Hvilket lydkort har jeg?
Jeg skal laste ned drivere til lydkortet mitt, men vet ikke hvilket lydkort jeg har.
jeg vet at jeg har Creative Sound Blaster Live! Men jeg vet ikke hvilken version.
kan dere hjelpe meg der?
System Information
Time of this report: 10/6/2004, 15:52:33
Machine name: CHRIS-UO8C26N3K
Operating System: Windows XP Professional (5.1, Build 2600) (2600.xpclient.010817-1148)
Language: English (Regional Setting: English)
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon 64 Processor 3400+, ~2.4GHz
Memory: 1024MB RAM
Page File: 114MB used, 2347MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9800 PRO
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9800 AGP (0x4E48)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4E48&SUBSYS_00021002&REV_00
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6476 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/25/2004 13:29:04, 209408 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 8/25/2004 13:28:46, 787456 bytes
Device Identifier: {D7B71EE2-0D08-11CF-FE6A-0820A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4E48
SubSys ID: 0x00021002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Live! Wave Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0002&SUBSYS_80261102&REV_07
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: emu10k1m.sys
Driver Version: 5.12.0001.3300 (English)
WHQL Logo'd: Yes
Date and Size: 8/17/2001 13:19:26, 283904 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 5000, 100000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SB Live! MIDI UART, Hardware (Kernel Mode), Input, No DLS, External
SB Live! MIDI UART, Hardware (Kernel Mode), Output, No DLS, External
SB Live! Wave Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
B: SB Live! MIDI Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
A: SB Live! MIDI Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI UART [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI UART [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Multimedia Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1631, 0x5000
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x00E7
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/23/2001 13:00:00, 50688 bytes
| Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes
Gameport Devices
+ PCI standard PCI-to-PCI bridge
| Matching Device ID: pci\cc_0604
| Service: pci
| Driver: pci.sys, 8/23/2001 13:00:00, 62464 bytes
+-+ Creative SBLive! Gameport
| | Matching Device ID: pci\ven_1102&dev_7002
| | Lower Filters: ctljystk
| | Service: gameenum
| | Driver: ctljystk.sys, 8/17/2001 13:19:20, 3712 bytes
| | Driver: gameenum.sys, 8/17/2001 15:02:32, 9728 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/23/2001 13:00:00, 50944 bytes
| Driver: kbdclass.sys, 8/23/2001 13:00:00, 23424 bytes
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/23/2001 13:00:00, 13952 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/17/2001 22:38:00, 37896 bytes
+ Logitech USB First/Pilot Mouse+
| Vendor/Product ID: 0x046D, 0xC001
| Matching Device ID: hid\vid_046d&pid_c001
| Service: mouhid
| Driver: mouhid.sys, 8/23/2001 13:00:00, 12160 bytes
| Driver: mouclass.sys, 8/23/2001 13:00:00, 22016 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 108.8 GB
Total Space: 114.5 GB
File System: NTFS
Model: SAMSUNG SP1213N
Drive: D:
Model: HL-DT-ST DVD-ROM GDR8163B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 47488 bytes
Drive: E:
Model: IDE-CD R/RW 8x4x32
System Devices
Name: ADMtek AN983 10/100 PCI Adapter
Device ID: PCI\VEN_1317&DEV_0985&SUBSYS_12161113&REV_11\4&3191A3E6&0&3870
Driver: C:\WINDOWS\System32\DRIVERS\an983.sys, 2.12.0507.2001 (English), 8/17/2001 13:11:16, 34112 bytes
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_086C0574&REV_46\4&3191A3E6&0&6070
Driver: C:\WINDOWS\System32\DRIVERS\ohci1394.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 55424 bytes
Driver: C:\WINDOWS\System32\DRIVERS\1394bus.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 49536 bytes
Driver: C:\WINDOWS\System32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 14:46:40, 6400 bytes
Driver: C:\WINDOWS\System32\DRIVERS\nic1394.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 56960 bytes
Driver: C:\WINDOWS\System32\DRIVERS\arp1394.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 54016 bytes
Name: Creative SBLive! Gameport
Device ID: PCI\VEN_1102&DEV_7002&SUBSYS_00201102&REV_07\4&3191A3E6&0&4970
Driver: C:\WINDOWS\system32\drivers\ctljystk.sys, 5.01.2501.0000 (English), 8/17/2001 13:19:20, 3712 bytes
Driver: C:\WINDOWS\System32\DRIVERS\gameenum.sys, 5.01.2600.0000 (English), 8/17/2001 15:02:32, 9728 bytes
Name: Creative SB Live! Value (WDM)
Device ID: PCI\VEN_1102&DEV_0002&SUBSYS_80261102&REV_07\4&3191A3E6&0&4870
Driver: n/a
Name: NVIDIA CK8S Serial ATA Controller (v2.5)
Device ID: PCI\VEN_10DE&DEV_00EE&SUBSYS_03001462&REV_A2\3&13C0B0C5&0&48
