Nyeste k700i FW
_THX_
etter det jeg har skjønt, så er R2AA003 den nyeste FW'en som er å få til K700i. Men spørsmålet mitt er om denne ligger ute på oppdateringsservicen til SE sine sider enda????
mvh
_THX_
mvh
_THX_
Nei, og etter det jeg har lest så har den blitt trukket tilbake intill videre pga noen feil de har funnet i den.
Følg med på denne tråden så får du med deg det meste av det som skjer ang. dette.
mvh
_THX_
Thnx m8
Hvor gammel er r2ao41. Kjøpte telefonen for et par uken siden. og de sa at det var siste fw. Saken er at batteriet holder bare halvannet døgn.
Det er første release.. se selv:
Firmware Overview
R2A041
- First release
- JBenchmark 1 - approx 2,640
- JBenchmark 2 - approx 123
- Software versions:
LCD 200404231
Camera 3.9
ITP CXC 125 813 R1S
R2C001
- Released around 30/6/2004
- Ability to mute the shutter sound of the camera
LCD: 200404231
Camera: 3.9
ITP: CXC 125 813 R1T
R2E011
- Released to service points around 14/7/04
- Improved battery (i.e. green (full) to red (empty) is now slower)
- Smoother video playback
- New Bugs
Appointments are no longer marked as bold dates in the month calender. So now you can no longer see on which days you need to do things.
R2J002
- Were available from SE Online Firmware Update (http://www.sonyericsson.com/updateservice/K700/frameset.htm)
- Not released at service centres
LCD 200404231
Camera 3.9
ITP CXC 125 813 R1S
R2J015
- Released to Chinese service centres around 27/7/04.
- LCD 200406041
- Camera 3.9
- ITP CXC 125 813 R1T
New bugs
Ability to mute the shutter sound of the camera taken out
R2J041
- Chinese release (perhaps Chinese version of R2L?)
- Snooze is now available on Recurrent alarms
- At least 10% improvement in battery life (over and above R2E?)
- Time of the last call now displayed in the missed calls list
- The fonts of Operator logo, the command keys such as "Calls", "More" are a bit larger and the font of Date & time has been Slightly reduced.
- Faster loading of JAVA games
R2L001
- 4/8/04
- One second delay before the person at the other end of the phone can hear you when answering a call bug fixed (unless they are associated with a picture?)
- Backlight timings have changed to improve battery life (20s, 26s, 40s to 15s, 20s, 60s - Fade, Backlight off, Display off)
- Pressing a volume control button when in Standby mode displays the time, or the missed call icon and time if you have missed a call, for 3-4 seconds.
- Use Now option appears when transfering pictures to the phone (previously just Ok). Options are View, Set as wallpaper, Set as screensaver, Set as starup screen, Add to contact
- SE wap link removed from Application folder
- Faster image browsing with selected images appearing full screen.
- Improved Bluetooth stability
- Bug where entering multiple names & numbers could delete the numbers for the first names entered has been fixed.
- Can now delete one contect from a group without deleting the whole group
- The bug whereby the first call received after power up produces an "answer, reject, answer and continue" menu seems to have been fixed
- The Globe icon that appears when using GRPS has been modified during initial connection (four silver ball circling around the globe)
- SMS Delivery Notification sound is now different to Incoming SMS sound (fixed to bluetooth transfer notification sound)
- Screen brightness increased
- Performing a Sync does not cause the phone to reboot (some phones only?)
- Playing sound and video after running Java applications now always works fine.
- When in phonebook, it's now possible to change keyboard language by simply press the # key.
- New contact =>New number =>Look up =>Unsaved list is now limited to 10 numbers rather than unlimited
- Line 1/2 indicator in top line of display
- Additional profile of 'TTY accessory' (Teletype device for the hearing impared)
- Sending pictures via bluetooth to other devices occasionally sent a lower quality image with previous firmwares. This has been fixed.
- Setup wizard has tips on the back and cancel key
- "Mark several" included in messages function
- Moving around in the Main Menu is faster and smoother
- Animated images run at a constant frame rate rather than vary according the the complexity of the image.
- JBenchmark 1 - 2,313 - 2,326
- JBenchmark 2 - 118 - 127
LCD 200406041
Camera 3.9
ITP CXC 125 813 R1S or R1T
- Bugs
Bluetooth turns itself off if a paired bluetooth headset goes out of range (some phones only).
Pocket PCs can no longer connect to the internet via bluetooth (still possible with IR). Add "Z" to the field of 'Extra dial-string modem commands' to fix this issue
Auto save to SIM option no longer available - Contacts / Advanced / Auto save on SIM.
R2V001
- Vodaphone version of R2L (UK)
- MP3s can now be used as ringtones so long as they have digital rights management, e.g. repackaged using Sony Ericsson's DRM Packager Tool.
R2N001
- Vodaphone version of R2L (Netherlands)
- Still unable to use MP3s as ringtones, whether they have DRM or not.
R2AA003
- 6/10/04 on Total Multiserver
- Faster main menu
- Ability to autosave a contact when using your SIM as the main phonebook
- Phonebook quicksearch facility
- Improvements to Bluetooth
- Improved battery life (for post Week 40 batteries only?)
- JBenchmark1: 2529
- Jbenchmark2: 129
R2AA003 er tatt bort fra markede å fra nettet (har ikke komme på nette enda da men)
Det viste seg at den laget mere problemer enn hva den løste :p
