e mail script
har et som jeg fant en gang der du kan logge på den serveren du måtte ønske
hoved filen
<?php
# Feriepost
$version = "0,13";
# Released under the terms of the GNU General Public License.
# Please refer to the readme file for more information.
# You may edit the following variables if you want to.
# Please pick a language file:
$languageFile = "language files/english.php";
# If you only want to use Feriepost with one particular server,
# you can write the name of the server (i.e. mail.example.com) here:
$fixedServer = "";
# If the fixed server does not run on port 110,
# you can fill in the port number here:
$fixedServerPort = "";
# If Feriepost is only going to be used by one particular user
# (that is, one particular POP3 account), you can fill in the
# POP3 username here:
$fixedUser = "";
# If Feriepost is only going to be used by one particular user,
# you can write the default "From:" address here
# (i.e. "Your Name <[email protected]>").
$fixedSender = "";
# you can write a signature here.
$signature = "";
# That's it!
require($languageFile);
function links($tekst) {
   # Quoted printable... I hate it!
   $tekst = str_replace("=E6", "æ", $tekst);
   $tekst = str_replace("=F8", "ø", $tekst);
   $tekst = str_replace("=E5", "å", $tekst);
   $tekst = str_replace("=C6", "Æ", $tekst);
   $tekst = str_replace("=D8", "Ø", $tekst);
   $tekst = str_replace("=C5", "Å", $tekst);
   $tekst = str_replace("=A7", "§", $tekst);
   $tekst = str_replace("=A4", "¤", $tekst);
   $tekst = str_replace("=3D", "=", $tekst);
   $tekst = str_replace("=20", " ", $tekst);
   $tekst = str_replace("=A3", "£", $tekst);
   $tekst = str_replace("=E4", "ä", $tekst);
   $tekst = str_replace("=F6", "ö", $tekst);
   $tekst = str_replace("=C4", "Ä", $tekst);
   $tekst = str_replace("=D6", "Ö", $tekst);
   # Replacing less than and greater than with the HTML entities.
   # The reason why I don't use htmlspecialchars() is the fact that
   # htmlspecialchars() also converts "&" into "&", which creates problems
   # with the regular expressions below when dealing with URLs that include
   # "&" (i.e. "http://example.com/page.php?var1=value&var2=value").
   $tekst = str_replace("<", "<", $tekst);
   $tekst = str_replace(">", ">", $tekst);
   # Turning email addresses into links:
   $tekst = eregi_replace("([_.a-z0-9-]+@[_.a-z0-9-]+\.[a-z]{2,3})", "<a href=\"$GLOBALS[PHP_SELF]?handling=skriv&modtager=\\1\">\\1</a>", $tekst);
   # Links beginning with an Internet protocol:
   $tekst = eregi_replace("((http://|ftp://|news://|file://)[_.a-z0-9-]+[a-z]{2,3}[a-z0-9/_:@=.+?#%&~-]*[^. |! |? ])", "<a href=\"\\1\" target=\"blank\">\\1</a>", $tekst);
