Sletting av filer?
garfunk
hei garfunk,
du kan trygt sletter disse filer.
Home | Forum | Products | Services | Tricks | Games | Contact November 20, 2004
What Can You Safely Delete?
You can safely delete these files: (BTW: * means anything)
Deletable File Extension Location Comments
*.* C:\Windows\temp You can remove any file in this folder that is more than one day old.
*.--- C:\ Backup Files Created By Windows
*.1st C:\ Delete these files only if you have backed up your registry
~$*.doc Throughout your drive Temporary Word files created whenever a document is open. Safe to delete only if the original document is closed (these 'orphans' are often left behind during a crash)
*.bak Throughout your drive Backup files from various applications
*.cab Throughout your drive Installation Files
*.chk C:\ Files created by Scandisk and its ancestor, ChkDsk
*.dos C:\ Safe to delete only if you don't dual-boot to DOS.
*.fts Throughout your drive Windows will recreate these files as needed
*.gid Throughout your drive Windows will recreate these files as needed
*.log C:\ or C:\Windows Log files created by certain programs tracking certain jobs; if they're more than a few days old, they're not being used anymore.
*.old C:\ Old versions of files that have been replaced by newer versions
*.prv C:\ Log files created by past Windows boots
*.shs Desktop or Throughout your drive Scrap objects; temporary files created in OLE-supporting applications.
*.tmp Throughout your drive Temporary Files from various applications.
*.wbk C:\My Documents and its subfolders Word Backup Files
© 2000 - 2003 Shoeb Omar.
:thumbup: gaggen
Endret av gaggen
