3dmark2001SE problemer..
heisann.
Jeg skulle kjøre 3dmark igjen i går.. det gikk helt fint før, men nå fikk jeg denne erroren!
jeg paster lik så godt hele greia.
sorry om det er litt mye, men da har dere i alle fall all infoen dere trenger for å si om det er no feil...
Application info
Name 3DMark2001 SE
Build 300
Error log
Could not create render target depth-stencil surface - D3DERR_INVALIDCALL
System info available: yes
Project available: yes
Result file
3DMARK2001 PROJECT FILE
PROJECT
Name My Benchmark
Description
Registration Name
Registration Key
3DMark Version 300
DISPLAY
Platform 3D Prophet FDX 8500 LE
CPU Optimization D3D Pure Hardware T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Double
Refresh Rate 60 Hz
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score N/A
Game 1 - Car Chase - Low Detail N/A
Game 1 - Car Chase - High Detail N/A
Game 2 - Dragothic - Low Detail N/A
Game 2 - Dragothic - High Detail N/A
Game 3 - Lobby - Low Detail N/A
Game 3 - Lobby - High Detail N/A
Game 4 - Nature N/A
Fill Rate (Single-Texturing) N/A
Fill Rate (Multi-Texturing) N/A
High Polygon Count (1 Light) N/A
High Polygon Count (8 Lights) N/A
Environment Bump Mapping N/A
DOT3 Bump Mapping N/A
Vertex Shader N/A
Pixel Shader 71.8 fps
Advanced Pixel Shader N/A
Point Sprites N/A
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family Athlon
Internal Clock 1.17 GHz
Internal Clock Maximum 1.17 GHz
External Clock 100 MHz
Socket Designation Slot A
Type <unknown>
Upgrade Slot 1
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!
Version AMD Athlon
CPUID 0x00000642
CACHES
Level 1
Capacity 32 KB
Type Internal
Type Details Synchronous
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 256 KB
Type External
DIRECTX INFO
DirectX Version 8.1
DIRECTDRAW INFO
DirectDraw Version 5.1.2600.881
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer Hercules Technologies
Name 3D Prophet FDX 8500 LE
Total Local Video Memory 64 MB
Total Local Texture Memory 64 MB
Total AGP Memory 24 MB
Display Driver ati2dvag.dll
Display Driver Version 5.13.01.6025
Driver WHQL Certified No
Max Texture Width 2048
Max Texture Height 2048
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 6
Vertex Shader Version 1.1
Pixel Shader Version 1.4
Max Vertex Blend Matrices 57
Max Texture Coordinates 6
Vendor ID 0x1002
Device ID 0x514c
Sub-System ID 0x00001681
Revision 0x00
DISPLAY MODES
Resolution 320x200x16-bit RGB [565] @ 60 Hz
Resolution 320x200x16-bit RGB [565] @ 75 Hz
Resolution 320x200x32-bit RGB [888] @ 60 Hz
Resolution 320x200x32-bit RGB [888] @ 75 Hz
Resolution 320x240x16-bit RGB [565] @ 60 Hz
Resolution 320x240x16-bit RGB [565] @ 75 Hz
Resolution 320x240x32-bit RGB [888] @ 60 Hz
Resolution 320x240x32-bit RGB [888] @ 75 Hz
Resolution 400x300x16-bit RGB [565] @ 60 Hz
Resolution 400x300x16-bit RGB [565] @ 75 Hz
Resolution 400x300x32-bit RGB [888] @ 60 Hz
Resolution 400x300x32-bit RGB [888] @ 75 Hz
Resolution 512x384x16-bit RGB [565] @ 60 Hz
Resolution 512x384x16-bit RGB [565] @ 75 Hz
Resolution 512x384x32-bit RGB [888] @ 60 Hz
Resolution 512x384x32-bit RGB [888] @ 75 Hz
Resolution 640x400x16-bit RGB [565] @ 60 Hz
Resolution 640x400x16-bit RGB [565] @ 75 Hz
