Ratleto Skrevet 7. november 2004 Skrevet 7. november 2004 Hei Har Fedora Core 2, og skulle oppgradere aMule fra v1.2.6. La inn disse: cryptopp-5.1-1.1.fc2.dag.i386.rpm amule-2.0.0-0.rc5.1.1.fc2.fr.i386.rpm ...og det gikk greit, men programmet funka ikke. Det bare stoppa opp etter dette: $ amule Initialising aMule Userhash loaded: EFD89399100E3135AB8EFC95139C6F84 *** UDP socket at 1054 *** TCP socket at 1051 *** UDP socket at 1051 No cryptkey.dat found, creating Så fant jeg en nyere utgave av amule i RPM (aMule-2.0.0-rc7_fc2.i586.rpm), men når jeg skal installere denne, får jeg dette: # rpm --upgrade aMule-2.0.0-rc7_fc2.i586.rpm file /usr/bin/alc from install of aMule-2.0.0-rc7_fc2 conflicts with file from package amule-2.0.0-0.rc5.1.1.fc2.fr file /usr/bin/amule from install of aMule-2.0.0-rc7_fc2 conflicts with file from package amule-2.0.0-0.rc5.1.1.fc2.fr file /usr/bin/cas from install of aMule-2.0.0-rc7_fc2 conflicts with file from package amule-2.0.0-0.rc5.1.1.fc2.fr file /usr/bin/wxcas from install of aMule-2.0.0-rc# rpm --erase amule error: %preun(amule-2.0.0-0.rc5.1.1.fc2.fr) scriptlet failed, exit status 27_fc2 conflicts with file from package amule-2.0.0-0.rc5.1.1.fc2.fr file /usr/lib/xchat/plugins/xas.pl from install of aMule-2.0.0-rc7_fc2 conflicts with file from package amule-2.0.0-0.rc5.1.1.fc2.fr Så prøver jeg å avinstallere amule, men da får jeg dette: # rpm --erase amule error: %preun(amule-2.0.0-0.rc5.1.1.fc2.fr) scriptlet failed, exit status 2 Så hva gjør jeg nå?
Ratleto Skrevet 9. desember 2004 Forfatter Skrevet 9. desember 2004 (endret) Bump... Jeg sliter fortsatt med dette problemet. Har i tillegg nå prøvd "rpm --force -U aMule-20.0.0-rc7_fc2.i586.rpm" uten at det ble så veldig mye bedre... Stopper opp i starten nå også, bare med annen feilmelding. $ amule Initialising aMule Userhash loaded: 621B89B49D0E164AF843BA8C8A366F11 *** UDP socket at 1054 *** UDP socket at 1051 OOPS! - Seems like aMule crashed. Version is: aMule 2.0.0rc7 using wxGTK1 v2.4.2 --== BACKTRACE FOLLOWS: ==-- [0] amule(_ZN9CamuleApp16OnFatalExceptionEv+0x3c) [0x8217878] [1] /usr/lib/libwx_gtk-2.4.so.0(wxFatalSignalHandler+0x2d) [0x23c08dd] [2] /lib/tls/libpthread.so.0 [0x7d6688] [3] amule(_ZN10CSearchDlg15UpdateCatChoiceEv+0x69) [0x81e1785] [4] amule(_ZN9CamuleDlgC1EP8wxWindowRK8wxString7wxPoint6wxSize+0x55f) [0x821bf3b] [5] amule(_ZN9CamuleApp6OnInitEv+0x139d) [0x821593d] [6] /usr/lib/libwx_gtk-2.4.so.0(_Z7wxEntryiPPc+0x228) [0x223c828] [7] amule(main+0x17) [0x8214207] [8] /lib/tls/libc.so.6(__libc_start_main+0xe4) [0x5a9ad4] [9] amule(_ZNK20wxTopLevelWindowBase10GetMaxSizeEv+0x55) [0x811dce1] Aborted Edit:La til feilmeldinga Endret 9. desember 2004 av Ratleto
Gronz Skrevet 9. desember 2004 Skrevet 9. desember 2004 Stopper opp i starten nå også, bare med annen feilmelding. Hvilken da?
objorkum Skrevet 9. desember 2004 Skrevet 9. desember 2004 Bruk av RPM: Søke etter ein installert pakke: rpm -qa | grep <pakkenavn> Sletting av pakke: rpm -e <pakkenavn> Husk å bruk heile pakkenamnet, slik det står i rpm -qa.
Ratleto Skrevet 9. desember 2004 Forfatter Skrevet 9. desember 2004 root]# rpm -qa |grep aMule aMule-2.0.0-rc7_fc2 root]# rpm -e aMule-2.0.0-rc7_fc2 (det gikk greit ja) root]# rpm -qa |grep amule amule-2.0.0-0.rc5.1.1.fc2.fr root]# rpm -e amule-2.0.0-0.rc5.1.1.fc2.fr error: %preun(amule-2.0.0-0.rc5.1.1.fc2.fr) scriptlet failed, exit status 2 Fortsatt noe av det samme. Noen flere forslag, noen?
Gronz Skrevet 10. desember 2004 Skrevet 10. desember 2004 Ser ut som RPM'en din er borket. Prøv å re-installere selve RPM-programmet.
Ratleto Skrevet 12. desember 2004 Forfatter Skrevet 12. desember 2004 Tror desverre ikke det har noe med rpm å gjøre. Når jeg kjører synaptic, får jeg samme feilmeldinga: While preparing for installation: error: %preun(amule-2.0.0-0.rc5.1.1.fc2.fr) scriptlet failed, exit status 2 Når jeg kjører "apt-get remove amule-2.0.0-0.rc5.1.1.fc2.fr", får jeg dette: Reading Package Lists... Done Building Dependency Tree... Done E: Couldn't find package amule-2.0.0-0.rc5.1.1.fc2.fr Ikke si at jeg må reinstallere hele Fedora for å få det til å funke igjen...?
Gronz Skrevet 12. desember 2004 Skrevet 12. desember 2004 Tror desverre ikke det har noe med rpm å gjøre. Når jeg kjører synaptic, får jeg samme feilmeldinga: Det er jo ikke rart, siden Synaptic bare er ett front-end til RPM.
Gronz Skrevet 12. desember 2004 Skrevet 12. desember 2004 Tror desverre ikke det har noe med rpm å gjøre. Når jeg kjører synaptic, får jeg samme feilmeldinga: While preparing for installation: error: %preun(amule-2.0.0-0.rc5.1.1.fc2.fr) scriptlet failed, exit status 2 Når jeg kjører "apt-get remove amule-2.0.0-0.rc5.1.1.fc2.fr", får jeg dette: Reading Package Lists... Done Building Dependency Tree... Done E: Couldn't find package amule-2.0.0-0.rc5.1.1.fc2.fr Ikke si at jeg må reinstallere hele Fedora for å få det til å funke igjen...? Prøv å kjøre bare "apt-get remove amule".
Ratleto Skrevet 12. desember 2004 Forfatter Skrevet 12. desember 2004 root]# apt-get remove amule Reading Package Lists... Done Building Dependency Tree... Done The following packages will be REMOVED: amule (2.0.0-0.rc5.1.1.fc2.fr) 0 upgraded, 0 newly installed, 1 removed and 2 not upgraded. Need to get 0B of archives. After unpacking 5191kB disk space will be freed. Do you want to continue? [Y/n] y Committing changes... Preparing... ########################################### [100%] error: %preun(amule-2.0.0-0.rc5.1.1.fc2.fr) scriptlet failed, exit status 2 W: Some errors occurred while running transaction ...og der kom samme error.
Ratleto Skrevet 12. desember 2004 Forfatter Skrevet 12. desember 2004 Fikk det til! rpm --erase --allmatches --noscripts amule Da forsvant den som ikke skulle være der (tror jeg i alle fall - hehe) Så fant jeg også noe på amule.org-forumet om å bruke wx-pakkene derfra. Så da måtte jeg "rpm --upgrade --force wxGTK-2.4.2-1.i386.rpm" også. Og nå funker det gitt. :-)
