prescott eller northwood?
Overclocking notes:
The PR does require good cooling for a good OC, even with the higher threshold.
The PR is capable of more per clock cycle than an NW. this means that a 200mhz OC on a PR will give a bigger performance boost than an eqivalent OC on an NW.
The PR and NW even out performance-wise, at around 3.4-3.5 ghz. The PR really starts to overtake the NW at around 3.6-3.7.
The PR has more potential as it is designed for way higher clocks than the NW which is reaching its limit.
Derfor har jeg litt lyst til å bytte ut min 3,2NW!
