tigergutten Skrevet 19. november 2004 Del Skrevet 19. november 2004 Jeg har problemer med å koble til mitt digitalkamera i XP (noe som suger vilt), og fant dette på nettet. Men jeg finner ikke ut hvor dette er i "kontroll panel", noen som kan forklare? Windows XP and My Cam 2300 Problems Its not working in windows xp ( Minolta Customer Support Said ) !!!!! But Finnaly I found the way , just follow this 1. Open the control panel from the Start menu 2. Select "Service and Maintanence", if you're in the cathegory view, then "Maintenance; or directly "Maintenance", if you're in the classic view. 3. Select "Services" 4. Scroll down the list, until you find a service, named "Windows Image Acquisition (WIA)". 5. Click with the right mouse button on the service name and choose "properties" 6. Choose "Deactivated" in the start type dropdown list 7. Click on "Stop" under service status 8. Click on "Ok" neither to say that before it you should install Minolta Software in windows Xp , its a bit hard but you can do it after some try. Problemet mitt er at jeg ikke finner noe "maintanence" i kontroll panel Lenke til kommentar
Zethyr Skrevet 19. november 2004 Del Skrevet 19. november 2004 Jeg har problemer med å koble til mitt digitalkamera i XP (noe som suger vilt), og fant dette på nettet. Men jeg finner ikke ut hvor dette er i "kontroll panel", noen som kan forklare? Windows XP and My Cam 2300 Problems Its not working in windows xp ( Minolta Customer Support Said ) !!!!! But Finnaly I found the way , just follow this 1. Open the control panel from the Start menu 2. Select "Service and Maintanence", if you're in the cathegory view, then "Maintenance; or directly "Maintenance", if you're in the classic view. 3. Select "Services" 4. Scroll down the list, until you find a service, named "Windows Image Acquisition (WIA)". 5. Click with the right mouse button on the service name and choose "properties" 6. Choose "Deactivated" in the start type dropdown list 7. Click on "Stop" under service status 8. Click on "Ok" neither to say that before it you should install Minolta Software in windows Xp , its a bit hard but you can do it after some try. Problemet mitt er at jeg ikke finner noe "maintanence" i kontroll panel start -> kjør -> 'services.msc' Følg fra punkt 4. Føler meg ganske sikker, men ikke 100%; gidder ikke å sjekke. Lenke til kommentar
tigergutten Skrevet 19. november 2004 Forfatter Del Skrevet 19. november 2004 Thanx mate, det gjorde det litt lettere ja Lenke til kommentar