   # HTTP links with no "http://" in front of them. The string must begin with either
   # a space, a carriage return or a newline.
   $tekst = eregi_replace("([ |\r|\n])([a-z0-9.-]+\.[a-z]{2,3}[a-z0-9&/_:@=.+?;#%~-]*[^. |! |? ])", "\\1<a href=\"http://\\2\" target=\"blank\">\\2</a>", $tekst);
   return $tekst;
function sidehoved($titel = "", $klasse = "", $visBody = 1) {
   if ($titel) {
       $titel = "Feriepost | $titel";
   else {
       $titel = "Feriepost";
   echo "<html><head><title>$titel</title>\n";
   echo "<style type=text/css><!--\n";
   echo "body { background: white; color: black }\n";
   echo "body.venstre { background: navy; color: black }\n";
   echo "body.oevre { background: white; color: black }\n";
   echo "body.nedre { background: white; color: black }\n";
   echo "body,td { font-family: helvetica; font-size: 10pt }\n";
   echo "td.listeoverskrift { background: navy; color: white }\n";
   echo "td.liste { background: #d0d0d0; color: black }\n";
   echo "input.blaa { background: navy; color: white }\n";
   echo "a:link { color: red }\n";
   echo "a:active { color: red }\n";
   echo "a:visited { color: navy }\n";
   echo "--></style>\n";
   echo "</head>\n\n\n\n";
   if ($visBody == 1) {
       if ($klasse) {
           $klasse = " class=\"$klasse\"";
       echo "<body$klasse>\n";
function sidefod() {
   echo "</body></html>";
function fejl($fejlbesked, $hoved = 0, $fod = 0) {
   if ($hoved == 1) {
       sidehoved();
   echo "<h3>$GLOBALS[s_error]</h3>\n";
   echo "$fejlbesked<p>\n";
   echo "<form><input type=button class=blaa value=\"<<< $GLOBALS[s_back]\" onClick=history.back()></form>\n";
   if ($fod == 1) {
       sidefod();
   exit;
# The logout page
if ($logUd == 1) {
   setcookie("server");
   setcookie("port");
   setcookie("bruger");
   setcookie("adgangskode");
   sidehoved();
   echo "<h3>$s_loggedOut</h3>\n";
   echo "$s_reenter\n";
   sidefod();
   exit;
# Left frame
if ($ramme == "venstre") {
   sidehoved("", "venstre");
   sidefod();
   echo "<a href=\"$PHP_SELF?ramme=oevre\" target=oevre><img src=\"images/hent.gif\" height=48 width=48 border=0 alt=\"$s_check\"></a>\n";
   echo "<a href=\"$PHP_SELF?handling=skriv\" target=nedre><img src=\"images/skriv.gif\" height=48 width=48 border=0 alt=\"$s_compose\"></a>\n";
   echo "<a href=\"README.html\" target=nedre><img src=\"images/readme.gif\" height=48 width=48 border=0 alt=\"$s_help\"></a>\n";
   echo "<a href=\"$PHP_SELF?logUd=1\" target=_top><img src=\"images/ud.gif\" height=48 width=48 border=0 alt=\"$s_logOut\"></a>\n";
   exit;
# Bottom frame
if ($ramme == "nedre") {
   sidehoved("", "nedre");
   echo "<br><br><br><br>\n";
   echo "<center>\n";
   echo "<span style=\"background: black; color: white; font-size: 14pt; font-style: italic; font-weight: bold\">";
   echo "   Feriepost   ";
   echo "</span>\n";
   echo "</center>\n";
   sidefod();
   exit;
# The login page
if (!$server || !$port || !$bruger || !$adgangskode) {
   sidehoved();
   echo "<table border=0 cellspacing=1 cellpadding=3>\n";
   echo "<form action=\"$PHP_SELF\" method=post>\n";
   echo "<tr><td class=listeoverskrift colspan=2><b>Feriepost</b></td>\n";
   echo "<tr><td class=liste>$s_server</td>\n";
   if ($fixedServer) {
       echo "<input type=hidden name=server value=\"$fixedServer\">\n";
       echo "<td class=liste>$fixedServer</td>\n";
   else {
       echo "<td class=liste><input type=text name=server size=18></td>\n";
   echo "<tr><td class=liste>$s_port</td>\n";
   if ($fixedServer) {
       if ($fixedServerPort) {
           echo "<input type=hidden name=port value=\"$fixedServerPort\">\n";
           echo "<td class=liste>$fixedServerPort</td>\n";
       else {
           echo "<input type=hidden name=port value=110>\n";
           echo "<td class=liste>110</td>\n";