Driver: C:\WINDOWS\System32\DRIVERS\nvatabus.sys, 5.10.2600.0412 (English), 1/13/2004 04:36:00, 63744 bytes
Driver: C:\WINDOWS\System32\idecoi.dll, 1.00.0000.0001 (English), 1/13/2004 04:36:00, 291328 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_00ED&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&70
Driver: C:\WINDOWS\System32\DRIVERS\pci.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 62464 bytes
Name: Multimedia Audio Controller
Device ID: PCI\VEN_10DE&DEV_00EA&SUBSYS_75851462&REV_A1\3&13C0B0C5&0&30
Driver: n/a
Name: Universal Serial Bus (USB) Controller
Device ID: PCI\VEN_10DE&DEV_00E8&SUBSYS_03001462&REV_A2\3&13C0B0C5&0&12
Driver: n/a
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_03001462&REV_A1\3&13C0B0C5&0&11
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 15616 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 123264 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 23:36:34, 67072 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 50688 bytes
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_03001462&REV_A1\3&13C0B0C5&0&10
Name: NVIDIA CK8S Parallel ATA Controller (v2.5)
Device ID: PCI\VEN_10DE&DEV_00E5&SUBSYS_03001462&REV_A2\3&13C0B0C5&0&40
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_00E4&SUBSYS_03001462&REV_A1\3&13C0B0C5&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_00E3&SUBSYS_03001462&REV_A2\3&13C0B0C5&0&50
Name: NVIDIA nForce3 250 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_00E2&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&58
Driver: C:\WINDOWS\System32\DRIVERS\nv_agp.SYS, 4.12.0001.0377 (English), 10/29/2003 05:02:00, 21120 bytes
Driver: C:\WINDOWS\System32\NVCOG.DLL, 1.00.0000.0007 (English), 10/29/2003 05:02:00, 29696 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_00E1&SUBSYS_00000000&REV_A1\3&13C0B0C5&0&00
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_00E0&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&08
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 35840 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_00DF&SUBSYS_03001462&REV_A2\3&13C0B0C5&0&28
Driver: C:\WINDOWS\System32\DRIVERS\nvnetbus.sys, 1.00.0000.0433 (English), 3/16/2004 03:50:52, 12928 bytes
Driver: C:\WINDOWS\System32\DRIVERS\nvnrm.sys, 1.00.0000.0433 (English), 3/16/2004 03:50:44, 56448 bytes
Driver: C:\WINDOWS\System32\DRIVERS\nvsnpu.sys, 1.00.0000.0433 (English), 3/16/2004 03:50:34, 190976 bytes
Driver: C:\WINDOWS\System32\bdco1.dll, 1.00.0000.0000 (English), 3/16/2004 03:40:14, 8192 bytes
Driver: C:\WINDOWS\System32\nvconrm.dll, 1.00.0000.0014 (English), 3/16/2004 04:33:42, 31744 bytes
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C0
Driver: n/a
Name: RADEON 9800 PRO - Secondary
Device ID: PCI\VEN_1002&DEV_4E68&SUBSYS_00031002&REV_00\4&1AD7642&0&0158
Driver: C:\WINDOWS\System32\DRIVERS\ati2mtag.sys, 6.14.0010.6476 (English), 8/25/2004 13:28:46, 787456 bytes
Driver: C:\WINDOWS\System32\ati2dvag.dll, 6.14.0010.6476 (English), 8/25/2004 13:29:04, 209408 bytes
Driver: C:\WINDOWS\System32\ati2cqag.dll, 6.14.0010.0252 (English), 8/25/2004 13:10:20, 237568 bytes
Driver: C:\WINDOWS\System32\Ati2mdxx.exe, 6.14.0010.2494 (English), 8/25/2004 13:27:08, 65536 bytes
Driver: C:\WINDOWS\System32\ati3duag.dll, 6.14.0010.0257 (English), 8/25/2004 13:25:56, 2239328 bytes
Driver: C:\WINDOWS\System32\ativvaxx.dll, 6.14.0001.0029 (English), 8/25/2004 13:15:16, 476928 bytes
Driver: C:\WINDOWS\System32\ATIDDC.DLL, 6.14.0010.0005 (English), 8/25/2004 13:26:32, 81920 bytes
Driver: C:\WINDOWS\System32\atitvo32.dll, 6.14.0010.4100 (English), 8/25/2004 13:12:10, 17408 bytes
Driver: C:\WINDOWS\System32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 11:01:04, 24064 bytes
Driver: C:\WINDOWS\System32\ati2evxx.exe, 6.14.0010.4105 (English), 8/25/2004 13:26:56, 389120 bytes
Driver: C:\WINDOWS\System32\ati2evxx.dll, 6.14.0010.4105 (English), 8/25/2004 13:27:00, 86016 bytes
Driver: C:\WINDOWS\System32\atipdlxx.dll, 6.14.0010.2491 (English), 8/25/2004 13:27:18, 126976 bytes
Driver: C:\WINDOWS\System32\Oemdspif.dll, 6.14.0001.0010 (English), 8/25/2004 13:27:12, 102400 bytes
Driver: C:\WINDOWS\System32\ati2edxx.dll, 6.14.0010.2494 (English), 8/25/2004 13:27:04, 30720 bytes
Driver: C:\WINDOWS\System32\ATIDEMGR.dll, 1.00.1698.24059 (English), 8/25/2004 14:22:08, 151552 bytes
Driver: C:\WINDOWS\System32\atioglxx.dll, 6.14.0010.4582 (English), 8/25/2004 13:48:12, 6508544 bytes
Driver: C:\WINDOWS\System32\atiiiexx.dll, 6.14.0010.4003 (English), 8/25/2004 14:40:02, 294912 bytes
Device ID: PCI\VEN_1002&DEV_4E48&SUBSYS_00021002&REV_00\4&1AD7642&0&0058
DirectX Components
ddraw.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 265728 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 10496 bytes
d3d8.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1179648 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1689600 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 33040 bytes