Resolution 640x400x32-bit RGB [888] @ 60 Hz
Resolution 640x400x32-bit RGB [888] @ 75 Hz
Resolution 640x480x16-bit RGB [565] @ 60 Hz
Resolution 640x480x16-bit RGB [565] @ 72 Hz
Resolution 640x480x16-bit RGB [565] @ 75 Hz
Resolution 640x480x16-bit RGB [565] @ 85 Hz
Resolution 640x480x16-bit RGB [565] @ 90 Hz
Resolution 640x480x16-bit RGB [565] @ 100 Hz
Resolution 640x480x32-bit RGB [888] @ 60 Hz
Resolution 640x480x32-bit RGB [888] @ 72 Hz
Resolution 640x480x32-bit RGB [888] @ 75 Hz
Resolution 640x480x32-bit RGB [888] @ 85 Hz
Resolution 640x480x32-bit RGB [888] @ 90 Hz
Resolution 640x480x32-bit RGB [888] @ 100 Hz
Resolution 800x600x16-bit RGB [565] @ 56 Hz
Resolution 800x600x16-bit RGB [565] @ 60 Hz
Resolution 800x600x16-bit RGB [565] @ 70 Hz
Resolution 800x600x16-bit RGB [565] @ 72 Hz
Resolution 800x600x16-bit RGB [565] @ 75 Hz
Resolution 800x600x16-bit RGB [565] @ 85 Hz
Resolution 800x600x16-bit RGB [565] @ 90 Hz
Resolution 800x600x16-bit RGB [565] @ 100 Hz
Resolution 800x600x32-bit RGB [888] @ 56 Hz
Resolution 800x600x32-bit RGB [888] @ 60 Hz
Resolution 800x600x32-bit RGB [888] @ 70 Hz
Resolution 800x600x32-bit RGB [888] @ 72 Hz
Resolution 800x600x32-bit RGB [888] @ 75 Hz
Resolution 800x600x32-bit RGB [888] @ 85 Hz
Resolution 800x600x32-bit RGB [888] @ 90 Hz
Resolution 800x600x32-bit RGB [888] @ 100 Hz
Resolution 1024x768x16-bit RGB [565] @ 60 Hz
Resolution 1024x768x16-bit RGB [565] @ 70 Hz
Resolution 1024x768x16-bit RGB [565] @ 72 Hz
Resolution 1024x768x16-bit RGB [565] @ 75 Hz
Resolution 1024x768x16-bit RGB [565] @ 85 Hz
Resolution 1024x768x16-bit RGB [565] @ 90 Hz
Resolution 1024x768x16-bit RGB [565] @ 100 Hz
Resolution 1024x768x32-bit RGB [888] @ 60 Hz
Resolution 1024x768x32-bit RGB [888] @ 70 Hz
Resolution 1024x768x32-bit RGB [888] @ 72 Hz
Resolution 1024x768x32-bit RGB [888] @ 75 Hz
Resolution 1024x768x32-bit RGB [888] @ 85 Hz
Resolution 1024x768x32-bit RGB [888] @ 90 Hz
Resolution 1024x768x32-bit RGB [888] @ 100 Hz
Resolution 1152x864x16-bit RGB [565] @ 60 Hz
Resolution 1152x864x16-bit RGB [565] @ 70 Hz
Resolution 1152x864x16-bit RGB [565] @ 75 Hz
Resolution 1152x864x16-bit RGB [565] @ 85 Hz
Resolution 1152x864x32-bit RGB [888] @ 60 Hz
Resolution 1152x864x32-bit RGB [888] @ 70 Hz
Resolution 1152x864x32-bit RGB [888] @ 75 Hz
Resolution 1152x864x32-bit RGB [888] @ 85 Hz
Resolution 1280x768x16-bit RGB [565] @ 56 Hz
Resolution 1280x768x16-bit RGB [565] @ 60 Hz
Resolution 1280x768x16-bit RGB [565] @ 75 Hz
Resolution 1280x768x16-bit RGB [565] @ 85 Hz
Resolution 1280x768x32-bit RGB [888] @ 56 Hz
Resolution 1280x768x32-bit RGB [888] @ 60 Hz
Resolution 1280x768x32-bit RGB [888] @ 75 Hz
Resolution 1280x768x32-bit RGB [888] @ 85 Hz
Resolution 1280x1024x16-bit RGB [565] @ 60 Hz
Resolution 1280x1024x16-bit RGB [565] @ 70 Hz
Resolution 1280x1024x16-bit RGB [565] @ 75 Hz
Resolution 1280x1024x32-bit RGB [888] @ 60 Hz
Resolution 1280x1024x32-bit RGB [888] @ 70 Hz
Resolution 1280x1024x32-bit RGB [888] @ 75 Hz
TEXTURE FORMATS
Pixel Format 32-bit ARGB [8888]
Pixel Format 32-bit RGB [888]
Pixel Format 16-bit RGB [565]
Pixel Format 16-bit RGB [555]
Pixel Format 16-bit ARGB [1555]
Pixel Format 16-bit ARGB [4444]