   else {
       echo "<td class=liste><input type=text name=port size=18 value=110></td>\n";
   echo "<tr><td class=liste>$s_user</td>\n";
   if ($fixedUser) {
       echo "<input type=hidden name=bruger value=\"$fixedUser\">\n";
       echo "<td class=liste>$fixedUser</td>\n";
   else {
       echo "<td class=liste><input type=text name=bruger size=18></td>\n";
   echo "<tr><td class=liste>$s_password</td>\n";
   echo "<td class=liste><input type=password name=adgangskode size=18></td>\n";
   echo "<tr><td class=liste> </td>\n";
   echo "<td class=liste><input type=submit class=blaa value=\"$s_submit\"></td>\n";
   echo "<tr><td class=listeoverskrift colspan=2>$s_cookies</td>\n";
   echo "</form>\n";
   echo "</table>\n";
   sidefod();
   exit;
$fp = fsockopen($server, $port) or fejl($s_cannotConnect, 1, 1);
$foersteLinje = fgets($fp, 1024);
fputs($fp, "USER $bruger\r\n");
$andenLinje = fgets($fp, 1024);
fputs($fp, "PASS $adgangskode\r\n");
if (substr(fgets($fp, 1024), 0, 3) != "+OK") {
   fejl($s_wrongPassword, 1, 1);
setcookie("server", $server, time()+3600);
setcookie("port", $port, time()+3600);
setcookie("bruger", $bruger, time()+3600);
setcookie("adgangskode", $adgangskode, time()+3600);
# Frameset
if (!$QUERY_STRING) {
   sidehoved("", "", 0);
   echo "<frameset cols=75,* border=3>\n";
   echo "<frame src=\"$PHP_SELF?ramme=venstre\" name=venstre scrolling=no>\n";
   echo "<frameset rows=20%,* border=3>\n";
   echo "<frame src=\"$PHP_SELF?ramme=oevre\" name=oevre>\n";
   echo "<frame src=\"$PHP_SELF?ramme=nedre\" name=nedre>\n";
   echo "</frameset>\n";
   echo "</frameset></html>";
# The compose page
if ($handling == "skriv") {
   sidehoved();
   if ($send) {
       if (!$til) {
           fejl($s_noRecipient);
       if (!eregi("[a-z0-9]+@[a-z0-9]+", $til)) {
           fejl($s_invalidRecipient);
       $til = stripslashes($til);
       $fra = stripslashes($fra);
       $emne = stripslashes($emne);
       $tekst = stripslashes($tekst);
       $headere = "From: $fra\nX-Mailer: Feriepost $version\n";
       if ($cc) {
           $headere .= "CC: $cc\n";
       if ($bcc) {
           $headere .= "BCC: $bcc\n";
       if ($fil_name) {
           if (!$fil_type) {
               $fil_type = "application/unknown";
           $adskiller = uniqid("Feriepost");
           $headere .= "Content-Type: multipart/mixed;\n boundary=\"$adskiller\"\n";
           $aabenFil = $filindhold = fopen($fil, "r");
           $filindhold = fread($aabenFil, filesize($fil));
           if (ereg("^text/", $fil_type)) {
               $disposition = "inline";
               $indkodning = "8bit";
           else {
               $filindhold = chunk_split(base64_encode($filindhold));
               $disposition = "attachment";
               $indkodning = "base64";
           $tekst = "--$adskiller\nContent-Type: text/plain\nContent-Transfer-Encoding: 8bit\n\n$tekst\n\n";
           $tekst .= "--$adskiller\nContent-Type: $fil_type;\n name=\"$fil_name\"\nContent-Transfer-Encoding: $indkodning\nContent-Disposition: $disposition;\n filename=\"$fil_name\"\n\n$filindhold\n--$adskiller--";
       mail($til, $emne, $tekst, $headere);
       echo "$s_emailSent\n";
       sidefod();
       exit;
   $ebrev = htmlspecialchars(stripslashes($ebrev));
   $fixedSender = htmlspecialchars($fixedSender);
   $signature = htmlspecialchars($signature);
   $emne = htmlspecialchars(chop($emne));
   if ($besvar) {
       if (!eregi("^Re: ", $emne)) {
           $emne = "Re: $emne";
   if ($videresend) {
       $emne = "Fwd: $emne";
       $ebrev = "-------------------- $s_forwarded --------------------\n\n$ebrev";
   if ($besvar) {
       $modtager = htmlspecialchars(chop($modtager));
       $ebrev = str_replace("\n", "\n> ", $ebrev);
       $ebrev = "$modtager $s_wrote\n>\n> $ebrev";
