Datagrid - editere en rad
Hei
Jeg prøver meg igjen jeg...
HTML kode
<asp:datagrid id="dgConstants" style="Z-INDEX: 103; LEFT: 40px; POSITION: absolute; TOP: 224px"
    runat="server" Width="840px" Height="280px" OnCancelCommand="dgConstants_Cancel" OnUpdateCommand="dgConstants_Update" OnEditCommand="dgConstants_Edit">
    <Columns>
    <asp:EditCommandColumn ButtonType="PushButton" UpdateText="Update" CancelText="Cancel" EditText="Edit"></asp:EditCommandColumn>
    <asp:BoundColumn DataField="ID" ReadOnly="True" HeaderText="ID"></asp:BoundColumn>
    </Columns>
  </asp:datagrid>
Binder data til datagriden slik:
    dgConstants.AutoGenerateColumns = False
                '    Response.Write(TabConstants.Rows.Count)
                i = TabConstants.Rows.Count
                Dim bc As BoundColumn
                For Each col As DataColumn In TabConstants.Columns
                    bc = New BoundColumn
                    bc.HeaderText = col.ColumnName
                    bc.DataField = col.ColumnName
                    Me.dgConstants.Columns.Add(bc)
                Next
                Me.dgConstants.Visible = True
                Dim ds As New DataSet
                ds = New DataSet
                'creating a dataset
                ds.Tables.Add(TabConstants)
                'adding the table to dataset
                dgConstants.DataSource = ds
                'binding the table to datagrid
                dgConstants.DataBind()
                dgConstants.Columns(1).Visible = False
                dgConstants.Columns(2).Visible = False
                dgConstants.Columns(4).Visible = False
Jeg ønsker å editere rader så derfor benytter jeg meg av EditCommandColumn med noen funksjoner som vist under:
Sub dgConstants_Edit(ByVal sender As Object, ByVal e As DataGridCommandEventArgs)
        dgConstants.EditItemIndex = e.Item.ItemIndex
        Dim columnValue As Integer
            testBind()
End Sub
Sub dgConstants_Cancel(ByVal sender As Object, ByVal e As DataGridCommandEventArgs)
        dgConstants.EditItemIndex = -1
    testBind()
End Sub
Sub dgConstants_Update(ByVal sender As Object, ByVal e As DataGridCommandEventArgs)
        Dim i As Integer
        Dim columnValue As String
        'HENTER UT GALT ANTALL CELLER
        columnValue = e.Item.Cells.Count
        'HENTER UT RETT KOLONNE
        Dim itemIndx As Integer = e.Item.ItemIndex
        'KLARER IKKE HENTE UT VERDIER FRA CELLENE...
        Dim itemtext1 As String = dgConstants.Items(itemIndx).Cells(1).Text
        Dim itemtext2 As String = dgConstants.Items(itemIndx).Cells(2).Text
    End Sub
Kan noen fortelle meg hvorfor jeg ikke får tak i cellene i valgt rad?
Silje
Sjekk om de kolonnene den ikke klarer å hente ut, er de som du har satt til visible=false.
I så fall må du gjøre en egen bind for datagrid_EditItem, der du ikke skjuler disse feltene før en update. Kolonner og innholdet som er satt til visible=false "eksisterer" ikke for datagrid'en, dessverre.
Tips: Legg informasjonen i de usynlige kolonnene i enten labels eller tekstbokser som du setter til 1 px bredde. Da kan du hente ut dataene, uten at de egentlig synes. Dessverre så vil du da få rare striper i datagriden din. FOr å gjøre om på de, så lager du 3 ekstra css-oppføringer. En viser kun høyre cellekant, en viser ingen cellesidekanter, og en viser kun venstre sidekant. I onItemDataBound gjør du en sjekk på om du er i editeringsmodus, og setter css-atributtet til respektive kolonner.
Mulig det finnes en mindre knotete måte å gjøre det på, men denne brute-force-metoden skal faktisk fungere.
Kirikiri
Kirikiri
Hei
Det har ikke noe med de kolonnene jeg setter til visable = false. Det er faktisk kun disse jeg får tak i update funksjonen pga disse er definert i HTML koden. Problemet er at jeg ikke får tak i de kolonner som jeg oppretter dynamisk i koden.
Det er mulig du må gjøre en sjekk på
if page.IsPostback then
'- ikke gjør noe
else
BindDatagrid
end if
Eller om det er omvendt. Mest sannsynlig så prøver du å oppdatere fra en grid som ikke er i edit-modus, eller noe sånn.
Sjekk disse to postene fra www.asp.net om de kan hjelpe deg videre:
http://www.asp.net/Forums/ShowPost.aspx?ta...=1&PostID=57849
og http://www.asp.net/Forums/ShowPost.aspx?ta...=1&PostID=97265
Kirikiri
