stout Skrevet 29. oktober 2004 Del Skrevet 29. oktober 2004 Min .asoundrc (tatt rett fra nettet): pcm.!default { # pcm.!default skal overstyre pcm.default i alsa.conf type plug slave.pcm "dmixer" } pcm.dmixer { type dmix ipc_key 1024 slave { pcm "hw:1,0" period_time 0 period_size 1024 buffer_size 4096 rate 44100 } bindings { 0 0 1 1 } } ctl.dmixer { type hw card 0 } filename: /lib/modules/2.6.8.1-10mdk/kernel/sound/pci/snd-intel8x0.ko.gz author: Jaroslav Kysela <[email protected]> description: Intel 82801AA,82901AB,i810,i820,i830,i840,i845,MX440; SiS 7012; Ali 5455 license: GPL parm: index:Index value for Intel i8x0 soundcard. parm: id:ID string for Intel i8x0 soundcard. parm: enable:Enable Intel i8x0 soundcard. parm: ac97_clock:AC'97 codec clock (0 = auto-detect). parm: ac97_quirk:AC'97 workaround for strange hardware. parm: buggy_irq:Enable workaround for buggy interrupts on some motherboards. parm: joystick:Enable joystick for Intel i8x0 soundcard. parm: mpu_port:MPU401 port # for Intel i8x0 driver. vermagic: 2.6.8.1-10mdk 686 gcc-3.4 depends: gameport,snd-ac97-codec,snd-pcm,snd-page-alloc,snd-mpu401-uart,snd alias: pci:v00008086d00002415sv*sd*bc*sc*i* alias: pci:v00008086d00002425sv*sd*bc*sc*i* alias: pci:v00008086d00002445sv*sd*bc*sc*i* alias: pci:v00008086d00002485sv*sd*bc*sc*i* alias: pci:v00008086d000024C5sv*sd*bc*sc*i* alias: pci:v00008086d000024D5sv*sd*bc*sc*i* alias: pci:v00008086d000025A6sv*sd*bc*sc*i* alias: pci:v00008086d0000266Esv*sd*bc*sc*i* alias: pci:v00008086d00007195sv*sd*bc*sc*i* alias: pci:v00001039d00007012sv*sd*bc*sc*i* alias: pci:v000010DEd000001B1sv*sd*bc*sc*i* alias: pci:v000010DEd0000003Asv*sd*bc*sc*i* alias: pci:v000010DEd0000006Asv*sd*bc*sc*i* alias: pci:v000010DEd00000059sv*sd*bc*sc*i* alias: pci:v000010DEd0000008Asv*sd*bc*sc*i* alias: pci:v000010DEd000000DAsv*sd*bc*sc*i* alias: pci:v000010DEd000000EAsv*sd*bc*sc*i* alias: pci:v00001022d0000746Dsv*sd*bc*sc*i* alias: pci:v00001022d00007445sv*sd*bc*sc*i* alias: pci:v000010B9d00005455sv*sd*bc*sc*i* /usr/share/alsa/alsa.conf er umodifisert. Problemet: Fungerer som det skal ALSA lib pcm_dmix.c:868:(snd_pcm_dmix_open) unable to open slave aplay: main:508: audio open error: No such file or directory Samme som over Det vil si at default ikke blir overstyrt som den skal. Har prøvd å kommentere ut pcm.default i alsa.conf uten hell. Er klar over at man må reboote, det hadde ingen effekt. devfs ser ut til å være installert, må det konfigureres? soundcore er også installert. Lenke til kommentar
drall Skrevet 29. oktober 2004 Del Skrevet 29. oktober 2004 Dette funket fint på et ES1370 kort i vertfall. /etc/asound.conf: pcm.mixer { type dmix ipc_key 1024 slave { pcm "hw:0,0" period_time 0 period_size 1024 buffer_size 8192 rate 44100 } } pcm.!default { type plug slave.pcm "mixer" } Har ikke testet å angi "default" direkte til et program siden det ser ut til å virke av seg selv. Det funker riktig nok bare på program som støtter alsa. Lenke til kommentar
stout Skrevet 30. oktober 2004 Forfatter Del Skrevet 30. oktober 2004 Takk! Ser ut til å fungere som det skal Lenke til kommentar
diskvask Skrevet 30. oktober 2004 Del Skrevet 30. oktober 2004 "rate 44100" - betyr det at all lyd blir resamplet til den frekvensen? Jeg bruker følgende på mitt M-audio sonica theater; pcm.usb-audio { type hw card 0 } ctl.usb-audio { type hw card 0 } Lenke til kommentar
drall Skrevet 30. oktober 2004 Del Skrevet 30. oktober 2004 (endret) "rate 44100" - betyr det at all lyd blir resamplet til den frekvensen? Ja, derfor er det lurt å velge den frekvensen det meste av lydavspillingen på din pc foregår i. Jeg bruker følgende på mitt M-audio sonica theater; pcm.usb-audio { type hw card 0 } ctl.usb-audio { type hw card 0 } Da har du ikke dmix aktivert. Om ikke kortet ditt (med driver) støtter hardware mxing, kan du ikke spille av flere lyder samtidig uten software mixere som arts, esd, dmix etc. Dmix er den eneste av disse som fungerer automatisk på all alsa-lyd. Endret 30. oktober 2004 av drall Lenke til kommentar