   if ($videresend) {
       $modtager = "";
   echo "<form action=\"$PHP_SELF?handling=skriv\" enctype=\"multipart/form-data\" method=post>\n";
   echo "<tr><td class=liste>$s_writeTo</td>\n";
   echo "<td class=liste><input type=text name=til size=40 value=\"$modtager\">\n";
   echo "<tr><td class=liste>$s_writeFrom</td>\n";
   echo "<td class=liste><input type=text name=fra size=40 value=\"$fixedSender\">\n";
   echo "<tr><td class=liste>$s_writeCc</td>\n";
   echo "<td class=liste><input type=text name=cc size=40>\n";
   echo "<tr><td class=liste>$s_writeBcc</td>\n";
   echo "<td class=liste><input type=text name=bcc size=40>\n";
   echo "<tr><td class=liste>$s_writeAttach</td>\n";
   echo "<input type=hidden name=\"MAX_FILE_SIZE\" value=\"204800\">\n";
   echo "<td class=liste><input type=file name=fil size=40>\n";
   echo "<tr><td class=listeoverskrift>$s_writeSubject</td>\n";
   echo "<td class=listeoverskrift><input type=text name=emne size=40 value=\"$emne\">\n";
   echo "</table>\n";
   echo "<textarea name=tekst cols=72 rows=10>\n";
   echo $ebrev;
   if ($signature) {
       echo "\n\n-- \n$signature";
   echo "</textarea><br>\n";
   echo "<input type=submit class=blaa name=send value=\"$s_send\">\n";
   echo "</form>\n";
   sidefod();
# The top frame -- message list
if ($ramme == "oevre") {
   sidehoved("", "oevre");
   # Deleting emails:
   if ($sletEbreve) {
       for ($i = 0; $i < sizeof($sletEbreve); $i++) {
           fputs($fp, "DELE $sletEbreve[$i]\r\n");
       fputs($fp, "QUIT\r\n");
       echo "<form action=\"$PHP_SELF?ramme=oevre\" method=post>\n";
       echo "$s_messagesDeleted<br>\n";
       echo "<input type=submit class=blaa value=\"$s_ok\">\n";
       echo "</form>\n";
       sidefod();
       exit;
   fputs($fp, "STAT\r\n");
   $ebreve = fgets($fp, 1024);
   $ebreve = split(" ", $ebreve);
   $antalEbreve = $ebreve[1];
   if ($antalEbreve == 0) {
       echo "$s_noEmails\n";
       sidefod();
       exit;
   echo "<script language=\"javascript\"><!--\n";
   echo "function krydsAf(alleEllerIngen) {\n";
   echo "  for (i = 0; i < document.forms[0].elements.length; i++) {\n";
   echo "      if (alleEllerIngen == \"alle\") {\n";
   echo "          document.forms[0].elements[i].checked = true\n";
   echo "      }\n";
   echo "      else {\n";
   echo "          document.forms[0].elements[i].checked = false\n";
   echo "      }\n";
   echo "  }\n";
   echo "}\n";
   echo "// --></script>\n";
   echo "<table width=100% border=0 cellspacing=1 cellpadding=2>\n";
   echo "<tr><td class=listeoverskrift>$s_delete</td>\n";
   echo "<td class=listeoverskrift>$s_subject</td>\n";
   echo "<td class=listeoverskrift>$s_from</td>\n";
   echo "<td class=listeoverskrift>$s_date</td>\n";
   echo "<td class=listeoverskrift>$s_size</td>\n";
   for ($i = $antalEbreve; $i >= 1; $i--) {
       fputs($fp, "TOP $i 0\r\n");
       while (substr($linje = fgets($fp, 1024), 0, 2) != chr(13).chr(10)) {
           if (substr($linje, 0, 9) == "Subject: ") {
               $emne = htmlspecialchars(substr($linje, 9));
           if (substr($linje, 0, 6) == "From: ") {
               $fra = htmlspecialchars(substr($linje, 6));
           if (substr($linje, 0, 6) == "Date: ") {
               $dato = htmlspecialchars(substr($linje, 6));
           if (substr($linje, 0, 3) == "+OK") {
               $stoerrelse = split(" ", $linje);
               $stoerrelse = $stoerrelse[1];
               # If the size information is available:
               if ($stoerrelse && $stoerrelse != "\r\n") {
                   $stoerrelse = $stoerrelse / 1024;
                   $stoerrelse = number_format($stoerrelse, 1);
                   $stoerrelse = str_replace(".", $s_decimalDelimiter, $stoerrelse);
                   $stoerrelse = "$stoerrelse $s_kb";
               else {
                   # Some POP3 servers don't show the file size of the message
                   # when you enter the "TOP" command.
                   # Therefore, we'll just write a hyphen instead of the file size.
                   $stoerrelse = "-";
       # Certain browsers don't paint the background in the table cells
       # if the cells are empty. Therefore, we need to put a " "
       # in the cells if the headers are empty.
       if (!$emne || $emne == "\r\n") {
           $emne = " ";
       if (!$dato || $dato == "\r\n") {
           $dato = " ";
       if (!$fra || $fra == "\r\n") {
           $fra = " ";
       echo "<tr><td class=liste><input type=checkbox name=sletEbreve[] value=$i></td>\n";
       echo "<td class=liste><a href=\"$PHP_SELF?visEbrevNummer=$i\" target=nedre style=\"text-decoration: none; color: black\">$emne</a></td>\n";
       echo "<td class=liste><a href=\"$PHP_SELF?visEbrevNummer=$i\" target=nedre style=\"text-decoration: none; color: black\">$fra</a></td>\n";
       echo "<td class=liste><a href=\"$PHP_SELF?visEbrevNummer=$i\" target=nedre style=\"text-decoration: none; color: black\">$dato</a></td>\n";
       echo "<td class=liste><a href=\"$PHP_SELF?visEbrevNummer=$i\" target=nedre style=\"text-decoration: none; color: black\">$stoerrelse</a></td>\n";
   echo "</table>\n";
   echo "<input type=button class=blaa value=\"$s_selectAll\" onClick=\"krydsAf('alle')\">\n";
   echo "<input type=button class=blaa value=\"$s_deselectAll\" onClick=\"krydsAf('ingen')\">\n";
   echo "<input type=submit class=blaa value=\"$s_delete\">\n";
   echo "</form>\n";
   sidefod();
if ($visKilden && $ebrevNummer) {
   sidehoved();
   echo "<pre>\n";
   fputs($fp, "RETR $ebrevNummer\r\n");
   while (substr($linje = fgets($fp, 1024), 0, 3) != ".".chr(13).chr(10)) {
       echo htmlspecialchars($linje);
   echo "</pre>\n";
   sidefod();
# Displaying the contents of the email
if ($visEbrevNummer) {
   sidehoved();
   fputs($fp, "RETR $visEbrevNummer\r\n");
       if ($visAlleHeadere == 1) {
           if (ereg(": ", $linje)) {
               $position =strpos($linje, " ");
               $headernavn = substr($linje, 0, $position);
               $headervaerdi = substr($linje, $position);
               $headernavn = htmlspecialchars($headernavn);
               $headervaerdi = htmlspecialchars($headervaerdi);
               $alleHeadere .= "<b>$headernavn</b>$headervaerdi";
           else {
               $alleHeadere .= htmlspecialchars($linje);
       if (substr($linje, 0, 4) == "To: ") {
           $til = htmlspecialchars(substr($linje, 4));
       if (substr($linje, 0, 10) == "X-Mailer: ") {
           $postprogram = htmlspecialchars(substr($linje, 10));
   echo "<form action=\"$PHP_SELF?handling=skriv\" method=post>\n";
   echo "<table width=100% border=0 cellspacing=0 cellpadding=2 style=\"background: #d0d0d0\">\n";
   $mellemrum = "     ";
   echo "<tr><td style=\"background: navy; color: white\" colspan=2>\n";
   echo "<input type=submit class=blaa name=besvar value=\"$s_reply\">\n";
   echo "$mellemrum\n";
   echo "<input type=submit class=blaa name=videresend value=\"$s_forward\">\n";
   echo "<input type=button class=blaa value=\"$s_print\" onClick=self.print()>\n";
       echo "<a href=\"$PHP_SELF?visEbrevNummer=$visEbrevNummer\" style=\"text-decoration: none; color: white\">$s_showNormalHeaders</a>\n";
   else {
       echo "<a href=\"$PHP_SELF?visEbrevNummer=$visEbrevNummer&visAlleHeadere=1\" style=\"text-decoration: none; color: white\">$s_showAllHeaders</a>\n";
   echo "<a href=\"$PHP_SELF?visKilden=1&ebrevNummer=$visEbrevNummer\" target=\"_blank\" style=\"text-decoration: none; color: white\">$s_showSource</a>\n";
