Vis kilde i IE virker ikke.
Quote fra en artikkel jeg fant:
There are many possible causes for this.
If your browser cache is full, View source can fail. To see if this is the case, select Internet Options from ie's Tools menu, click on the General tab, and click on the Delete files button in the Temporary Internet Files pane.
View source can be disabled for a specific browser window if that window is launched via JavaScript. If View source is disabled for all pages, this is not the cause.
View source is always disabled when a page has not finished loading (a clue here would be that File ¦ Save As is also disabled). Again this is probably not the cause.
If notepad.exe is missing from the Windows folder, View source will fail.
View source can fail if the TEMP or TMP environment variable points to a nonexistent folder. Open a command prompt and enter the commands SET TEMP and SET TMP to view the values of these variables.
A Registry setting can restrict the availability of this command. Launch REGEDIT from the Start menu's Run dialog and navigate to HKEY_CURRENT_USER\Software\ Policies\Microsoft\Internet Explorer\ Restrictions. Look in the right-hand pane for a value named NoViewsource. If present with data set to 1, double-click on it and change the data to 0.
A Registry setting may point to the wrong program to invoke for View source. Launch REGEDIT and navigate to HKEY_LOCAL_MACHINE\Software\ Microsoft\Internet Explorer\View source Editor\Editor Name. If this key exists, the data for the default value in the right-hand pane should be the full pathname of notepad, typically C:\windows\notepad.exe. If not, verify the correct location of notepad, double-click on the default value, and correct the data.
A Group Policy setting can disable the View source menu item. From the Start menu's Run dialog, launch GPEDIT.MSC. If this command is unrecognized, a Group Policy setting is not the cause. Otherwise, in the Group Policy Editor, navigate to User Configuration\Administrative Templates\ Windows Components\Internet Explorer \Browser menus. In the right-hand pane find the item View menu: Disable source menu. If it's set to Enabled, change it to Disabled.
note that the Temporary Internet Files problem (the first item) is the most common reason for View source to fail. If that doesn't help, go through these possibilities until the problem is cleared up.
Mye feilinformasjon i den lenken da .
Ingenting om forbedringene i IE under xp-sp2 er nevnt .
Så nettleseren blir like bra som dei andre fordi du må installere en haug med korreksjoner og oppdateringer, og gjerne et par-tre tredjeparts plugins for å få samme tilnærma funksjonalitet?
Neitakk, du. At IE er en dårlig nettleser er et faktum, og å forsvare IE i en slik diskusjon er berre å grave seg lengre ned i ei grøft.
Endret av arve87
Er nok mere enn det som er endret/nytt og det er ikke sinnsykt mye sikkerhets hull i "nye" IE.
Sier ikke noe om hvem som er best , kun at daniels web om ie mangler oppdatert informasjon.
Nytt / Endret i Sp2
Enhanced browsing security
Download, Attachment, and Authenticode Enhancements
Internet Explorer Add-on Management and Crash Detection
Internet Explorer Binary Behaviors Security Setting
Internet Explorer BindToObject Mitigation
Internet Explorer Information Bar
Internet Explorer Using Feature Control Registry Settings with Security Zone Settings
Internet Explorer Feature Control Settings in Group Policy
Internet Explorer UrlAction Security Settings in Group Policy
Internet Explorer Local Machine Zone Lockdown
Internet Explorer MIME Handling Enforcement
Internet Explorer Object Caching
Internet Explorer Pop-up Blocker
Internet Explorer Untrusted Publishers Mitigations
Internet Explorer Window Restrictions
Internet Explorer Zone Elevation Blocks
Internet Explorer Network Protocol Lockdown
Dessuten var det vel et sikkerhetshull rapportert for Opera 21/10:
Secunia melder om at selskapet har funnet en sårbarhet i Opera, som kan utnyttes av ondsinnede nettsteder for å forfalske dialogbokser.
Ingen er perfekt tydligvis.
Endret av syar2003
Korrekt. Ingen er perfekt, men IE er fjernt fra å vere god nok.
Sammenligna med FF og Opera, så vil IE ha null og ingenting å stille opp med.
Ett sikkerhetshull. For IE uten tusenvis av oppdateringer er det kjent en plass mellom 50 og 70 hull.
og var et hull IE ikke hadde.
Hvilket i seg selv er ganske godt gjort :mrgreen:
Spøk til side, da det er et faktum at IE og Opera er bygget opp på vidt forskjellige måter, og ikke deler så mye som en fjert med kode, ja da er det vel ikke så unaturlig at de ikke kommer med idenstiske feil?
Ja alle programmer har sine svakheter, når man har med programmer som har med kommunikasjon å gjøre vil svakheter kunne utnyttes å utgjøre en sikkerhetsrisiko, så klart vet vi at både Opera, FF og andre nettlesere også har sine feil, noen flere enn andre, men de er der, det som er saken med IE er at, særlig når det gjelder nyere versjoner (opp til nå) så har Microsofts strategi med å automatisere handlinger på datamaskinen vert til en stor ulempe, IE er nemlig veldig godt integrert i operativsystemet, og når et slikt program får sikkerhetsfeil vil faren være vesentlig mye større enn om det oppstår en feil på et program som tross alt "bare" viser frem websider, og ikke har kontakt med systemets andre funksjoner.
Det hjelper ikke det spøtt at det er et faktum at IE har intatt en solid ledelse når det gjelder antall kritiske feil, hvilket gjelder i samtlige utgitte versjoner av nettleseren.
Forsvar gjerne det som Microsoft gjør bra, sånn som brukervennlighet etc, men kom ikke her å fortell at IE kan måle seg med alle andre nettlesere, fordi det kan den nemlig IKKE.
