får ikke laget typed dataset
kan noen hjelpe meg
har gjort alt som står i guiden (Microsoft® Visual C++® .NET 2003 Kick Start)
Working with XML is well-supported throughout the .NET Framework. Both Visual Studio and the Base Class Library have a wide variety of tools and methods that are founded on XML. For example, if you right-click in the editor while editing the new file, people.xml, you can choose Create Schema. This will set Visual Studio to work creating an XML schema that matches the sample XML you provided.
After you generate the schema, flip back to the file of XML. You'll notice that Visual Studio edited it to reflect the name and location of the schema. What's more, once a file of XML has an associated schema, you get Intellisense when you edit it. It closes tags as you open them (if you type <member>, it will type </member>) and provides a drop-down menu of the only elements that belong where you are typing.
Once you have a schema, you can use it to generate a very useful class called a typed dataset. This is a class that inherits from the Dataset class in the System::Data sub-namespace (discussed more fully in Chapter 11) and is typically used to hold the results from a query of the database. By default, Visual Studio .NET 2003 generates a typed dataset whenever you generate a schema, and regenerates the typed dataset every time you save the schema.
What good is a typed dataset? It's the definition of a class. An actual instance of that class can hold data from a database (or elsewhere as you'll see shortly) and can then be used as the data source for a control that knows how to display data. A perfect example of such a control is a DataGrid
dette sto i guiden hva er galt?
Det var snodig. Her er hva jeg gjorde:
1. Lager et nytt "Windows Forms Application (.NET)" prosjekt fra "Visual C++ Projects" lista.
2. Høyreklikker på prosjektet i "Solution Explorer" og velger "Add New Item" ->"XML file" (kall den f.eks. "people.xml").
3. Skriv inn det du ønsker i xml-fila, f.eks:
<?xml version="1.0" encoding="utf-8"?>
<people>
<babe>
 <name>Britney Spears</name>
 <age>21</age>
</babe>
<babe>
 <name>Christina Aguilera</name>
 <age>21</age>
</babe>
</people>
4. Høyreklikk i editoren og velg "Create Schema".
5. VS har nå laget tre nye filer: "people.xsd", "people.h" og "people.xsx" hvor "people.h" vel er den du har etterlyst?
Hvis ikke dette fungerer for deg må det være innstallasjonen din som ikke er helt oppegående.
Endret av kjetil7
