3D Mark error
Hei, har installert mitt "gamle" skjermkort GeForce 3 igjen, da Geforce 4 TI ble for dyrt. Da jeg kjører 3D Mark 2001 SE får jeg en feilmelding og denne loggen er kreert:
Application info
Name 3DMark2001 SE
Build 300
Error log
Texture mapping not supported.
System info available: yes
Project available: no
System info
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer Intel
Family Pentium® 4
Internal Clock 1.72 GHz
Internal Clock Maximum 2.34 GHz
External Clock 110 MHz
Socket Designation PGA478
Type <unknown>
Upgrade <unknown>
Capabilities MMX, CMov, RDTSC, SSE, SSE2
Version Intel® Pentium® 4 Processor
CPUID 0x00000f12
CACHES
Level 1
Capacity 8 KB
Type Data, Internal
Type Details Synchronous, Pipeline Burst
Error Correction Type Single-bit ECC
Associativity 4-way Set-Associative
Level 2
Capacity 256 KB
Type Instruction, Data, Internal
Error Correction Type Parity
Associativity <unknown>
DIRECTX INFO
DirectX Version 8.1
DIRECTDRAW INFO
DirectDraw Version 5.1.2600.0
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer NVIDIA
Name NVIDIA GeForce3 Ti 200
Total Local Video Memory 128 MB
Total Local Texture Memory 128 MB
Total AGP Memory 63 MB
Display Driver nv4_disp.dll
Display Driver Version 6.13.10.2832
Driver WHQL Certified Yes
Max Texture Width 0
Max Texture Height 0
Max User Clipping Planes 0
Max Active Hardware Lights 0
Max Texture Blending Stages 0
Textures In Single Pass 0
Vertex Shader Version N/A
Pixel Shader Version N/A
Max Vertex Blend Matrices 0
Max Texture Coordinates 0
Vendor ID 0x10de
Device ID 0x0201
Sub-System ID 0x0c4d10b0
Revision 0xa3
Hva er feilen? Det står: "Texture mapping not supported" Hva F gkør jeg med et?
takker
