Forskjell på XP pro og home, og OEM
Hva er det med HW.no? Hvorfor svarer alltid folk på helt andre ting enn det man spør om?
Mannen spør om hva forskjellen på Home, Pro og OEM er, ikke om han bør oppgradere! :thumbdown:
Forskjellen på Home og Pro er bl.a. at Home mangler en god del av nettverksstøtten Pro har, samt at Home ikke støtter flerCPU. Pro støtter opptil to.
Du kan lese mer her.
OEM betyr at det er en lisens som kun kan kjøpes sammen med maskinvare.
-KJ
Endret av jevel
A. With Windows XP, the two Windows OS lines merge, so we'll no longer have Windows 2000/Windows NT and Windows Me/Windows 98—just Windows XP. However, we still have two different types of users: the office user and the basic home user with one machine. Hence the two versions of Windows XP: Windows XP Professional Edition, for those accustomed to Win2K Professional/NT Workstation, and Windows XP Home Edition, for those accustomed to Windows Me/Win98.
Although the XP Pro and Home Editions share the same common core code, they don't have the same features. The right version for you depends on the functionality you need. Think of XP Pro as a superset of XP Home. Below is a short list of supported features:
    * Backup—XP Pro has the standard Win2K backup program; XP Home has no backup program.
    * Dynamic Disks—XP Pro supports dynamic disks; XP Home doesn't.
    * IIS—XP Pro includes IIS; XP Home doesn't.
    * Encrypted File System (EFS)—EFS debuted in Win2K and lets you encrypt files on an NTFS partition, a very useful feature for mobile machines. XP Pro includes EFS; XP Home doesn't.
    * Multiple Monitors—XP Pro supports up to nine monitors; XP Home supports only one monitor (Windows Me/Win98 supported multiple monitors).
    * Multiprocessor—XP Pro supports up to two processors; XP Home supports only one (as did Windows Me/Win98).
    * Remote Assistance—Both editions support Remote Assistance, which lets someone from a Help desk connect to the client desktop to troubleshoot problems.
    * Remote Desktop—XP Pro adds to Remote Assistance by letting any machine running a Terminal Services client run one Terminal Services session against an XP Pro machine.
    * Domain Membership—XP Pro systems can be domain members; XP Home systems can't, but they can access domain resources.
    * Group Policy—XP Pro supports group policies; XP Home doesn't.
    * IntelliMirror—XP Pro supports IntelliMirror, which includes Microsoft Remote Installation Services (RIS), software deployment, and user setting management; XP Home doesn't support IntelliMirror.
    * Upgrade from Windows Me/Win98—Both XP Pro and XP Home support this upgrade.
    * Upgrade from Win2K/NT—Only XP Pro supports this upgrade.
    * 64-bit Support—Only XP Pro will have a 64-bit version that supports the Itanium systems.
    * Network Support—XP Pro includes support for Network Monitor, SNMP, IP Security (IPSec), and the Client Services for NetWare (CSNW); XP Home doesn't.
Engelsk :hmm:
pro skal også være mer stabilt enn home, ikke det at noen av de er særlig stabile da :p
Offtopic:
De er nok kanske like når det gjelder stabilitet.Det du sier at de ikke er noe særlig stabile stemmer ikke helt dersom maskinvaren din er i orden og at dine pc kunnskaper er middels.Har selv+andre jeg snakker med ikke problemer med at os'et er ustabilt.
Er du uenig håper jeg du kan begrunne det.
Offtopic:
nei, kan ikke begrunne dette med annet enn at det krasjer alt for ofte
Hva er forskjellen på XP Pro og Home utgaven?
Noen lisenser er med OEM hva betyr dette?
Er det slik at XP krever mer maskin en Windows 2000 Pro slik at det beste var ikke å skifte operativsystem?
Her er en fin oversikt på forskjellen mellom Home og Professional; http://www.winsupersite.com/showcase/windowsxp_home_pro.asp
OEM er en versjon hvor det kreves at du kjøper ved noe hardware (f.eks. en mus til 70,-), og hvor du ikke får med en skikkelig manual. Et tips er å godprate litt med selger, så slipper du kanskje og kjøpe hardware ved siden av også.
Endret av mabbutt
Feil. OEM-lisenser er ment for levering sammen med nye PC-er. Microsoft definerer en PC som "ny" hvis du kjøper enten nytt hovedkort, ny CPU eller ny HD. Altså: en gyldig OEM-lisens selges sammen med en av disse tingene. Men det er sikkert butikker som tar rennefart og driter i dette...
Jeg gir meg. Du har rett, men jeg tror butikker gir blaffen i dette nå. Jeg fikk XP Home Engelsk for OEM pris, og slapp å kjøpe noe ved siden av :)
Gratulerer! AKKURAT det samme som ble postet over, bare litt feiltolket og noen timer seinere.
-KJ
Skal ha ny maskin med 19" lcd, amd socket 939, og muligens over til XP pro fra W2K men har ingen erfaring med XP så derfor greit å vite om det er verdt oppgraderingen. Akkurat nå kjører jeg en gammel AMD 2000 XP med noen CRT bokser i 1024 * 786.
Endret av Neotetra
