Problem med at drivaren kræsje systemet mitt.Hjelp
Efreet
Eg har eit Gainward Geforce 6800 ultra 256mb grafikk kort. Problemet er at drivarane eg har får systemet mitt til å gå i stå. F.ek. denne; http://www.nvidia.com/object/winxp_2k_66.93
Den gjer at alt blir rugglete og deformert og ingenting virker og PCen restarter.
Det gjer også den som følger med CDen.
Så eg lurte. er det noen eldre drivarar eg kan bruke, da denne tydligvis ikkje virker på mitt system?
denne erroren får eg av microsoft, om det er til noe hjelp:
Error caused by NVIDIA® Corporation: No specific solution found
Problem Description:
An unknown error occurred in the NVIDIA Graphics Driver created by NVIDIA® Corporation. If you were not using the product when it crashed, it is possible the application/driver is automatically started. The driver or application may cause problems even if you are not currently using NVIDIA Graphics Driver.
Problem Resolution:
Microsoft is currently not aware of a specific solution for the problem that you reported. Below are a list of recommendations to take which may help prevent the problem from reoccurring.
Contact NVIDIA® Corporation for support or product updates.
Remove the faulting application or driver. Click here for instructions.
If this problem continues to occur with the latest product updates for NVIDIA Graphics Driver we highly recommend you obtain assistance and troubleshooting information directly from NVIDIA® Corporation.
eg har jo den nyaste drivaren, det er den sin feil.
PS: Samme gjelder for SP2, men den gir annen error :/
Takker for alle seriøse svar.
  • 2 uker senere...
