taking out as many of them as they can. After the initial Covenant are taken care of, head to the right of the room by the entrance and you'll find a small slope leading up. Be careful, at the top there is a Red Elite and he's intent on getting you. Don't go up to far. When you can see the end, throw a grenade to attract him and then use an overcharged Plasma Pistol to bring down his shields. Then, run up to him and melee him a few times to bring him down. Continue up and left and you should reach the bridge controls. Watch the bridge appear and head back to your Warthog. Now that you have the bridge activated, you can continue through and to the other side. The cave will swerve a lot and Cortana will tell you a few things. After a while, you will reach an opening in the cave. Finally! Endret 21. november 2004 av mago Lenke til kommentar
Sir_cruz Skrevet 21. november 2004 Del Skrevet 21. november 2004 opp i en sprekk i fjellet Lenke til kommentar
StaBBer Skrevet 21. november 2004 Del Skrevet 21. november 2004 (endret) Trodde ikke det var mulig å sitte fast i Halo jeg, hehe Det er jo for det meste å rett fram, er jo i bunnn og grunn en "krigssimulator". Ikke så mye gåteløsning osv i den gården nei! Endret 21. november 2004 av StaBBer Lenke til kommentar
Cera Skrevet 22. november 2004 Forfatter Del Skrevet 22. november 2004 Jeg, det var litt flaut og sitte fast, men "du må hoppe over en avsats med jeepen hjalp meg, gikk rimelig fort når jeg visste hva jeg skulle gjøre... Lenke til kommentar
Arsenal_RULES Skrevet 22. november 2004 Del Skrevet 22. november 2004 Ja, nå har jeg sett det å *LOL* (satt en del fast selv, når eg tenker meg om!) Lenke til kommentar
HMaster Skrevet 22. november 2004 Del Skrevet 22. november 2004 Warthogen er jo deilig å kjøre da. Perfekt til å meie ned aliens med. Lenke til kommentar
Zeph Skrevet 22. november 2004 Del Skrevet 22. november 2004 Styringen er feilande etter mitt hjerte. Lenke til kommentar
Cera Skrevet 23. november 2004 Forfatter Del Skrevet 23. november 2004 Styringen var i begynnelsen helt FORFERDELIG, men etterhvert når jeg forstod hvordan det skulle gjøres så gikk de jo greit. Hadde riktignok sikkert vært mer fornuftig og hatt "vanlig" styring... Lenke til kommentar
Deathie Skrevet 23. november 2004 Del Skrevet 23. november 2004 Trodde ikke det var mulig å sitte fast i Halo jeg, hehe Det er jo for det meste å rett fram, er jo i bunnn og grunn en "krigssimulator". Ikke så mye gåteløsning osv i den gården nei! Bane 2, "Halo"(navnet på banen), kan faktisk være begynnelsen. Man skal finne 3 forskjellige steder hvor man skal hjelpe marinesene med å bekjempe the Covenant. Disse 3 stedene kan faktisk være ganske vanskelige å finne i begynnelsen. Men etter å ha rundet det ca 20 ganger til sammen, på alle de forskjellige vanskelighetsgradene går det ganske fint Leiter du litt, så finner du det nok. Lenke til kommentar
Mato Skrevet 25. november 2004 Del Skrevet 25. november 2004 Warthogen er jo deilig å kjøre da. Perfekt til å meie ned aliens med. den bilen suger jo da . styringe er , ubrukilig , jeg klarer ikke slutten pga den , men det er jo bare et filmklipp som mangler så jeg tar det ikke så tungt , nå er det heller det og komme vidre i halo2 Lenke til kommentar
StaBBer Skrevet 25. november 2004 Del Skrevet 25. november 2004 Warthogen er jo deilig å kjøre da. Perfekt til å meie ned aliens med. den bilen suger jo da . styringe er , ubrukilig , jeg klarer ikke slutten pga den , men det er jo bare et filmklipp som mangler så jeg tar det ikke så tungt , nå er det heller det og komme vidre i halo2 Hver sin mening egentlig. Personlig digget jeg warthog'en, og den gjorde siste banen til en av de beste i hele spillet Lenke til kommentar
Mato Skrevet 25. november 2004 Del Skrevet 25. november 2004 Warthogen er jo deilig å kjøre da. Perfekt til å meie ned aliens med. den bilen suger jo da . styringe er , ubrukilig , jeg klarer ikke slutten pga den , men det er jo bare et filmklipp som mangler så jeg tar det ikke så tungt , nå er det heller det og komme vidre i halo2 Hver sin mening egentlig. Personlig digget jeg warthog'en, og den gjorde siste banen til en av de beste i hele spillet grunnen til at jeg ikke liker den er sikkert det at det ikke er noe utpreget bruk av den gjennom spillet og dermed blir det ikke til at man lærer seg og bruke den , begynner og bli vant til den i 2`ern nå Lenke til kommentar
