Hvordan avinstallere Mediaplayer 10
takk for ingenting
http://www.microsoft.com/windows/windowsmedia/mp10/faq.aspx ;)
Windows Media Player is a feature of the operating system and cannot be removed entirely. However, depending upon which version of the Player and Windows you are using, you might be able to revert to an earlier version of the Player or remove access to the Player.
If you are running Windows Media Player 9 Series or later, you can revert to an earlier version of the Player. For more information, see question 2.3.
Endret av jarmo
