Diskeeper 9 demo [ur disk is critical] help
m-momr
Frag Shield
"Fragmentation of the Master File Table (MFT—the disk’s virtual “table of contents”) and paging file (disk-based extension of memory) can lead to severe reliability problems. Diskeeper uses exclusive FragShield technology to configure disk allocation so as to prevent these critical system areas from becoming fragmented. Should Diskeeper detect a situation that could impact reliability, it recommends the appropriate action. In order to maintain performance and stability, Diskeeper does not initiate these actions until the server operator tells it to."
