Får ikke kjørt Doom3
Har installert doom3-linux-1.1.1282.x86.run og lagt over filene .pak filer i ~/base, men får følgende triste melding:
IP: 127.0.0.1
------ Initializing File System ------
Loaded pk4 /usr/local/games/doom3/base/game00.pk4 with checksum 0x7dafc4d4
Loaded pk4 /usr/local/games/doom3/base/game01.pk4 with checksum 0x16cf3b8a
Loaded pk4 /usr/local/games/doom3/base/pak005.pk4 with checksum 0x8ffc3621
Current search path:
/home/bruker/.doom3/base
/usr/local/games/doom3/base/pak005.pk4 (63 files)
/usr/local/games/doom3/base/game01.pk4 (2 files)
/usr/local/games/doom3/base/game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
Unknown command 'vid_restart'
idRenderSystem::Shutdown()
Sys_Error: Couldn't load default.cfg
Hva kan jeg gjøre med dette?
Oppsann, hadde visst ikke kopiert over alle .pak filer allikvel :whistle:
Til tross for dette, får jeg nå følgende probblem:
bla bla bla...
blablablablabla....
error at 2311:
4].x, vertex.attrib[9], program.env[20];
DP3 result.texcoord[4].y, vertex.attrib[10], program.env[20];
DP3 result.texcoord[4].z, vertex.attrib[11], program.env[20];
# put into texture space
DP3 result.texcoord[5].x, vertex.attrib[9], program.env[21];
DP3 result.texcoord[5].y, vertex.attrib[10], program.env[21];
DP3 result.texcoord[5].z, vertex.attrib[11], program.env[21];
DP3 result.texcoord[6].x, vertex.attrib[9], program.env[22];
DP3 result.texcoord[6].y, vertex.attrib[10], program.env[22];
DP3 result.texcoord[6].z, vertex.attrib[11], program.env[22];
# generate the vertex color, which can be 1.0, color, or 1.0 - color
# for 1.0 : env[16] = 0, env[17] = 1
# for color : env[16] = 1, env[17] = 0
# for 1.0-color : env[16] = -1, env[17] = 1
MAD result.color, vertex.color, program.env[16], program.env[17];
ENDglprogs/ambientLight.vfp: GL_FRAGMENT_PROGRAM_ARB not available
glprogs/shadow.vp
glprogs/R200_interaction.vp
GL_PROGRAM_ERROR_STRING_ARB: line 83, column 22: error: invalid texture coordinate number
line 84, column 22: error: invalid texture coordinate number
line 85, column 22: error: invalid texture coordinate number
line 88, column 22: error: invalid texture coordinate number
line 89, column 22: error: invalid texture coordinate number
line 90, column 22: error: invalid texture coordinate number
error at 2579:
4].x, vertex.texcoord[1], R0;
DP3 result.texcoord[4].y, vertex.texcoord[2], R0;
DP3 result.texcoord[4].z, vertex.texcoord[3], R0;
# texture 5's texcoords will be the unnormalized lightDir in tangent space
DP3 result.texcoord[5].x, vertex.texcoord[1], lightDir;
DP3 result.texcoord[5].y, vertex.texcoord[2], lightDir;
DP3 result.texcoord[5].z, vertex.texcoord[3], lightDir;
ENDglprogs/nv20_bumpAndLight.vp
glprogs/nv20_diffuseColor.vp
glprogs/nv20_specularColor.vp
glprogs/nv20_diffuseAndSpecularColor.vp
glprogs/environment.vfp
glprogs/environment.vfp: GL_FRAGMENT_PROGRAM_ARB not available
using ARB_vertex_buffer_object memory
using NV20 renderSystem
Regenerated world, staticAllocCount = 0.
Sys_Error: couldn't find game dynamic library
Hmm.....
:dontgetit:
