Feil under brenning av dvdfilm hva betyr dette?
zuhr
Når jeg prøver å brenne en dvdfilm med DVDShrink kommer følgenende feil etter at den har tatt backup og brenningen skal starte:
1A21-0009-8030-2296-3298-5413
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22.07.2004 17:33:44
Nero API version: 6.3.1.20
Using interface version: 6.3.1.4
Installed in: D:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: < DVD+RW RW8165> Version: 1.01 - HA 1 TA 0 - 6.3.1.20
Adapter driver: <atapi> HA 1
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK6022GAX atapi Port 0 ID 0 DMA: On
CdRomPeripheral : DVD+RW RW8165 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
DVD+RW RW8165 E: CDRom0
Generic DVD-ROM F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 510MB (523248kB)
Free physical memory: 117MB (120032kB)
Memory in use : 77 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.10.2004
NeroAPI
14:15:53 #1 Phase 112 File APIProgress.cpp, Line 273
DVD-Video files reallocation started
14:15:56 #2 Phase 114 File APIProgress.cpp, Line 273
DVD-Video files reallocation completed (no file modified)
14:15:56 #3 Phase 111 File APIProgress.cpp, Line 273
DVD-Video files sorted
14:15:56 #4 Text 0 File Reader.cpp, Line 126
Reader running
14:15:56 #5 Text 0 File AudioCompilationImpl.cpp, Line 817
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
14:15:56 #6 Text 0 File Writer.cpp, Line 124
Writer DVD+RW RW8165 running
14:15:56 #7 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
14:15:56 #8 ISO9660GEN -11 File geniso.cpp, Line 3899
14:15:56 #9 Text 0 File Burncd.cpp, Line 3173
Turn on Disc-At-Once, using DVD media
14:15:56 #10 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286127 (508:01.52, 4465MB)
14:15:56 #11 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO
14:15:56 #12 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: DVD+RW RW8165, Media type: DVD+R
14:15:56 #13 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
14:15:56 #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [ DVD+RW RW8165 ]
14:15:56 #15 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [ DVD+RW RW8165 ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286128 | lead-out | 1 | 0x00 | 0x41
14:15:56 #16 Phase 24 File APIProgress.cpp, Line 273
Caching of files started
14:15:56 #17 Text 0 File Burncd.cpp, Line 4183
Cache writing successful.
14:15:56 #18 Phase 25 File APIProgress.cpp, Line 273
Caching of files completed
14:15:56 #19 Phase 36 File APIProgress.cpp, Line 273
Burn process started at 4x (5 540 KB/s)
14:15:56 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:15:56 #21 SCSI -1066 File Cdrdrv.cpp, Line 1188
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x07816000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x24 0x00
14:15:57 #22 Text 0 File DVDR.cpp, Line 5076
Drive: DVD+RW RW8165
Book Type request: DVD-ROM
Changing the book type was done succesfully
14:15:57 #23 Text 0 File DVDPlusRW.cpp, Line 628
Start write address at LBA 0
DVD high compatibility mode: Yes
14:16:05 #24 SCSI -1046 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x01AF0000
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x30 0x05
14:16:05 #25 CDR -1046 File Writer.cpp, Line 304
Illegal disc
14:16:05 #26 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
14:16:05 #27 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
14:16:05 #28 SCSI -1046 File Cdrdrv.cpp, Line 1188
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x5B 0x01 0x01 0x00 0x00 0x01 0x00 0x00 0x00 0x00 0x00 0x00
14:16:05 #29 SCSI -1046 File Cdrdrv.cpp, Line 1188
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
14:16:05 #30 Phase 127 File APIProgress.cpp, Line 273
Generating DVD high compatibility borders
14:16:06 #31 Text 0 File DVDR.cpp, Line 5076
Book Type request: DVD+R
14:16:06 #32 CDR -1046 File WriterStatus.cpp, Line 164
Illegal disc
14:16:06 #33 TRANSFER -24 File WriterStatus.cpp, Line 164
Could not perform end of Disc-at-once
14:16:06 #34 Phase 38 File APIProgress.cpp, Line 273
Burn process failed at 4x (5 540 KB/s)
14:16:06 #35 Text 0 File AudioCompilationImpl.cpp, Line 828
DRM: DRM burn session terminated.
14:16:06 #36 Text 0 File AudioCompilationImpl.cpp, Line 857
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.70a, size=20176 bytes, created 03.03.2004 02:02:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Prøv med en annen dvd r plate.
kan teste det, men det er slik at dvdshrink krever nero for å brenne ut?
Krever Nero ja.
Du kan også oppdatere Nero og DVD Shrink til siste versjon og se om det hjelper ;)
Jeg har også fått rare feilmeldinger i DVD Shrink (Burned process failed...) pga at jeg ikke hadde plate i, når den skulle begynne å brenne. Normalt skal det komme "Checking disc..." dialog opp.
(Orket ikke lese den lange meldinga, så så ikke helt hva som er feil hos deg).
Endret av JohnRichard
OPTODISC.OR4 4x DVD+R: Lavkvalitetsplater produsert av Optodisc i Taiwan, anbefales ikke utenom hvis prisen er meget lav. Merker: MMORE, That's write i DVD-Cover, en del samsung i 50 spindel. Leverandører: www.komplett.no Kvalitets score: 45%
Var det du tenkte på?
foresten på computer management på maskina står det:
DVD+RW RW8165
Er det noen spesielle plater denne ikke liker?
Endret av zuhr
Det var det jeg tenkte på ja.
Vet ikke hva slags brenner det er du har.... står jo ingenting om produsent.....
Er det i en bærbar PC? SDlike brennere er ofte kresne og jeg anbefaler deg å prøve kvalitetsplater som verbatim, eproformance, plextor, memorex, tdk, maxell osv.
