Vil CNPS7000A-Cu passe på Epox 8RDA6+? NB vifta?
Theo343
Jeg har et epox ep8-rda3+ Med den samme viften i kobber. Du må passe på at ingen av kondensatorene treffer festene til viften. Jeg måtte kappe feste, sjekk den samme Zaalman linken. Northbrigde viften må også kappes i. Du må tilpasse det hjørnet som pekker mot cpu vifte.
Endret av eloole
Det er ikke lett å prate med EPoX, har i 5 dager forsøkt å få fornuftige svar. Her er noen av de.. Asia er typisk kundevennlige og USA dont give a f...
<firstname>,
Are these type of fan on the AMD recommended lists. Sound like they are not industry standard, for best result purchase a fan on AMD recommended lists. Thanks
www.amd.com
NOTE: Thank you for your interest in EPoX products and contacting our support department. If you reply ensure to include all previous E-mail text. It will prevent unnecessary delays and guarantee the fastest possible response.
Technical Support Department
EPoX International, Inc.
[email protected]
www.epox.com
Visit the EPoX store for all those hard to find motherboard accessories... BIOS chips, heatsinks, cables, and much more! <https://www.epoxstore.com/>
<<<<Epox Spotlight>>>>
EP-8KDA3+ (NF3 250Gb) <http://www.hothardware.com/viewarticle.cfm?articleid=526>
EP-8HDA5+ (VIA K8T800) <http://www.neoseeker.com/Articles/Hardware/Reviews/epox8hda5plus/index.html>
EP-4PDA5+ (Intel 865PE) <http://www.tweaknews.com/reviews/epox/>
-----Original Message-----
Posted At: Tuesday, November 02
Posted To: EPoX-Support
Conversation: About to buy 8RDA6+ Pro and CPU cooler, but need info.
Subject: SV: About to buy 8RDA6+ Pro and CPU cooler, but need info.
Fra: EPoX Support [mailto:[email protected]]
Til:
Emne: 8RDA6+Pro_INFORMATION_G0341_ need.CPU cooler info_W
Dear sir
The board can not use Zalman CNPS7000B-C cooler . because it is to wide and too low,it will touch the Electric capacity and chipset 's cooler.
The SLK-947-U cooler may be can used,but you must checck the 4 holder wide.
Du må fjerne Ca 1,5 cm av feste på den ene siden. Det andre du må gjøre for og få Northbrigde viften på plass igjen er å kappe litt av det ene hjørnet(på skrå) Jeg brukte en Stanley kniv..
Stemmer, har 8RDA6+ Pro selv og det jeg måtte gjøre var å sage litt av festet på ene siden, og pusse litt av NB-kjøleren. Brukte Dremel.
