Hva er TSOP?
Aetius
hmm spesiel Socket kansje er ikke helt sikker, Google var ikke til mye hjelp heller
Prøv å søke på define:tsop, jeg fant en del. F.eks dette:
TSOP (Thin Small-Outline Package) - A DRAM package that uses gull-wing leads on both sides. TSOP DRAM mounts directly on the surface of the printed circuit board. The TSOP package is one-third the thickness of an SOJ. TSOP components commonly occur in small-outline DIMMs and credit card memory.
