Kompilere kjernen for HyperThreading støtte
iver89
Du finner ikke noe info i dmesg. Jeg har allerede prøvd.
# dmesg | grep CPU
Initializing CPU#0
CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000
CPU: After vendor identify, caps: bfebfbff 00000000 00000000 00000000
CPU: Trace cache: 12K uops, L1 D cache: 8K
CPU: L2 cache: 512K
CPU: Physical Processor ID: 0
CPU: After all inits, caps: bfebfbff 00000000 00000000 00000080
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
CPU0: Thermal monitoring enabled
CPU0: Intel(R) Pentium(R) 4 CPU 3.00GHz stepping 09
per-CPU timeslice cutoff: 1462.98 usecs.
enabled ExtINT on CPU#0
Initializing CPU#1
masked ExtINT on CPU#1
CPU: L2 cache: 512K
Intel machine check reporting enabled on CPU#1.
CPU1: Intel P4/Xeon Extended MCE MSRs (12) available
CPU1: Thermal monitoring enabled
CPU1: Intel(R) Pentium(R) 4 CPU 3.00GHz stepping 09
..... CPU clock speed is 2998.0170 MHz.
checking TSC synchronization across 2 CPUs: passed.
Brought up 2 CPUs
CPU0: online
CPU1: online
ACPI: Processor [CPU1] (supports C1)
ACPI: Processor [CPU2] (supports C1)
