Hvordan stenge porter med OutPost Firewall?
Ideally your status should be "Blocked". This indicates that your ports are not only
closed, but they are completely hidden (stealthed) to attackers.
DNS 53 CLOSED This port has responded to our probes. This means that you are not running any application on this port, but it is still possible for someone to crash your computer through known TCP/IP stack vulnerabilities.
Når jeg kjører "Stealth Scan" på Sygates side får jeg opp en mengde porter med varsel lik den over.
Har Agnitum OutPost Firewall.
Hva gjør jeg med disse portene? Kan jeg blokkere dem i brannmuren.
Hvordan gjør jeg evt. det? :hmm:
Endret av tibbs
