Test av Pentium 4 XE 3,46Ghz med 1066Mhz FSB
HKS
Anadtech har testet Intel sin nye Extreme Edition CPU med støtte for 1066Mhz FSB. Ytelsen er ikke så bra som jeg hadde regnet med. Synes Intel får ganske lite ut av å gå fra 800Mhz FSB til 1066Mhz.
De er nok avhengig av raskere DDR2 minne og lavere latency til minnet tror jeg...
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2261&p=1
The move to the 1066MHz FSB is in sharp contrast to the past two FSB bumps that we've seen from Intel. The introduction of the 533MHz FSB back in 2002 yielded up to a 12% gain in gaming performance, and a 3 - 6% gain in individual applications as it was paired with PC1066 RDRAM. Then came the 800MHz migration that showed a 3 - 9% increase in gaming performance, and just under a 12% increase in professional application performance.