Pixel Format 8-bit RGB [332]
Pixel Format 8-bit YUV [800]
Pixel Format 16-bit AYUV [8800]
Pixel Format FourCC [DXT1]
Pixel Format FourCC [DXT2]
Pixel Format FourCC [DXT3]
Pixel Format FourCC [DXT4]
Pixel Format FourCC [DXT5]
3D Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Range Fog, Vertex Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Rendering to a Window, N Patches, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, DXT Compressed Textures
DIRECTSHOW INFO
DirectShow Version 6.03.01.0400
REGISTERED DIRECTSHOW FILTERS
Filter .RAM file Parser
Filter AC3 Parser Filter
Filter ACELP.net Sipro Lab Audio Decoder
Filter ACM Wrapper
Filter ASF ACM Handler
Filter ASF DIB Handler
Filter ASF DJPEG Handler
Filter ASF ICM Handler
Filter ASF JPEG Handler
Filter ASF URL Handler
Filter ASF embedded stuff Handler
Filter ASX file Parser
Filter ASX v.2 file Parser
Filter AVI Decompressor
Filter AVI Draw
Filter AVI Splitter
Filter AVI/WAV File Source
Filter BDA MPEG2 Transport Information Filter
Filter Color Space Converter
Filter DV Muxer
Filter DV Splitter
Filter DV Video Decoder
Filter Default DirectSound Device
Filter Default MidiOut Device
Filter File Source (Async.)
Filter File Source (Netshow URL)
Filter File Source (URL)
Filter File stream renderer
Filter IVF source filter
Filter Indeo® audio software
Filter Indeo® video 5.10 Decompression Filter
Filter Internal Script Command Renderer
Filter Line 21 Decoder
Filter Lyric Parser
Filter MIDI Parser
Filter MJPEG Decompressor
Filter MPEG Audio Decoder
Filter MPEG Layer-3 Decoder
Filter MPEG Video Decoder
Filter MPEG-2 Demultiplexer
Filter MPEG-2 Splitter
Filter MPEG-I Stream Splitter
Filter Microsoft MPEG-4 Video Decompressor
Filter Multi-file Parser
Filter NSC file Parser
Filter Overlay Mixer2
Filter QT Decompressor
Filter QuickTime Movie Parser
Filter SAMI (CC) Parser
Filter VBI Surface Allocator
Filter VGA 16 Color Ditherer
Filter Video Renderer
Filter WM ASF Reader
Filter WM ASF Writer
Filter WST Decoder
Filter Wave Parser
Filter Windows Media Audio Decoder
Filter Windows Media Multiplexer
Filter Windows Media Update Filter
Filter Windows Media source filter
Filter XML Playlist
MEMORY INFO
Total Physical Memory 256 MB
Free Physical Memory 174.27 MB
Total Pagefile Memory 618.44 MB
Free Pagefile Memory 539.40 MB
MEMORY ARRAYS
Max Module Capacity 512 MB
Location System Board
Use Flash
Supported Error D&C None
Supported Speeds <unknown>
Supported Types <unknown>
Supported Voltages <unknown>
MEMORY SLOTS
Installed & Enabled Size 128 MB
Form Factor DIMM
Frequency 0 Hz
Slot BANK_0 [bank0/1]
Manufacturer
Type <unknown>
Type Details <unknown>
Enabled Size 128 MB
Total Bit Width 0
Data Bit Width 0
Form Factor DIMM
Frequency 0 Hz
Slot BANK_1 [bank2/3]
Manufacturer
Type <unknown>
Enabled Size 128 MB
Total Bit Width 0
Data Bit Width 0
Installed & Enabled Size 0 bytes
Form Factor DIMM
Frequency 0 Hz
Slot BANK_2 [bank4/5]
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
Form Factor DIMM
Frequency 0 Hz
Slot BANK_3 [bank6/7]
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer
Model 8363A-686B
Version N/A
BIOS Vendor Award Software International, Inc.
