-HaZeN- Skrevet 6. november 2004 Del Skrevet 6. november 2004 Hei! En liten hypotese: Jeg kjøper alt det nedenfor fra customenterprise.com Hvor mye blir kostnadene utover selve prisen på delene? Hvor mye i frakt og evt. toll? Hva er den billigste og beste måten å få fraktet delene til Norge på? Sparer jeg på å få det til et EU-land og "hente" det over grensen ? Delene: NISSAN MAXIMA – ULTIMATE STYLING FOR -98mod V6 140HP FRA CUSTOMIZEENTERPRISE.COM Exterior: • Urethane body kit $ 999,- • Sarona Design Phase II Fenders $ 420,- • Sarona Design Hoods $ 649,- • Sarona Design?Roof Wing $ 269,- • Sunroof Wind Deflector $ 49,- • Grill mesh x3 $ 58,- $2444,- NOK 16500,- Interior: • Diamond Plate Floor Mats $ 139 • Triple Gauge Pods $ 59 - Water Temperature 100-260 F $139 - Voltmeter 8-18 Volts $109 - Oil Pressure 0-100 PSI $199 • Door Sills $ 99 • Maxima Dash Kits $ 200 • E-Brake Handle Covers $ 19 • Chrome Gauge Rings $ 29 • Nissan Shoulder Pads $ 12 • Corbeau Legacy Racing Seats $ 699 • Corbeau Custom Seat Brackets $ 129 NOK 12400,- Lighting: • Nissan Maxima Red Clear Taillights $ 199 • Diamond Cut Bumper Lights $ 44 • Maxima Diamond Cut Clear Corners $ 43 • 12000K Extreme Ultraviolet $ 599 • 2 Rectangular IonBlue Type 2 Foglight $ 50 NOK 6310,- Performance: • Ultra S Underdrive Pulley +20 HP $ 199 • Unorthodox Lightened Flywheel +20 HP $ 509 • Bolt On Cat-Back Dual Exhaust +10HP $ 809 • Maxima High Performance Y-Pipe +10 HP $ 249 • Maxima HighFlow Catalytic Converter +25 HP $ 149 • Injen Polished Cold Air Intake +14 HP $ 272 - Heat Shield +6 HP $ 65 • JET Computer Chip Upgrade +15 HP $ 349 • Denso Iridium Power Spark Plugs x 6 $ 96 • Design Engineering Radiator Relief $ 19 • Powerslot Rotors - Front + Rear $ 428 • Hawk High Performance Brake Pads $ 75 NOK 21730,- Suspension: • Progress Rear Anti-Sway Bar $ 139 • Maxima Front Strut Bar $ 59 • JIC Magic Suspension Kits $1849 NOK 13220,- Miscellaneous: • PIAA Wipers $ 39 • Maxima Emblems x 2 $ 28 • GT-R Emblem $ 12 NOK 530,- TOTAL SUM NOK 70690,- Ca. 70 000,- UTEN FRAKT/TOLL MEDREGNET FRAKT/TOLL ??? Lenke til kommentar
Goophy Skrevet 6. november 2004 Del Skrevet 6. november 2004 Frakt og toll er svindyrt. Aner ikke hva det koster fra USA, men jeg bestilte nesten full bodykit, dempere, bremser og eksosanlegg fra japan. Det kostet nesten 30000 å sende... Lenke til kommentar
Dan Stamnes Skrevet 11. november 2004 Del Skrevet 11. november 2004 du kan iallefall legge til +24% på totale summen, som er toll avgift, pluss sikkert noen fler og! Lenke til kommentar
tilstad Skrevet 3. desember 2004 Del Skrevet 3. desember 2004 (endret) Det er kun utvalge varer som enkelte meieriprodukter, kjøtt osv som pr idag har toll. På bildeler er det ikke toll, så man betaler kun moms. Den er som alle vet for tiden 24% og dette beregnes av prisen på varene og frakten. Fraktkostnaden finner du svært enkelt ut ved å spørre de du kjøper det av som skal sende dette. Utover dette tilkommer det et tollgebyr på 150,- evt 70,- i forenklet fortolling. Jeg kan ikke forstå at man skal spare noe på å hente noe i Sverige dersom det blir bestilt i USA. Man må uansett betale svensk moms som jeg mener er 23%. Unntaket er vel dersom man bestiller noe fra et EUland med lavere moms sats enn Sverige, og da blir det evt denne differansen man sparer. Men man kan bare ta med varer for 5000 kr over grensen, så de summene du har snakket om her kvalifiserer da faktisk for en tiltale for momsunndragelse. Endret 3. desember 2004 av tilstad Lenke til kommentar
tilstad Skrevet 3. desember 2004 Del Skrevet 3. desember 2004 Dersom firmaet er i USA og de ikke sender til Europa kan du bruke en såkalt "freight forwarder" som UPS TNT osv. Da får man ofte benyttet seg av fri frakt i USA til mottaket til forwarderen, også betaler man derfra og hjem. For å beregne kostnadene må man vite både volum og vekt. Det kan gjøres på de respektive firmaenes nettsider. Lenke til kommentar
Remi-A Berg Skrevet 4. desember 2004 Del Skrevet 4. desember 2004 Jeg mener at på deler bestilt innen EU er tollfritt mens varer utenfor EU må du betale toll for. 24% norsk mva kommer i tillegg + tollgebyrer(må ikke forveksles med toll) Mva skal tilbakebetales fra det landet du bestiller fra når du kan forevise at du har betalt norsk mva. Det er vel også en del billigere frakt å handle innen EU en på andre siden av jordkloden Lenke til kommentar
tilstad Skrevet 4. desember 2004 Del Skrevet 4. desember 2004 Det er mulig det er noe toll hvis man tar noe utenfra og inn i Eu, men nå er jo ikke vi med i Eu, så da blir det jo ikke noe. Men du kan stole på at det ikke er toll på bildeler. Sånn er det bare, jeg importerer bildeler jevnlig, fra asia, Usa, og Europa. Det er riktig det at frakt kan utgjøre mer fra usa enn europa, men når de er såpass mye mer konkurranse dyktig på prisen på varen i usa enn eu, så lønner det seg som oftest likevel. Det vanlige når man eksport klarerer noe er å ikke belaste kunden moms i utgangspunktet, derfor slipper man å få refundert noe moms fra kjøperlandet, og man betaler kun den norske. Jeg eksporterer noe varer til Sverige og Danmark, og da betales det ikke Norsk moms, fordi det skal exporteres. I prinsippet selges da varen i de landene og er kun i transitt her hjemme. Lenke til kommentar
