shit89 Skrevet 18. november 2004 Del Skrevet 18. november 2004 Hver eneste gang (med unntak av de gangene jeg bruker imation cder) blir cdene mine feilbrent. Jeg har en plextor 40/12/40a. Jeg har oppdatert firmwaren til den nyeste (1.06)uten videre hell. Her er en logg fra en brenning: Kristian 1502-4340-1150-0511-6200-0998* Windows XP 5.1 WinAspi: - ahead WinASPI: File 'D:\Programfiler\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.44, size=172099 bytes, created 10.02.2002 13:08:31 Nero Version: 5.5.8.1 Recorder: <PLEXTOR CD-R PX-W4012A> Version: 1.06 - HA 0 TA 1 - 5.5.8.1 Adapter driver: <nvatabus> HA 0 Drive buffer : 4096kB Bus Type : default (0) -> ATAPI CD-ROM: <_NEC DV-5500A> Version: 1.07 - HA 0 TA 0 - 5.5.8.1 Adapter driver: <nvatabus> HA 0 Bus Type : default (0) -> ATAPI === Scsi-Device-Map === CdRomPeripheral : _NEC DV-5500A nvatabus Port 0 ID 0 DMA: ? CdRomPeripheral : PLEXTOR CD-R PX-W4012A nvatabus Port 0 ID 1 DMA: ? DiskPeripheral : SAMSUNG SP1614C nvatabus Port 1 ID 0 DMA: ? CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 3 ID 0 DMA: ? ======================= AutoRun : 0 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 1023MB (1048048kB) Free physical memory: 719MB (736888kB) Memory in use : 29 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Wizard: Off CueSheet 18.11.2004 15:51:33 #1 Phase 72 File dlgbrnst.cpp, Line 1449 BURN-Proof activated 15:51:33 #2 Text 0 File Reader.cpp, Line 118 Reader running 15:51:33 #3 Text 0 File Writer.cpp, Line 129 Writer PLEXTOR CD-R PX-W4012A running 15:51:33 #4 Text 0 File Burncd.cpp, Line 2636 Turn on Track-At-Once, using CD-R/RW media 15:51:33 #5 Text 0 File ThreadedTransferInterface.cpp, Line 684 Setup items (original item values) 0: TRM_DATA_RAW_MODE1 (Cue Sheet Track) 2 indices, index0 (150) provided original CD pos #0 + 331691 (331691) = #331691/73:42.41 relocatable, CD pos for caching/writing not required/not required, no patch infos -------------------------------------------------------------- 15:51:34 #6 Text 0 File DlgWaitCD.cpp, Line 199 Last possible write address on media: 359845 (79:59.70) Last address to be written: 331690 (73:44.40) 15:51:35 #7 Text 0 File DlgWaitCD.cpp, Line 1387 Recorder: PLEXTOR CD-R PX-W4012A; CDR code: 00 97 32 19; OSJ entry from: Prodisc Technology Inc. ATIP Data: Special Info [hex] 1: E0 00 B0, 2: 61 20 13 (LI 97:32.19), 3: 4F 3B 47 (LO 79:59.71) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 15:51:35 #8 Text 0 File ThreadedTransferInterface.cpp, Line 834 Prepare recorder PLEXTOR CD-R PX-W4012A for write in TAO DAO infos: ========== MCN: TOCTYPE: 0x0 Close CD Tracks 1 to 1: TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 679610368 15:51:35 #9 Text 0 File ThreadedTransferInterface.cpp, Line 862 Removed 2 run-out blocks from end of track 1. 15:51:35 #10 Text 0 File ThreadedTransferInterface.cpp, Line 684 Setup items (after recorder preparation) 0: TRM_DATA_RAW_MODE1 (Cue Sheet Track) 2 indices, index0 (150) provided original CD pos #0 + 331691 (331691) = #331691/73:42.41 relocatable, CD pos for caching/writing not required/not required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 331689 blocks [PLEXTOR CD-R PX-W4012A] -------------------------------------------------------------- 15:51:35 #11 Phase 36 File dlgbrnst.cpp, Line 1449 Burn process started at 24x (3 600 KB/s) 15:51:35 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1960 Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0 15:51:35 #13 Text 0 File Mmc.cpp, Line 15644 Set BUFE: BURN-Proof -> ON 15:54:30 #14 SCSI -1135 File Cdrdrv.cpp, Line 1398 SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02880000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x07 CDB Data: 0x2A 0x00 0x00 0x03 0x90 0x71 0x00 0x00 0x1F 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x03 0x00 0x03 0x91 0x07 0x0A 0x00 0x00 0x00 0x00 0x0C 0x07 15:54:30 #15 MMC -1135 File Writer.cpp, Line 330 Write error 15:54:30 #16 Text 0 File