BIOS Version 6.00 PG
BIOS Release Date 09/06/2001
BIOS Properties Plug and Play, Flash, AGP
CARD SLOTS
Number 0
Designation ISA
Type ISA
Characteristics 5.0V
Data Bus Width 16
Details Long
Device Class <unknown>
Device Name
Device Manufacturer
Device Driver Date
Device Vendor ID 0x0000
Device ID 0x0000
Device Sub-System ID 0x00000000
Device Revision 0x00
IRQ 0
Number 0
Designation ISA
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 0
Designation ISA
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 0
Designation ISA
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 1
Designation PCI
Type PCI
Data Bus Width 32
Details Available, Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 2
Designation PCI
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 3
Designation PCI
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 4
Designation PCI
Type PCI
Data Bus Width 32
Details In Use, Long
Device Class Network Adapter
Device Name Realtek RTL8139(A) PCI Fast Ethernet Adapter
Device Manufacturer Realtek
Device Driver Date
Device Vendor ID 0x10ec
Device ID 0x8139
Device Sub-System ID 0x813910ec
Device Revision 0x10
IRQ 11
Number 0
Designation AGP
Type AGP
Data Bus Width 32
Device Class Display Adapter
Device Name 3D Prophet FDX 8500 LE
Device Manufacturer Hercules Technologies
Device Driver Date
Device Vendor ID 0x1002
Device ID 0x514c
Device Sub-System ID 0x00001681
IRQ 11
SYSTEM DEVICES
Description VIA Standard CPU to PCI Bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x0305
Subsystem ID 0x00000000
Revision 0x03
Description VIA Tech PCI to ISA bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x0686
Revision 0x40
Description VIA Tech Power Management controller
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x3057
Subsystem ID 0x30571106
Revision 0x40
Description VIA CPU to AGP Controller
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x8305
Revision 0x00
Revision 2.0
Rate 1x, 2x, 4x (4x enabled)
Aperture Size 64 MB
Sideband Addressing supported (enabled)
Fast Write not supported
MONITOR INFO
MONITORS
Name Default Monitor
Manufacturer (Standard monitor types)
Max Width 0
Max Height 0
Name Plug and Play Monitor
Max Width 0
Max Height 0
POWER SUPPLY INFO
BATTERIES
OPERATING SYSTEM INFO
Operating System Microsoft Windows 2000
Version 5.0.2195
Service Pack Service Pack 2
Locale NO
Desktop Width 1280
Desktop Height 1024
Desktop BPP 32
HARD DISK INFO
HARD DISKS
Name WDC WD400BB-00CCB0
Manufacturer (Standard disk drives)
Capacity 37.27 GB
Model WDC WD400BB-00CCB0
Interface Type IDE
Jeg har også problem med 3DMark2001 SE.
Har GeForce4 Ti4600.
Hele maskinen henger seg når den kommer til advanced pixel shader (tror jeg). Den med hestene i karusellen.. 2 lights og så 8. Da tilter det helt.
Har prøvd å sende support forespørsel til madonion men har ikke fått svar.
Prøv å se litt på http://www.madonion.com
Kan hende forumet kan gi noen svar.
Den samme feilen fikk jeg også. Den fikset jeg ved å fjerne tweake programmet jeg brukte. Husker ikke hva det het da..
Ikke Radeonator. Det var den andre saken som de som har nvidia kort bruker. *pokker **** ta meg i ræv sprekken!*
Nei, jeg husker ikke hva den heter, men fjern den (slette) og bruk heller et annet tweake program. Jeg bruker den fra Rage3D. Den er genial :smile:
Kan også bruke Radeonator, men jeg vet ikke om den fungerer med kort fra Hercules :/
Prøv å se litt på
Det er ikke advanced pixel shader :smile:
