Pilot_ Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Heisann! Driver å utvikler en poll, og har nettopp funnet denne her på hotscripts.com : HTML Code <html> <head> <title>Min hjemmeside</title> </head> <body> <basefont face=Arial> <form action=poll.php method=post> Hva synst dere om denne siden?<br> <input type=radio name=vote value="Denne siden er perfekt!"> Perfekt<br> <input type=radio name=vote value="Denne siden var ikke så verst."> Ikke verst<br> <input type=radio name=vote value="Denne siden var dårlig."> Dårlig<br> <input type=radio name=vote value="Denne siden var skikkelig ræva!."> Ræva<br> <input type=submit value=Vote> </form> </body> </html> PHP Code // DEFINE THE VARIABLES // // title of this poll $title = "What is your favorite programming language?"; // closing date for this poll in MM/DD/YYYY format $closingDate = "1/1/2010"; // text file that stores vote choices and totals $pollFile = "poll.txt"; // text file that stores IP addresses $ipFile = "ips.txt"; // full path to your CSS style sheet $styleSheet = "http://yoursite/style.css"; // leave blank if you aren't using this // DO NOT EDIT BELOW THIS POINT UNLESS YOU KNOW PHP! // // DEFINE THE FUNCTIONS // // check if the poll has closed function is_closed() { global $closingDate; // split the closing date into month, day, and year $closingDate = explode("/", $closingDate); // get today's today to test against the closing date $today = getdate(); $message = date("l, F j", mktime(0,0,0,$closingDate[0],$closingDate[1],$today[year])); // if today's year is greater than the closing year, return true if ($today[year] > $closingDate[2]) { return $message; } // if today's year is equal to the closing year elseif ($today[year] == $closingDate[2]) { // if today's month is greater than the closing month, return true if ($today[mon] > $closingDate[0]) { return $message; } // if today's month is equal to the closing month elseif ($today[mon] == $closingDate[0]) { // if today is greater than or equal to the closing day, return true if ($today[mday] >= $closingDate[1]) { return $message; } // if the poll is still open, return false else { return false; } } // if the poll is still open, return false else { return false; } } // if the poll is still open, return false else { return false; } } // check if the user has already voted function has_voted() { global $ipFile; global $REMOTE_ADDR; // open the IP address file $ips = fopen($ipFile, "r"); // compare each entry with the user's IP address while (!feof($ips)) { $ip = fgets($ips, 20); if ($ip == $REMOTE_ADDR . "\r\n") { $match = 1; break; } } // close the IP address file fclose($ips); if (!$match) { // reopen the IP address file $ips = fopen($ipFile, "a"); // add the user's IP address fputs($ips, $REMOTE_ADDR . "\r\n"); // close the IP address file fclose($ips); return false; } else { return true; } } // add the user's vote function addVote($vote) { global $pollFile; // get the current votes $fp_read = fopen($pollFile, "r"); $currentVote = fread($fp_read, filesize($pollFile)); fclose($fp_read); // create an array with even numbers containing vote choices // and odds containing vote totals $votes = split('[|:]', $currentVote); // update the vote for ($i = 1; $i < count($votes); $i = $i + 2) { // get the array index number for the name of this vote $name = $i - 1; // if this vote choice is this user's selection, increment it if ($votes[$name] == $vote) { $votes[$i]++; } // if this vote IS the last choice if ($i == (count($votes) - 1)) { $updatedVote .= $votes[$name] . ":" . $votes[$i]; } // if this vote is NOT the last choice else { $updatedVote .= $votes[$name] . ":" . $votes[$i] . "|"; } } // save the updated vote $fp_write = fopen($pollFile, "w"); fputs($fp_write, $updatedVote); fclose($fp_write); } // display the poll function displayPoll($message) { global $title, $pollFile, $styleSheet; echo "<html>\n"; echo "<head>\n"; echo "<title>$title</title>\n"; echo "<link rel=\"stylesheet\" type=\"text/css\" href=\"$styleSheet\">\n"; echo "</head>\n\n"; echo "<body>\n"; // get the current votes $fp_read = fopen($pollFile, "r"); $currentVote = fread($fp_read, filesize($pollFile)); fclose($fp_read); // create an array with even numbers containing vote choices // and odds containing vote totals $votes = split('[|:]', $currentVote); // if a message was sent, print it if (isset($message)) { echo "<p align=center>$message</p>\n\n"; } echo "<table align=center>\n"; echo "<caption align=top><b>$title</b></caption>\n"; // print the poll table rows // including vote choice, vote total, and percentage of total votes for ($i = 1; $i < count($votes); $i = $i + 2) { // add together each vote total to find the total number of votes cast $totalVotes += $votes[$i]; } for ($i = 1; $i < count($votes); $i = $i + 2) { // get the array index number for the name of this vote $name = $i - 1; // calculate the percentage of total votes for this vote // rounded to 1 decimal place if ($totalVotes == 0) { $percentage = 0; } else { $percentage = $votes[$i] / $totalVotes * 100; $percentage = round($percentage, 1); } echo "<tr>\n"; echo "\t<td>$votes[$name]</td>\n"; echo "\t<td>$votes[$i] votes</td>\n"; // if the percentage is 0, don't print a bar if ($percentage == 0) { echo "\t<td>$percentage%</td>\n"; } // otherwise, print the bar else { echo "\t<td><img src=poll.jpg width=$percentage height=15> $percentage%</td>\n"; } echo "</tr>\n"; } // print the total number of votes cast echo "<caption align=bottom>Total Votes: $totalVotes</caption>\n"; // finish printing the poll table echo "</table>\n"; echo "</body>\n"; echo "</html>\n"; } // PROGRAM CODE // // if the poll is closed, display the poll and exit if ($message = is_closed()) { displayPoll("The poll closed on " . $message . "."); exit; } // if the user is not voting, display the poll and exit if (!isset($vote)) { displayPoll(""); exit; } // if the user has already voted, display the poll and exit if (has_voted()) { displayPoll("You already voted."); exit; } // add the user's vote addVote($vote); // display the poll displayPoll(""); ?> Ser dette bra ut? Lenke til kommentar
Marvil Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Tja, har du noen gang sett at det finnes en PHP-del her på forumet..? De ville ryktene tilsier at den fungerer også. Lenke til kommentar
Pilot_ Skrevet 13. oktober 2004 Forfatter Del Skrevet 13. oktober 2004 Har lest litt rundt der ja.. men lurte bare på om denne her var bra? Lenke til kommentar
potetskrell Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Har lest litt rundt der ja.. men lurte bare på om denne her var bra? Sett den opp å se selv, da vel Lenke til kommentar
Pilot_ Skrevet 13. oktober 2004 Forfatter Del Skrevet 13. oktober 2004 Jeg prøvde å teste den på maskinen, der når jeg trykte "vote" ville browseren laste ned filen "poll.php". Må jeg legge den ut på nettet før den skal fungere? Lenke til kommentar
Purify Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Naturlig nok må du det, hvis du ikke har installert støtte for php lokalt, da. Lenke til kommentar
cfenzo Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 (endret) Om du ikke kjører webserver med php selv på din pc.. Så er du nødt til å laste den opp på en server med støtte for php før du kan se om det funker, ja.. damn... Purfiy var litt for kjapp der.. Endret 13. oktober 2004 av cfenzo Lenke til kommentar
Pilot_ Skrevet 13. oktober 2004 Forfatter Del Skrevet 13. oktober 2004 (endret) Ble en post for mye Endret 13. oktober 2004 av Luzifer Lenke til kommentar
Pilot_ Skrevet 13. oktober 2004 Forfatter Del Skrevet 13. oktober 2004 Naturlig nok må du det, hvis du ikke har installert støtte for php lokalt, da. Hvordan gjøres det da? Lenke til kommentar
Purify Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Aner ikke. Legg det heller ut på en server med støtte for php. Er ikke så mye strev, skal du se. Lenke til kommentar
Pilot_ Skrevet 13. oktober 2004 Forfatter Del Skrevet 13. oktober 2004 Aner ikke. Legg det heller ut på en server med støtte for php. Er ikke så mye strev, skal du se. Joda.. skal gå fint det Lenke til kommentar
Marvil Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Har lest litt rundt der ja.. men lurte bare på om denne her var bra? Jeg mente at tråden kanskje passet bedre der.. Lenke til kommentar
potetskrell Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Vil ikke virke det der, mangler vesentlig "<?php" i begynnelsen. Kan btw informere at denne pollen ikke virker sånn som den står der.. Med <? så klart.. Lenke til kommentar
Simon Zimmermann Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Her er en liste over gratis-servere med støtte for PHP:Liste Ellers finnes det mange forskjellige programmer som man kan installerer lokalt på egen datamaskin, enten til testing av php eller til rett og slett å hoste sin egen webside. Lenke til kommentar
Pilot_ Skrevet 13. oktober 2004 Forfatter Del Skrevet 13. oktober 2004 Gikk ikke dette her http://medlem.spray.se/luziferx/poll.html Lenke til kommentar
Purify Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Nei. Fatal error: Maximum execution time of 10 seconds exceeded in /data/members/free/tripod/se/l/u/z/luziferx/htdocs/poll.php on line 71 Lenke til kommentar
Radar911 Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Test ut FusionPoll, genialt og enkelt. Lenke til kommentar
Pilot_ Skrevet 13. oktober 2004 Forfatter Del Skrevet 13. oktober 2004 Test ut FusionPoll, genialt og enkelt. Er det noe slags tegn til reklame på den der?? Lenke til kommentar
Radar911 Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 (endret) Ingen reklame eller annet tull, nei. Endret 13. oktober 2004 av Radar911 Lenke til kommentar
