-MarL- Skrevet 15. oktober 2004 Rapporter Del Skrevet 15. oktober 2004 Sliter ennå med freelancer lyden... Har gjort alt d som sto ovenfor...men det funker ikke allikavel... Har media player 10 mens den som følger med cd`en er media player 7.1... vil jo ikke downgrade media playeren min bare for å spille freelancer... Ingen andre som har samme probleme?? Hadde det samma probleme når jeg spillte spille for første gang. Hvis jeg husker rett så er det codec som gjør att du mister lyden. Søk på google om lyd probleme. Eller du kan se her Lenke til kommentar
-MarL- Skrevet 15. oktober 2004 Rapporter Del Skrevet 15. oktober 2004 Missing Game Sounds If you experience missing game sounds throughout Freelancer then a different audio codec is probably being used rather that the one provided by Freelancer. Please follow these steps if some sounds and speech are still missing after installation: Uninstall any 3rd party codec pack or the Nimo Codec pack from your system. Uninstall Freelancer. Go to the following directory, C:\WINDOWS\system32 and delete the file ?l3codecp.acm?. If there happens to be another file named ?l3codeca.acm?, delete this too. If your system is Windows 98 or ME, open the system.ini file located in your system folder; C:\WINDOWS\SYSTEM. Delete ONLY the line that starts with ?msacm.l3acm=?. In the case of the Nimo codec pack, this will read ?msacm.l3acm=l3codecp.acm? If your system is Windows 2000 or XP, open the system registry editor (regedit) from the RUN command window. Locate and delete the following key: \HKLM\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Drivers32\msacm.l3acm Load the Freelancer installation CD and locate the REDIST folder. Within the REDIST folder, double click on the file named ?WMFADist.exe? and follow on-screen instructions. Install Freelancer. Lenke til kommentar
vorbis Skrevet 16. oktober 2004 Rapporter Del Skrevet 16. oktober 2004 Idag fant jeg den perfekte handelsruta Jeg kjøper fertilizers i Denver, Colorado. Så flyr igjennom Galileo eller Kepler til den solsystemet i Kusari (tror det heter Shikoku, men er ikke sikker ) Selger fertilizers i Deshima Station for 50 $ i fortjenste. Så kjøper du Engine Componets der og flyr tilbake til Denver og selger de der til ca 500$ i fortjeneste (!) Nettopp kjøpt meg en Drone, så nå får jeg ca. 100 000 i fortjeneste tur/retur. Ferden videre, etter jeg har spart meg opp litt penger, blir vel litt utforskning i Kusari. Eventuelt kjøper jeg meg en Dragon og sloss mot litt kriminelle Lenke til kommentar
atrax Skrevet 16. oktober 2004 Forfatter Rapporter Del Skrevet 16. oktober 2004 Freelancer håndterer ikke lag på en helt elegant måte. Spillte et oppdrag i dag, kom meg til waystation, men fiendene bare fløy av gårde ut i evigheten. Javel, tenkte jeg og venta på at lag skulle stoppe og de skulle komme tilbake. Men eneste som skjer er at serveren trolig også tror at jeg befinner meg der ute i evigheten et sted og og blir beskutt. For med gjevne mellomrom mister jeg shield og blir skadet. Uten at jeg kan gjøre noe som helst, eller ser noe som helst. Serveren står på en NGT Delta 2400/640-linje. Dette burde holde i bøtter og spann (da 10 spillere var tilkoblet, lå uploadhastigheten på ca 15kB/s). Linjen er delt mellom meg og en jente som kun bruker laptopen sin til surfing. Hun har ingen fildelingsprogrammer, brannmuren min forhindrer det. Noen muligheter til lag: PCen min eller hennes laster ned Windows Updates. Disse vil i såfall være små, så det burde ikke merkes engang. Din PC (eller andre tilkoblet linjen din) laster ned/opp noe. Krøll på linja hos meg, deg eller ISP. Nederste alternativ inkluderer ruterproblemer. Jeg har en Netopia 4542 som slår seg vrang med ca. 1 måneds mellomrom, og må da restartes. Dette har ikke skjedd så lenge serveren har vært oppe. Har andre opplevd slik fæl lag fra og med fredag? Lenke til kommentar