ThreadedTransfer.cpp, Line 222 all writers idle, stopping conversion 15:54:30 #17 Text 0 File ThreadedTransfer.cpp, Line 216 conversion idle, stopping reader 15:54:52 #18 CDR -201 File WriterStatus.cpp, Line 186 Invalid writestate 15:54:52 #19 TRANSFER -18 File WriterStatus.cpp, Line 186 Could not perform EndTrack 15:55:21 #20 Phase 38 File dlgbrnst.cpp, Line 1449 Burn process failed at 24x (3 600 KB/s) 15:55:21 #21 Text 0 File Scsicmd.cpp, Line 386 SCSI not using temporary buffers 20 out of 20 temporary buffers allocated Existing drivers: Jeg har alltid på simulering først og den er alltid vellykket, men når selve brenningen skjer blir det masse tull selv om jeg brenner på 24x og brenneren tåler 40x. Når jeg hadde Windows 98, funket det nesten alltid. Jeg har prøvd å brenne med både Nero og CloneCD og med sony, memorex og smartbuy som alle er lagd for 48x. og 52x. Jeg har prøvd å brenne fra cd til cd og fra harddisk til cd og virtuell cd-rom til cd. Brenningen stopper også alltid mellom 50 og 99,9 %. Hva gjør jeg feil? Hva er feil instillt? Lenke til kommentar
maedox Skrevet 18. november 2004 Del Skrevet 18. november 2004 Kan faktisk være så enkelt som er dårlig kabel til brenneren. Lenke til kommentar
neb Skrevet 18. november 2004 Del Skrevet 18. november 2004 (endret) eller dårlige CDer.. Har samme brenner.. har samme problemet med visse CD produsenter.. Verbatim cder fungerer utmerket.. kan også være som maedox sier .. men prøv en annen cd produsent eller IDE kabel i første omgang! Endret 18. november 2004 av bigben247 Lenke til kommentar
JKJK Skrevet 18. november 2004 Del Skrevet 18. november 2004 står brenneren din i PIO mode? Lenke til kommentar
shit89 Skrevet 18. november 2004 Forfatter Del Skrevet 18. november 2004 PIO<---- hva? Lenke til kommentar
maedox Skrevet 18. november 2004 Del Skrevet 18. november 2004 PIO<---- hva? Vil våge å påstå at det er uvesentlig siden brenneren har Burn-proof teknologi. Lenke til kommentar
JKJK Skrevet 19. november 2004 Del Skrevet 19. november 2004 Vil våge å påstå at det er uvesentlig siden brenneren har Burn-proof teknologi. Sant. Men kjekt å sjekke likevell. Går ikke akurat kjapt å brenne i pio mode heller Lenke til kommentar
talisar Skrevet 19. november 2004 Del Skrevet 19. november 2004 - Har du et nforce2 hovedkort og bruker idedriveren som kommer fra Nvidia? - Bruker du en virtuellcdrom? Daemontools f.eks? Lenke til kommentar
mandela Skrevet 19. november 2004 Del Skrevet 19. november 2004 har du testet annet brenneprogram? Lenke til kommentar
petterg Skrevet 19. november 2004 Del Skrevet 19. november 2004 Har opplevd med Memorex Cd'r at brenninga feiler hvis man ikke SKRUR AV burn-proof! Lenke til kommentar
hakrist Skrevet 19. november 2004 Del Skrevet 19. november 2004 (endret) Denne brenneren er vel en av de mindre bra som plextor har laget. Mye dårlige rykter om denne. Vel, nok om det. Hadde denne brenneren selv og opplevde samme problemene. Brenneren ble verre og verre over tid. Fant egentlig aldri ut av det, så jeg kjøpte ny brenner istedet jeg. Edit: Prøv å avinstallere plextools. Opplevde at nyere versoner av plextools gjorde saken verre. Versjonen som fulgte med brenneren (trur det var v1.07) virket ok, men så fort jeg oppgradere så ble det krøll. Et av problemene jeg opplevde med plextools installert var at windows trudde brenneren stod i pio selv om bios var satt til dma (Plextools rapporterte dma). Brenneren var heller ikke veldig happy for å stå på samme kabelen som andre ide enheter. Endret 19. november 2004 av hakrist Lenke til kommentar
hakrist Skrevet 19. november 2004 Del Skrevet 19. november 2004 PIO<---- hva? Vil våge å påstå at det er uvesentlig siden brenneren har Burn-proof teknologi. PIO mode har skapt problemer for meg med flere brennere. Greit nok at de har burn-proof, men ikke alle brennere takler uendelig med stopp og start i brenningen. Hvis det blir for mye av dette så vil du uansett kunne oppleve feilbrenning. Lenke til kommentar
