Den store Slackware 10.1-guiden
Skriv pkgtool
Du får nå opp mange valg. Gå ned til setup og trykk enter.
Du får nå opp en del valg. gå helt ned til xwmconfig. Trykk space og enter.
Nå får du opp en liste over alle GUI'er du har å velge mellom. Velg KDE og trykk enter
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
boot = /dev/sda
#compact        # faster, but won't work on all systems.
prompt
timeout = 300
# VESA framebuffer console @ 1024x768x64k
vga = 791
# Normal VGA console
# vga = normal
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# VESA framebuffer console @ 1024x768x256
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
# ramdisk = 0     # paranoia setting
# End LILO global section
# Linux bootable partition config begins
image="/boot/vmlinuz"
root="/dev/sda3"
label="Linux"
 read-only # Non-UMSDOS filesystems should be mounted read-only for checking
# Linux bootable partition config ends
# Windows bootable partition config begins
other = /dev/sda1
 label = Windows
 table = /dev/sda
# Windows bootable partition config ends