atrax Skrevet 16. oktober 2004 Forfatter Rapporter Del Skrevet 16. oktober 2004 (endret) Gode handelsruter baseres ofte på varer som er svært dyre. Alien organisms, alien artifacts, niobium, diamonds ++ er eksempler på gode varer. Man må ofte ut i avsidesliggende systemer som herjes av pirater for å få tak i disse godsakene... Den nest største freighteren tar 250 enheter, og selges for ca. $170k i Rheinland. Minuset er at den flyr som en gravid ku. (Den aller største freighteren krever ofte en del bestikkelser for å få tak i, siden det er en terroristbase som selger den.) Edit: Oppdaterte første post med info om bl.a. online statistikk. Dessuten har vi fått en cheater på besøk! Nemlig luringen ved navn 'Hallo'. Han har på mirakuløst vis skaffet seg nesten 10 millioner credits på under én times spilletid, og et heftig skip som ikke er å få kjøpt i de systemene han har vært i. Skjermskudd: Om dere savner navnet hans på statistikksiden, er det selvfølgelig fordi statistikken til cheatere er ugyldig. Endret 16. oktober 2004 av atrax Lenke til kommentar
JBlack Skrevet 16. oktober 2004 Rapporter Del Skrevet 16. oktober 2004 Noen muligheter til lag:PCen min eller hennes laster ned Windows Updates. Disse vil i såfall være små, så det burde ikke merkes engang. Din PC (eller andre tilkoblet linjen din) laster ned/opp noe. Krøll på linja hos meg, deg eller ISP. Nederste alternativ inkluderer ruterproblemer. Jeg har en Netopia 4542 som slår seg vrang med ca. 1 måneds mellomrom, og må da restartes. Dette har ikke skjedd så lenge serveren har vært oppe. Linja hos meg var grei, testa med en annen PC. Men jeg hadde skikkelig lag-problemer en stund i går. Men lag er en ting, en annen er hvordan Freelancer håndterer dette. At man blir beskutt og drept, uten at man kan gjøre noe som helst annet enn å sitte å se på, det er irriterende. Lenke til kommentar
Thsan Skrevet 16. oktober 2004 Rapporter Del Skrevet 16. oktober 2004 Jeg har en handelsrute der jeg jeg tjener 160.000 tur retur . Og da selger jeg bare 145 units . Men snakket litt med han hallo fyren han var fra tyskland og er 16 år mer sa ha ikke ! Lenke til kommentar
akarno Skrevet 16. oktober 2004 Rapporter Del Skrevet 16. oktober 2004 Har fått Eagle og så og si de beste våpenene og skjoldet i spillet... Men HVA NÅ? Seff skal jeg ikke slutte Lenke til kommentar
Fat_ASS Skrevet 16. oktober 2004 Rapporter Del Skrevet 16. oktober 2004 WOHOO!!!!! ENDELI fikk jeg lyden til å funke!!!! Tenkte jeg kanskje skulle ta å begynne å spille litt online snart...men jeg kan egentlig ikke noe serlig me spillet... Er det kanskje lurt å spille single player først??? Lenke til kommentar
akarno Skrevet 16. oktober 2004 Rapporter Del Skrevet 16. oktober 2004 Du trenger ikke å spille SP først, men er jo alltid en fordel... Lærer hvordan man spiller og får med deg historien. Det går fint å starte MP uten å ha spillt spillet før Lenke til kommentar
derezzed Skrevet 16. oktober 2004 Rapporter Del Skrevet 16. oktober 2004 (endret) Som meg. Spilte for første gang på onsdag og da var det multiplayer med en gang. EDIT: Omformulering... Endret 16. oktober 2004 av Aleksander Lenke til kommentar