dplayx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 230400 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 22016 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 42768 bytes
dpwsockx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 57856 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 377856 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 203264 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00 151552 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00 168960 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 394240 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 208896 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 76800 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744 bytes
gameenum.sys: 5.01.2600.0000 English Final Retail 8/17/2001 15:02:32 9728 bytes
dsound.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 363520 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 68096 bytes
dmusic.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 104448 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 181248 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1769472 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 13:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 8/23/2001 13:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 21504 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 53248 bytes
dxmasf.dll: 6.04.0009.1120 English Final Retail 8/23/2001 13:00:00 498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 10.00.0000.3646 English Final Retail 8/11/2004 01:45:04 221184 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 177152 bytes
qdv.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 276480 bytes
qdvd.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 382976 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 524800 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 1246208 bytes
strmdll.dll: 4.01.0000.3925 English Final Retail 8/23/2001 13:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/23/2001 13:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/23/2001 13:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/23/2001 13:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/23/2001 13:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/23/2001 13:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/23/2001 13:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/23/2001 13:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/23/2001 13:00:00 154624 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 194560 bytes
msdvdopt.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 74240 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 48512 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
kstvtune.ax: 5.03.0001.0904 English Final Retail 7/19/2004 16:19:30 285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0904
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0003.0086
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4477
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4477
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0904
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4477
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,2.00.0002.0002
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0904
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4477
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0904
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0904
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0904
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,2.00.0000.0020
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0904
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0006
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,2.00.0000.0020
Nero Digital Parser,0x00600000,0,3,NDParser.ax,2.00.0002.0002
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.0000.0900
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0904
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
SB Live! Wave Device,0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
A: SB Live! MIDI Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
B: SB Live! MIDI Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! MIDI UART,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
SB Live! MIDI UART,0x00200000,3,2,,5.03.0000.0900
SB Live! Wave Device,0x00200000,3,2,,5.03.0000.0900
WDM Streaming Rendering Devices:
A: SB Live! MIDI Synth,0x00200000,1,1,,5.03.0000.0900
B: SB Live! MIDI Synth,0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00200000,2,2,,5.03.0000.0900
Audio Renderers:
SB Live! Wave Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: SB Live! Wave Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming System Devices:
A: SB Live! MIDI Synth,0x00200000,11,2,,5.03.0000.0900
SB Live! Wave Device,0x00200000,13,2,,5.03.0000.0900
