Fx55 på 2,9 ghz på standard volt og luftkjøling
blackbrrd
Fx55 er visst laget på en litt annen produksjonsteknologi enn de tidligere prosessorene og overklokker svært bra.
http://www.anandtech.com/talkarticle.aspx?...AR_START=41&p=3
44 - Posted on Oct 19, 2004 at 7:55 PM by Wesley Fink Reply
#30 and #43 -
Once AMD informed us that strained silicon was used in the FX55 I couldn't resist a bit of a run with overclocking the FX55. The nForce4 Reference boad is not really intended or designed for overclocking, since it doesn't have any CPU or memory voltage adjustments. However it does support a wide range of multipliers so I could try a few settinngs.
I had no probelm at all running at 14.5X or 2.9GHz at default voltage. At that speed I ran quite a few benchmarks and a Quake 3 of 604.2 FPS. The FX55 actually booted at 3.0GHz but it never made it through a stable XP boot. I suspect with just a bit of CPU voltage 3.0GHz would be possible with the FX55 on air. All cooling was just the new AMD stock fan which now includes copper fins and heat pipes.
Wesley Fink er den som stod bak denne testen:
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2249
Endret av blackbrrd