Fat_ASS Skrevet 16. oktober 2004 Rapporter Del Skrevet 16. oktober 2004 Hehe...har spilt litt SP nå...begynner å skjønne hvordan ting fungerer... Betalte en fyr noe cash for at han skulle uploade noe info til meg... fikk opp karte men det sto ikke noe spesielt de som jeg ikke visste fra før... Hvqa er det som skjer når noen uploader noe til meg??? skal jeg ikke få vite noe nyttig??? skjønte ikke det der helt jeg...:/ Lenke til kommentar
likferd Skrevet 16. oktober 2004 Rapporter Del Skrevet 16. oktober 2004 Hehe...har spilt litt SP nå...begynner å skjønne hvordan ting fungerer...Betalte en fyr noe cash for at han skulle uploade noe info til meg... fikk opp karte men det sto ikke noe spesielt de som jeg ikke visste fra før... Hvqa er det som skjer når noen uploader noe til meg??? skal jeg ikke få vite noe nyttig??? skjønte ikke det der helt jeg...:/ Hva du får ved å betale for informasjon er svært varierende. Av og til får du vite om steder du allerede har vært, av og til blir du rett og slett lurt, og kjører inn i bakhold. Er du heldig får du derimot vite om skjulte baser, vrak med masse snacks, gjemte jumpholes som virker som snarveier mellom systemene, osv. Lenke til kommentar
atrax Skrevet 16. oktober 2004 Forfatter Rapporter Del Skrevet 16. oktober 2004 Jeg mener det er best å spille multiplayer først. Vanligvis er folk hjelpsomme og hyggelige, slik at det er mye lettere å lære spillet sammen med andre, enn på egenhånd. Erfarne spillere har dessuten ofte en del triks oppi ermet som nye spillere kan nyte godt av. For eksempel dette: Jeg kjøper aldri informasjon, det er kjekkere å finne gjemte baser og jump holes selv. Få opp kartet, og trykk på knappen som har mouseover-tekst: 'Patrol Path Map'. Nå ser du hvor de faste rutene til NPC-romskipene er. Om disse rutene slutter i et punkt utenfor allfarsvei, kan du nesten regne med at det er noe spesielt der. Prøv selv! Lenke til kommentar
Fat_ASS Skrevet 17. oktober 2004 Rapporter Del Skrevet 17. oktober 2004 Ser at enkelte skyter opp i level veldig fort....hvordan gjør dere det??? Ligger enda på level 4...gjør bare oppdrag å sånt... Kan ikke ta andre oppdrag enn i new york system for alle andre plasser er de så extremt overlegen at jeg dør med en gang... Noen gode råd?? har lyst på bedre fly å våpen...men jeg finner ikke noe særlig bra...:/ har vært i tre andre systemer men fant ikke noe bedre fly...fant heller ikke noe særlig bedre våpen...=( Lenke til kommentar
Bluebeans Skrevet 17. oktober 2004 Rapporter Del Skrevet 17. oktober 2004 Ey, nest nederst jo ! Har ikke rukket å spille noe særlig =P Lenke til kommentar
laserskriver Skrevet 17. oktober 2004 Rapporter Del Skrevet 17. oktober 2004 woow 19 plass Lenke til kommentar
Fat_ASS Skrevet 17. oktober 2004 Rapporter Del Skrevet 17. oktober 2004 Er det liksom bare å gjøre mission på mission til det ikke er flere igjen å så gå videre?? Blir jo litt meningsløst etterhvert da...:/ Lenke til kommentar
Fat_ASS Skrevet 17. oktober 2004 Rapporter Del Skrevet 17. oktober 2004 (endret) EDIT: Kom visst opp to ganger Endret 17. oktober 2004 av Fat_ASS Lenke til kommentar
ÖzzY Skrevet 17. oktober 2004 Rapporter Del Skrevet 17. oktober 2004 Har spilt ca. 5 timer, men så ble jeg lei... er ikke noe sykt spennende mp spill egentlig. Kan hende at jeg spiller litt når jeg ikke har noe annet å drive med. Noen som vet om de har tenkt på en oppfølger til freelancer eller? Lenke til kommentar
