qemilo Skrevet 4. november 2004 Del Skrevet 4. november 2004 Har en firewire disk som jeg ikke "vet hvor er", og klarer derfor ikke mounte den. Jeg hadde trodd den skulle ligge på sdb jeg da, siden sda er opptatt til en usb pen, men dengang ei. Antar det er en commando for å se forskjellige mountbare disker? Kanskje et gui program som også kan mounte dem? Om dmesg kan hjelpe, så er den sånn som dette: TCP: Hash tables configured (established 32768 bind 32768) Linux IP multicast router 0.06 plus PIM-SM RAMDISK: cramfs filesystem found at block 0 RAMDISK: Loading 3832 blocks [1 disk] into ram disk... done. Freeing initrd memory: 3832k freed VFS: Mounted root (cramfs filesystem). Freeing unused kernel memory: 100k freed NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4 ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx ide: late registration of driver. SIS5513: IDE controller at PCI slot 00:02.5 SIS5513: chipset revision 0 SIS5513: not 100% native mode: will probe irqs later SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller ide0: BM-DMA at 0xb400-0xb407, BIOS settings: hda:DMA, hdb:pio ide1: BM-DMA at 0xb408-0xb40f, BIOS settings: hdc:DMA, hdd:DMA hda: ST380023A, ATA DISK drive blk: queue e08273a0, I/O limit 4095Mb (mask 0xffffffff) hdc: MSI CD-RW MS-8348, ATAPI CD/DVD-ROM drive hdd: ATAPI DVD-ROM 16XMax, ATAPI CD/DVD-ROM drive ide0 at 0x1f0-0x1f7,0x3f6 on irq 14 ide1 at 0x170-0x177,0x376 on irq 15 hda: attached ide-disk driver. hda: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=155061/16/63, UDMA(100) Partition check: /dev/ide/host0/bus0/target0/lun0: [PTBL] [9729/255/63] p1 p2 p3 p4 Journalled Block Device driver loaded VFS: Can't find ext3 filesystem on dev ide0(3,2). VFS: Can't find ext2 filesystem on dev ide0(3,2). Unable to identify CD-ROM format. FAT: bogus logical sector size 0 VFS: Can't find a valid FAT filesystem on dev 03:02. reiserfs: found format "3.6" with standard journal reiserfs: checking transaction log (device ide0(3,2)) ... for (ide0(3,2)) ide0(3,2):Using r5 hash to sort names VFS: Can't find ext3 filesystem on dev ide0(3,2). VFS: Can't find ext2 filesystem on dev ide0(3,2). Unable to identify CD-ROM format. FAT: bogus logical sector size 0 VFS: Can't find a valid FAT filesystem on dev 03:02. reiserfs: found format "3.6" with standard journal reiserfs: checking transaction log (device ide0(3,2)) ... for (ide0(3,2)) ide0(3,2):Using r5 hash to sort names Adding Swap: 979916k swap-space (priority -1) SCSI subsystem driver Revision: 1.00 hdc: attached ide-scsi driver. hdd: attached ide-scsi driver. scsi0 : SCSI host adapter emulation for IDE ATAPI devices Vendor: MSI Model: CD-RW MS-8348 Rev: 150D Type: CD-ROM ANSI SCSI revision: 02 Vendor: ATAPI Model: DVD-ROM 16XMax Rev: 1.00 Type: CD-ROM ANSI SCSI revision: 02 kjournald starting. Commit interval 5 seconds EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,4), internal journal EXT3-fs: mounted filesystem with ordered data mode. Consumer PCM code does not work well at the moment --jk usb.c: registered new driver usbdevfs usb.c: registered new driver hub usb-ohci.c: USB OHCI at membase 0xe0a6b000, IRQ 9 usb-ohci.c: usb-00:03.0, Silicon Integrated Systems [siS] USB 