   echo "</td>\n";
       echo "<tr><td>\n";
       echo "<pre>\n";
       echo $alleHeadere;
       echo "</pre>\n";
       echo "</td>\n";
       echo "<td> </td>\n";
   else {
           $emne = " ";
           $dato = " ";
           $fra = " ";
       if (!$til || $til == "\r\n") {
           $til = " ";
       if (!$postprogram || $postprogram == "\r\n") {
           $postprogram = " ";
       echo "<tr><td><b>$s_mSubject</b></td>\n";
       echo "<td><b>".links($emne)."</b></td>\n";
       echo "<tr><td><b>$s_mDate</b></td>\n";
       echo "<td>".links($dato)."</td>\n";
       echo "<tr><td><b>$s_mFrom</b></td>\n";
       echo "<td>".links($fra)."</td>\n";
       echo "<tr><td><b>$s_mTo</b></td>\n";
       echo "<td>".links($til)."</td>\n";
       echo "<tr><td><b>$s_mMailer</b></td>\n";
       echo "<td>".links($postprogram)."</td>\n";
   echo "</table>\n";
       $ebrevtekst .= $linje;
   echo "<input type=hidden name=ebrev value=\"".htmlspecialchars($ebrevtekst)."\">\n";
   echo "<input type=hidden name=modtager value=\"$fra\">\n";
   echo "<input type=hidden name=emne value=\"$emne\">\n";
   echo "<pre>\n";
   echo links($ebrevtekst);
   echo "</pre>\n";
   echo "</form>\n";
   sidefod();
fclose($fp);
denne trenger følgende språk fil
<?php
# The error page
$s_error =              "An error occured:";
$s_back =               "Back";
$s_cannotConnect =      "The program cannot connect to the server $server on port $port.";
$s_wrongPassword =      "The username and/or the password is wrong.";
# The logout page
$s_loggedOut =          "You are now logged out.";
$s_reenter =            "Click <a href=\"$PHP_SELF\">here</a> to re-enter.";
# The login page
$s_server =             "Server:";
$s_port =               "Port:";
$s_user =               "Username:";
$s_password =           "Password:";
$s_submit =             "OK";
$s_cookies =            "Please notice that cookies must be enabled in your browser in order for Feriepost to work.";
# The message list
$s_noEmails =           "There are no new messages.";
$s_selectAll =          "Select all";
$s_deselectAll =        "Deselect all";
$s_delete =             "Delete";
$s_subject =            "Subject";
$s_from =               "Sender";
$s_date =               "Date";
$s_size =               "Size";
$s_kb =                 "Kb";
$s_messagesDeleted =    "The selected message(s) have been deleted.";
$s_ok =                 "OK";
# The decimal delimiter. In some countries it is
# a comma, in other countries it is a period:
$s_decimalDelimiter =   ".";
# Message information
$s_mSubject =           "Subject:";
$s_mFrom =              "Sender:";
$s_mTo =                "Recipient:";
$s_mDate =              "Date:";
$s_mMailer =            "Mail client:";
$s_reply =              "Reply";
$s_forward =            "Forward";
$s_showNormalHeaders =  "Show normal headers";
$s_showAllHeaders =     "Show all headers";
$s_showSource =         "Show the source";
$s_print =              "Print";
# The left frame
$s_check =              "Check for new mail";
$s_compose =            "Compose";
$s_help =               "Help";
$s_logOut =             "Log out";
# The compose page
$s_writeTo =            "To:";
$s_writeFrom =          "From:";
$s_writeCc =            "CC:";
$s_writeBcc =           "BCC:";
$s_writeAttach =        "Attachment:";
$s_writeSubject =       "Subject:";
$s_wrote =              "wrote:";
$s_forwarded =          "Forwarded message";
$s_send =               "Send";
$s_emailSent =          "The message has been sent.";
$s_noRecipient =        "You did not enter anything in the <i>To</i> field.";
$s_invalidRecipient =   "The email address in the <i>To</i> field is invalid.";
pluss noen bilder
Endret av lord_n
