Dette programmet regner ut kvadratrot:
#include <iostream>
#include <cmath>
using namespace std;
float regn_kvadratrot(float kvadratrot);
int main(int argc, char **argv)
 float kvadratrot;
       cout<<"Tall: ";
       cin>>kvadratrot;
       float svar;
       svar=regn_kvadratrot(kvadratrot);
       cout<<" = "<<svar<<"\n";
       cin.ignore();
       cin.get();
   float svar;
   svar = sqrt(kvadratrot);
   return svar;
#include <stdio.h>
#include <conio.h>
#include <windows.h>
void clearScreen()
// Get the handle to the console which is used for displaying characters
HANDLE consoleHandle = GetStdHandle(STD_OUTPUT_HANDLE);
// Get a handle to the console buffer (the memory which the characters in the console are stored)
CONSOLE_SCREEN_BUFFER_INFO csbi;
if(!GetConsoleScreenBufferInfo(consoleHandle, &csbi))
 return;
// Get the number of character cells in the current buffer.
DWORD dwConSize = csbi.dwSize.X * csbi.dwSize.Y;
// Fill the entire screen with blanks (Space Characters).
DWORD cCharsWritten;
COORD coordScreen = { 0, 0 };    // home for the cursor
if(!FillConsoleOutputCharacter(consoleHandle, (TCHAR) ' ', dwConSize,
coordScreen, &cCharsWritten))
 return;
// Get the current text attribute.
 return;
// Set the buffer's attributes accordingly.
if(!FillConsoleOutputAttribute(consoleHandle, csbi.wAttributes, dwConSize,
 return;
// Put the cursor at its home coordinates.
SetConsoleCursorPosition(consoleHandle, coordScreen);
int main()
// Set the starting number here
long double startingNumber = 0;
//make the user type in a number
printf("Type in a number to calculate square root from:\n");
scanf("%lg", &startingNumber);
// Make a guess on the result, I choose half the starting number since the
// algorithm is based on averages, it's most likely going to work best if you "Average the number with 0"
long double currentIteration = startingNumber / 2;
// This is used to store what the last guess was
long double last = 0;
while(true)  // Keep running until we're done
 // Test to see if the number is the square root of the starting number, if it is, then we're done
 if((currentIteration * currentIteration) == startingNumber) {
 printf("%.20lg is current test for square root of %.20lg\n", currentIteration, startingNumber);
 	break;
 // Divide the starting number by the current guess
 long double quotient = startingNumber / currentIteration;
 // Update the guess to be the average of the old guess and the new guess
 currentIteration = (currentIteration + quotient) / 2;
 // If the current guess is the same as the previous guess, then the guess is no longer changing
 // so there's no need to continue testing
 if(currentIteration == last)
 	break;
 // Store the last value
 last = currentIteration;
// Wait for a key press
_getch();
// Clear the screen
clearScreen();
// Wait for another key press
printf("Press any key to exit...");
_getch();
// Exit
return 0;
Her er den koden jeg bruker for å løse problemet.. Mesteparten går med til en funskjon for å tømme skjermen. :no:
Endret av Tha Phreak
Den vanlige teknikken for å beregne denne typen verdier på kalkulatorer og datamaskiner er vel å bruke et Taylor-polynom som tilnærmer verdien. Lager man et Taylor-polynom med et høyt nok antall ledd kan man finne ganske eksakte verdier for slike tall uten å utføre mer kompliserte regneoperasjoner enn de helt grunnleggende.
Eventuelt kan man lage en rekursiv formel som bruker Newtons metode til å tilnærme verdien. Jeg vet ærlig talt ikke hva som blir enklest.
Endret av Valagar
Jeg laget en egen funksjon for dette for ikke lenge siden,
jeg pastet koden i en post på forumet.
Søk på kvadratrot eller noe her på C++ forumet så finner du den.
Den går ut på å gjette seg oppover, 1, 2, 3, 4 og når den så kommer til et tall som blir høyere, så legger den på desimaler, 2,1-2,2-2,3 og så hundredeler, 2,31-2,32 osv.
(Dårlig forklart men du skjønner det når du ser koden)
Endret av <BøNilzen>
#include <iostream>
#include <cmath>
double const TOLERANCE = 1.0e-7;
double squareRootIter(double n)
 double ret = n / 2;
 do ret = (ret + n / ret) / 2;
 while(abs(ret * ret - n) > TOLERANCE);
 return(ret);
} // squareRootIter
double squareRootRec(double n, double guess = 1)
 // good enough?
 if(!(abs(guess * guess - n) > TOLERANCE))
   return(guess);
 return(squareRootRec(n, ((n / guess) + guess) / 2));
} // squareRootRec
int main()
 double n = 2;
 cout << "The square root of " << n << " is " << squareRootIter(n) << endl;
 cout << "The square root of " << n << " is " << squareRootRec(n) << endl;
 return(0);
} // main
Vet ikke hvor bra dette ble - men ser ut til å fungere.
edit:
http://mitpress.mit.edu/sicp/full-text/boo...tml#%_sec_1.1.7
Endret av søppel