1.0 Controller usb.c: new USB bus registered, assigned bus number 1 hub.c: USB hub found hub.c: 2 ports detected usb-ohci.c: USB OHCI at membase 0xe0a6d000, IRQ 9 usb-ohci.c: usb-00:03.1, Silicon Integrated Systems [siS] USB 1.0 Controller (#2) usb.c: new USB bus registered, assigned bus number 2 hub.c: USB hub found hub.c: 2 ports detected usb-ohci.c: USB OHCI at membase 0xe0a6f000, IRQ 9 usb-ohci.c: usb-00:03.2, Silicon Integrated Systems [siS] USB 1.0 Controller (#3) usb.c: new USB bus registered, assigned bus number 3 hub.c: USB hub found hub.c: 2 ports detected 8139too Fast Ethernet driver 0.9.26 eth0: RealTek RTL8139 at 0x8000, 00:10:a7:13:10:b5, IRQ 11 eth0: Identified 8139 chip type 'RTL-8139C' hub.c: new USB device 00:03.1-1, assigned address 2 usb.c: USB device 2 (vend/prod 0xd7d/0x100) is not claimed by any active driver.NVRM: loading NVIDIA Linux x86 NVIDIA Kernel Module 1.0-6111 Tue Jul 27 07:55:38 PDT 2004 8139cp: 10/100 PCI Ethernet driver v1.1 (Aug 30, 2003) ohci1394: $Rev: 1045 $ Ben Collins <[email protected]> ohci1394_0: Unexpected PCI resource length of 1000! ohci1394_0: OHCI-1394 1.1 (PCI): IRQ=[5] MMIO=[e3800000-e38007ff] Max Packet=[2048] ehci_hcd 00:03.3: Silicon Integrated Systems [siS] USB 2.0 Controller ehci_hcd 00:03.3: irq 9, pci mem e0f18000 usb.c: new USB bus registered, assigned bus number 4 PCI: cache line size of 128 is not supported by device 00:03.3 ehci_hcd 00:03.3: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4 hub.c: USB hub found hub.c: 6 ports detected usb.c: USB disconnect on device 00:03.1-1 address 2 ieee1394: ConfigROM quadlet transaction error for node 0-00:1023 ieee1394: Host added: ID:BUS[0-01:1023] GUID[00004c0107003661] hub.c: new USB device 00:03.1-1, assigned address 3 usb.c: USB device 3 (vend/prod 0xd7d/0x100) is not claimed by any active driver.eth0: link up, 100Mbps, full-duplex, lpa 0x41E1 Initializing USB Mass Storage driver... usb.c: registered new driver usb-storage scsi1 : SCSI emulation for USB Mass Storage devices Vendor: Model: USB DISK Rev: 2.08 Type: Direct-Access ANSI SCSI revision: 02 Attached scsi removable disk sda at scsi1, channel 0, id 0, lun 0 SCSI device sda: 128000 512-byte hdwr sectors (66 MB) sda: Write Protect is on /dev/scsi/host1/bus0/target0/lun0: p1 p2 p3 p4 WARNING: USB Mass Storage data integrity not assured USB Mass Storage device found at 3 USB Mass Storage support registered. Linux agpgart interface v0.99 © Jeff Hartmann agpgart: Maximum main memory to use for agp memory: 439M agpgart: Detected SiS 648 chipset agpgart: AGP aperture is 64M @ 0xe8000000 NVRM: AGPGART: unable to set MTRR write-combining NVRM: not using NVAGP, AGPGART is loaded!! NVRM: AGPGART: unable to set MTRR write-combining NVRM: not using NVAGP, AGPGART is loaded!! Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 Pinlig, tror ikke Firewiredisken var på når jeg kjørte dmesg sist Men Jeg ble da ikke klokere av den nye dmesg'en Freeing initrd memory: 3832k freed VFS: Mounted root (cramfs filesystem). Freeing unused kernel memory: 100k freed NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4 ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx ide: late registration of driver. SIS5513: IDE controller at PCI slot 00:02.5 SIS5513: chipset revision 0 SIS5513: not 100% native mode: will probe irqs later SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller ide0: BM-DMA at 0xb400-0xb407, BIOS settings: hda:DMA, hdb:pio ide1: BM-DMA at 0xb408-0xb40f, BIOS settings: hdc:DMA, hdd:DMA hda: ST380023A, ATA DISK drive blk: queue e08273a0, I/O limit 4095Mb (mask 0xffffffff) hdc: MSI CD-RW MS-8348, ATAPI CD/DVD-ROM drive hdd: ATAPI DVD-ROM 16XMax, ATAPI CD/DVD-ROM drive ide0 at 0x1f0-0x1f7,0x3f6 on irq 14 ide1 at 0x170-0x177,0x376 on irq 15 hda: attached ide-disk driver. hda: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=155061/16/63, UDMA(100) Partition check: /dev/ide/host0/bus0/target0/lun0: [PTBL] [9729/255/63] p1 p2 p3 p4 Journalled Block Device driver loaded VFS: Can't find ext3 filesystem on dev ide0(3,2). VFS: Can't find ext2 filesystem on dev ide0(3,2). Unable to identify CD-ROM format. FAT: bogus logical sector size 0 VFS: Can't find a valid FAT filesystem on dev 03:02. reiserfs: found format "3.6" with standard journal reiserfs: checking transaction log (device ide0(3,2)) ... for (ide0(3,2)) ide0(3,2):Using r5 hash to sort names VFS: Can't find ext3 filesystem on dev ide0(3,2). VFS: Can't find ext2 filesystem on dev ide0(3,2). Unable to identify CD-ROM format. FAT: bogus logical sector size 0 VFS: Can't find a valid FAT filesystem on dev 03:02. reiserfs: found format "3.6" with standard journal reiserfs: checking transaction log (device ide0(3,2)) ... for (ide0(3,2)) ide0(3,2):Using r5 hash to sort names Adding Swap: 979916k swap-space (priority -1) SCSI subsystem driver Revision: 1.00 hdc: attached ide-scsi driver. hdd: attached ide-scsi driver. scsi0 : SCSI host adapter emulation for IDE ATAPI devices Vendor: MSI Model: CD-RW MS-8348 Rev: 150D Type: CD-ROM ANSI SCSI revision: 02 Vendor: ATAPI Model: DVD-ROM 16XMax Rev: 1.00 Type: CD-ROM ANSI SCSI revision: 02 kjournald starting. Commit interval 5 seconds EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,4), internal journal EXT3-fs: mounted filesystem with ordered data mode. Consumer PCM code does not work well at the moment --jk usb.c: registered new driver usbdevfs usb.c: registered new driver hub usb-ohci.c: USB OHCI at membase 0xe0a6b000, IRQ 9 usb-ohci.c: usb-00:03.0, Silicon Integrated Systems [siS] USB 1.0 Controller usb.c: new USB bus registered, assigned bus number 1 hub.c: USB hub found hub.c: 2 ports detected usb-ohci.c: USB OHCI at membase 0xe0a6d000, IRQ 9 usb-ohci.c: usb-00:03.1, Silicon Integrated Systems [siS] USB 1.0 Controller (#2) usb.c: new USB bus registered, assigned bus number 2 hub.c: USB hub found hub.c: 2 ports detected usb-ohci.c: USB OHCI at membase 0xe0a6f000, IRQ 9 usb-ohci.c: usb-00:03.2, Silicon Integrated Systems [siS] USB 1.0 Controller (#3) usb.c: new USB bus registered, assigned bus number 3 hub.c: USB hub found hub.c: 2 ports detected 8139too Fast Ethernet driver 0.9.26 eth0: RealTek RTL8139 at 0x8000, 00:10:a7:13:10:b5, IRQ 11 eth0: Identified 8139 chip type 'RTL-8139C' hub.c: new USB device 00:03.1-1, assigned address 2 usb.c: USB device 2 (vend/prod 0xd7d/0x100) is not claimed by any active driver.NVRM: loading NVIDIA Linux x86 NVIDIA Kernel Module 1.0-6111 Tue Jul 27 07:55:38 PDT 2004 8139cp: 10/100 PCI Ethernet driver v1.1 (Aug 30, 2003) ohci1394: $Rev: 1045 $ Ben Collins <[email protected]> ohci1394_0: Unexpected PCI resource length of 1000! ohci1394_0: OHCI-1394 1.1 (PCI): IRQ=[5] MMIO=[e3800000-e38007ff] Max Packet=[2048] ehci_hcd 00:03.3: Silicon Integrated Systems [siS] USB 2.0 Controller ehci_hcd 00:03.3: irq 9, pci mem e0f18000 usb.c: new USB bus registered, assigned bus number 4 PCI: cache line size of 128 is not supported by device 00:03.3 ehci_hcd 00:03.3: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4 hub.c: USB hub found hub.c: 6 ports detected ieee1394: Node added: ID:BUS[0-00:1023] GUID[0010b920008a1625] ieee1394: Host added: ID:BUS[0-01:1023] GUID[00004c0107003661] usb.c: USB disconnect on device 00:03.1-1 address 2 sbp2: $Rev: 1074 $ Ben Collins <[email protected]> scsi1 : SCSI emulation for IEEE-1394 SBP-2 Devices hub.c: new USB device 00:03.1-1, assigned address 3 usb.c: USB device 3 (vend/prod 0xd7d/0x100) is not claimed by any active driver.ieee1394: sbp2: Logged into SBP-2 device ieee1394: sbp2: Node 0-00:1023: Max speed [s400] - Max payload [2048] eth0: link up, 100Mbps, full-duplex, lpa 0x41E1 Initializing USB Mass Storage driver... usb.c: registered new driver usb-storage scsi2 : SCSI emulation for USB Mass Storage devices Vendor: Model: USB DISK Rev: 2.08 Type: Direct-Access ANSI SCSI revision: 02 Attached scsi removable disk sda at scsi2, channel 0, id 0, lun 0 SCSI device sda: 128000 512-byte hdwr sectors (66 MB) sda: Write Protect is on /dev/scsi/host2/bus0/target0/lun0: p1 p2 p3 p4 WARNING: USB Mass Storage data integrity not assured USB Mass Storage device found at 3 USB Mass Storage support registered. Linux agpgart interface v0.99 © Jeff Hartmann agpgart: Maximum main memory to use for agp memory: 439M agpgart: Detected SiS 648 chipset agpgart: AGP aperture is 64M @ 0xe8000000 NVRM: AGPGART: unable to set MTRR write-combining NVRM: not using NVAGP, AGPGART is loaded!! NVRM: AGPGART: unable to set MTRR write-combining NVRM: not using NVAGP, AGPGART is loaded!! Lenke til kommentar
objorkum Skrevet 4. november 2004 Del Skrevet 4. november 2004 Om USB pennen er på /dev/sda1 er vel den kanskje på /dev/sda2? Lenke til kommentar
mysjkin Skrevet 4. november 2004 Del Skrevet 4. november 2004 Åpne en terminal (som root) og skriv tail -f /var/log/messages og koble så disken til. Da bør du se om det skjer noe og forhåpentligvis få et hint om hvor den havner. Drep tail'en med Ctrl-C når du ikke trenger den mer. Dersom det ikke kommer noe i messages når du plugger, kan det være værdt å ta en tilsvarende titt på /var/log/kernel*, evt ta en ls -l /var/log for å se om det skjer noe med noen av filene der. Dersom det ikke skjer noe, tyder det på at du mangler noe drivere for fw. Lykke til! M. Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 Objorkum: Nei Usb penen er mountet fra /dev/sda, den har ikke flere partisjoner, tror det er derfor det ikke er noe nummer etter. Zyp: fdisk -l ga ingen tilbakemelding og havnet tilbake til kommandolinjen. Mysjkin: Her er resultatet fra tail -f /var/log/messages: Nov 4 08:27:21 Oda ieee1394.agent[1279]: ... no drivers for IEEE1394 product 0x000000/0x0010b9/0xceb001 Nov 4 08:27:22 Oda kernel: ieee1394: sbp2: Logged into SBP-2 device Nov 4 08:27:22 Oda ieee1394.agent[1289]: sbp2: already loaded Så, ingen drivere for profuktet, nyttig. Fant nettopp et verktøy som heter gscanbus. Kjørte den og fikk: This probably means that you don't have raw1394 support in the kernel or that you haven't loaded the raw1394 module. Kjørte som root modprobe raw1394, og så gscanbus, fant firewire-disken Så gjenstår å finne hvor den befinner seg, som desverre ikke scanbus kunne si meg, prøvde /dev/sdb1, men var ikke valid blockdevice. Noen som har råd? Må også finne ut av hvor jeg putter den modulen så den loader ved oppstart, kjører Demudi, som er en "Debian Sarge (testing) for musikere". Takker for hjelp, føler jeg er nesten i mål, men nesten er ikke helt godt nok her. Lenke til kommentar
gspr Skrevet 4. november 2004 Del Skrevet 4. november 2004 Nov 4 08:27:22 Oda kernel: ieee1394: sbp2: Logged into SBP-2 deviceNov 4 08:27:22 Oda ieee1394.agent[1289]: sbp2: already loaded Er det kanskje en dev som heter sbp2? Snålt navn, men... Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 Nei, desverre Lenke til kommentar
mysjkin Skrevet 4. november 2004 Del Skrevet 4. november 2004 Er disken formatert? Hvis du har brukt den på windoes er det sannsynligvis fat-filsystem, har du tatt med swich for det på mount? Hvis den ikke er formatert, kan du jo prøve med en fdisk /dev/sdb, jeg trodde også den skulle dukke opp som en SCSI-disk. Må også finne ut av hvor jeg putter den modulen så den loader ved oppstart, kjører Demudi, som er en "Debian Sarge (testing) for musikere". se på /etc/modules (eller noe slikt, en fil i /etc som heter noe med module) når du ser kommentarene i toppen på den, vet du at det er den riktige. Forresten, jeg driver også å kikker litt på Demundi, hadde en del trøbbel med drop-outs ved opptak (arecord fra et m-audio 2496) med demundis 2.4.2x-multimedia kjerne, gikk uten problemer da jeg oppdaterte til en 'stock' debian 2.6.8 (men så er maskinen jeg bruker ikke av de raskeste....) M. Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 Den er formatert til fat32 og prøver å mounte den med -t vfat. Forøvrig to partisjoner på den. se på /etc/modules (eller noe slikt, en fil i /etc som heter noe med module) når du ser kommentarene i toppen på den, vet du at det er den riktige. wink.gif Putta den i /etc/modules jeg. Takker. Angående dropouts ved opptak. Har ikke prøvd opptak enda, så kan vel si lite om det. Men flott å vite at en oppdatering av kjerne kan fikse det. Har lekt meg litt med Hydrogen da, og må si at siste utgave er veldig imponerende. Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 (endret) Kjørte tail -f /var/log/messages, igjen, og koblet til Firewire, fikk: Nov 4 09:56:07 Oda ieee1394.agent[1554]: ... no drivers for IEEE1394 product 0x000000/0x0010b9/0xceb001 Nov 4 09:56:08 Oda kernel: ieee1394: sbp2: Logged into SBP-2 device Nov 4 09:56:08 Oda ieee1394.agent[1564]: sbp2: already loaded Så det er tydeligvis fortsatt et driverproblem. Sjekket at raw1394 virkelig var loada med lsmod, det var den. Brukte forøvrig samme disken på forrige Linux-system, Vidalinux, der mounta den fint på /dev/sda1 (hadde da ikke usb-pen på /dev/sda). Endret 4. november 2004 av qemilo Lenke til kommentar
JBlack Skrevet 4. november 2004 Del Skrevet 4. november 2004 Så gjenstår å finne hvor den befinner seg, som desverre ikke scanbus kunne si meg, prøvde /dev/sdb1, men var ikke valid blockdevice. Noen som har råd? fdisk -l som root Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 Ingen reaksjon: Oda:/home/ol# fdisk -l Oda:/home/ol# Lenke til kommentar
JBlack Skrevet 4. november 2004 Del Skrevet 4. november 2004 Ingen reaksjon:Oda:/home/ol# fdisk -l Oda:/home/ol# Veldig merkelig. Du burde få listet opp alle disker og partisjoner. Du kan prøve det samme med: sfdisk -l Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 sfdisk ga samme minimale reaksjon. Så ikke vet jeg Lenke til kommentar
JBlack Skrevet 4. november 2004 Del Skrevet 4. november 2004 (endret) Nei, da veit ikke jeg heller. Edit: /dev/sda1 og /dev/sda2 er ganske normalt. (Om du har extended partition så blir det /dev/sda5 eller høyere) Om du har flere enheter vil de normalt bli /dev/sdb1, /dev/sdc osv. Du må muligens modprobe noen andre moduler også, for eksempel ide-scsi. Endret 4. november 2004 av JBlack Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 Ja, går ut ifra at, når ting er i orden, skal partisjonene på fw-disken dukke opp på henholdsvis sdb1 og sdb2, siden sda er opptatt. I håp om at noen kan se en løsning poster jeg lsmod og dmesg. lsmod: Module Size Used by Tainted: P snd-seq-midi 3968 0 (autoclean) (unused) snd-seq-oss 31584 0 (autoclean) (unused) snd-seq-midi-event 3680 0 (autoclean) [snd-seq-midi snd-seq-oss] snd-seq 42192 5 (autoclean) [snd-seq-midi snd-seq-oss snd-seq-midi-event] agpgart 39972 0 (autoclean) af_packet 13896 1 (autoclean) usb-storage 59488 0 (unused) sbp2 16308 0 (unused) ehci-hcd 16172 0 (unused) ohci1394 23024 0 (unused) nvidia 4588300 6 8139too 13896 1 mii 2096 0 [8139too] crc32 2864 0 [8139too] usb-ohci 17320 0 (unused) usbcore 56684 1 [usb-storage ehci-hcd usb-ohci] snd-ice1712 46372 0 snd-pcm-oss 39784 0 (unused) snd-mixer-oss 14168 0 [snd-pcm-oss] snd-pcm 65760 0 [snd-ice1712 snd-pcm-oss] snd-timer 17092 0 [snd-seq snd-pcm] snd-ac97-codec 57328 0 [snd-ice1712] snd-ice17xx-ak4xxx 1520 0 [snd-ice1712] snd-cs8427 6664 0 [snd-ice1712] snd-i2c 2732 0 [snd-ice1712 snd-cs8427] snd-mpu401-uart 4096 0 [snd-ice1712] snd-rawmidi 14880 0 [snd-seq-midi snd-mpu401-uart] snd-seq-device 4340 0 [snd-seq-midi snd-seq-oss snd-seq snd-rawmidi]snd-ak4xxx-adda 3868 0 [snd-ice1712 snd-ice17xx-ak4xxx] snd 37284 0 [snd-seq-midi snd-seq-oss snd-seq-midi-event snd-seq snd-ice1712 snd-pcm-oss snd-mixer-oss snd-pcm snd-timer snd-ac97-codec snd-cs8427 snd-i2c snd-mpu401-uart snd-rawmidi snd-seq-device snd-ak4xxx-adda] snd-page-alloc 5356 0 [snd-seq-oss snd-seq snd-mixer-oss snd-pcm snd-timer snd-i2c snd-rawmidi snd-seq-device snd] soundcore 3876 8 [snd] nls_cp437 4316 2 (autoclean) raw1394 17944 0 (unused) ieee1394 183556 0 [sbp2 ohci1394 raw1394] ide-scsi 8656 0 sd_mod 10540 0 (unused) scsi_mod 89312 4 [usb-storage sbp2 ide-scsi sd_mod] reiserfs 158128 1 (autoclean) vfat 9196 1 (autoclean) fat 29208 0 (autoclean) [vfat] isofs 23480 0 (autoclean) ext3 71144 1 (autoclean) jbd 40312 1 (autoclean) [ext3] ide-detect 288 0 (autoclean) (unused) sis5513 9968 1 (autoclean) ide-disk 12704 4 (autoclean) ide-core 98268 4 (autoclean) [usb-storage ide-scsi ide-detect sis5513 ide-disk] unix 16236 34 (autoclean) dmesg: VFS: Mounted root (cramfs filesystem). Freeing unused kernel memory: 100k freed NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4 ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx ide: late registration of driver. SIS5513: IDE controller at PCI slot 00:02.5 SIS5513: chipset revision 0 SIS5513: not 100% native mode: will probe irqs later SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller ide0: BM-DMA at 0xb400-0xb407, BIOS settings: hda:DMA, hdb:pio ide1: BM-DMA at 0xb408-0xb40f, BIOS settings: hdc:DMA, hdd:DMA hda: ST380023A, ATA DISK drive blk: queue e08273a0, I/O limit 4095Mb (mask 0xffffffff) hdc: MSI CD-RW MS-8348, ATAPI CD/DVD-ROM drive hdd: ATAPI DVD-ROM 16XMax, ATAPI CD/DVD-ROM drive ide0 at 0x1f0-0x1f7,0x3f6 on irq 14 ide1 at 0x170-0x177,0x376 on irq 15 hda: attached ide-disk driver. hda: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=155061/16/63, UDMA(100) Partition check: /dev/ide/host0/bus0/target0/lun0: [PTBL] [9729/255/63] p1 p2 p3 p4 Journalled Block Device driver loaded VFS: Can't find ext3 filesystem on dev ide0(3,2). VFS: Can't find ext2 filesystem on dev ide0(3,2). Unable to identify CD-ROM format. FAT: bogus logical sector size 0 VFS: Can't find a valid FAT filesystem on dev 03:02. reiserfs: found format "3.6" with standard journal reiserfs: checking transaction log (device ide0(3,2)) ... for (ide0(3,2)) ide0(3,2):Using r5 hash to sort names VFS: Can't find ext3 filesystem on dev ide0(3,2). VFS: Can't find ext2 filesystem on dev ide0(3,2). Unable to identify CD-ROM format. FAT: bogus logical sector size 0 VFS: Can't find a valid FAT filesystem on dev 03:02. reiserfs: found format "3.6" with standard journal reiserfs: checking transaction log (device ide0(3,2)) ... for (ide0(3,2)) ide0(3,2):Using r5 hash to sort names Adding Swap: 979916k swap-space (priority -1) SCSI subsystem driver Revision: 1.00 hdc: attached ide-scsi driver. hdd: attached ide-scsi driver. scsi0 : SCSI host adapter emulation for IDE ATAPI devices Vendor: MSI Model: CD-RW MS-8348 Rev: 150D Type: CD-ROM ANSI SCSI revision: 02 Vendor: ATAPI Model: DVD-ROM 16XMax Rev: 1.00 Type: CD-ROM ANSI SCSI revision: 02 raw1394: /dev/raw1394 device initialized kjournald starting. Commit interval 5 seconds EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,4), internal journal EXT3-fs: mounted filesystem with ordered data mode. Consumer PCM code does not work well at the moment --jk usb.c: registered new driver usbdevfs usb.c: registered new driver hub usb-ohci.c: USB OHCI at membase 0xe0a9f000, IRQ 9 usb-ohci.c: usb-00:03.0, Silicon Integrated Systems [SiS] USB 1.0 Controller usb.c: new USB bus registered, assigned bus number 1 hub.c: USB hub found hub.c: 2 ports detected usb-ohci.c: USB OHCI at membase 0xe0aa1000, IRQ 9 usb-ohci.c: usb-00:03.1, Silicon Integrated Systems [SiS] USB 1.0 Controller (#2) usb.c: new USB bus registered, assigned bus number 2 hub.c: USB hub found hub.c: 2 ports detected usb-ohci.c: USB OHCI at membase 0xe0aa3000, IRQ 9 usb-ohci.c: usb-00:03.2, Silicon Integrated Systems [SiS] USB 1.0 Controller (#3) usb.c: new USB bus registered, assigned bus number 3 hub.c: USB hub found hub.c: 2 ports detected 8139too Fast Ethernet driver 0.9.26 eth0: RealTek RTL8139 at 0x8000, 00:10:a7:13:10:b5, IRQ 11 eth0: Identified 8139 chip type 'RTL-8139C' hub.c: new USB device 00:03.1-1, assigned address 2 usb.c: USB device 2 (vend/prod 0xd7d/0x100) is not claimed by any active driver.NVRM: loading NVIDIA Linux x86 NVIDIA Kernel Module 1.0-6111 Tue Jul 27 07:55:38 PDT 2004 8139cp: 10/100 PCI Ethernet driver v1.1 (Aug 30, 2003) ohci1394: $Rev: 1045 $ Ben Collins <[email protected]> ohci1394_0: Unexpected PCI resource length of 1000! ohci1394_0: OHCI-1394 1.1 (PCI): IRQ=[5] MMIO=[e3800000-e38007ff] Max Packet=[2048] ehci_hcd 00:03.3: Silicon Integrated Systems [SiS] USB 2.0 Controller ehci_hcd 00:03.3: irq 9, pci mem e0f1e000 usb.c: new USB bus registered, assigned bus number 4 PCI: cache line size of 128 is not supported by device 00:03.3 ehci_hcd 00:03.3: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4 hub.c: USB hub found hub.c: 6 ports detected ieee1394: Node added: ID:BUS[0-00:1023] GUID[0010b920008a1625] ieee1394: Host added: ID:BUS[0-01:1023] GUID[00004c0107003661] usb.c: USB disconnect on device 00:03.1-1 address 2 sbp2: $Rev: 1074 $ Ben Collins <[email protected]> scsi1 : SCSI emulation for IEEE-1394 SBP-2 Devices hub.c: new USB device 00:03.1-1, assigned address 3 usb.c: USB device 3 (vend/prod 0xd7d/0x100) is not claimed by any active driver.ieee1394: sbp2: Logged into SBP-2 device ieee1394: sbp2: Node 0-00:1023: Max speed [S400] - Max payload [2048] eth0: link up, 100Mbps, full-duplex, lpa 0x41E1 Initializing USB Mass Storage driver... usb.c: registered new driver usb-storage scsi2 : SCSI emulation for USB Mass Storage devices Vendor: Model: USB DISK Rev: 2.08 Type: Direct-Access ANSI SCSI revision: 02 Attached scsi removable disk sda at scsi2, channel 0, id 0, lun 0 SCSI device sda: 128000 512-byte hdwr sectors (66 MB) sda: Write Protect is on /dev/scsi/host2/bus0/target0/lun0: p1 p2 p3 p4 WARNING: USB Mass Storage data integrity not assured USB Mass Storage device found at 3 USB Mass Storage support registered. Linux agpgart interface v0.99 (c) Jeff Hartmann agpgart: Maximum main memory to use for agp memory: 439M agpgart: Detected SiS 648 chipset agpgart: AGP aperture is 64M @ 0xe8000000 NVRM: AGPGART: unable to set MTRR write-combining NVRM: not using NVAGP, AGPGART is loaded!! NVRM: AGPGART: unable to set MTRR write-combining NVRM: not using NVAGP, AGPGART is loaded!! Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 Det som er kjempe irriterende/oppløftende er jo at gscanbus tydelig finner den da. Forøvrig en Maxtor disk på ca 200 GB. Lenke til kommentar
objorkum Skrevet 4. november 2004 Del Skrevet 4. november 2004 Kjørte du "fdisk -l" som root da? "cfdisk" er jo en kommando å teste... Lenke til kommentar
qemilo Skrevet 4. november 2004 Forfatter Del Skrevet 4. november 2004 Ja. Cfdisk finner heller ikke noe på de vanlige stedene; sdb, sdd feks. Har ikke funnet noen tilsvarende "fdisk -l" i cfdisk. Lenke til kommentar
