Fong Kai - FK330
Fyrn som testa denne kabbisen er jo en tulling!
han foretrekker ugudelige plastikkklipps i stede
for skikkelige skruer når HK skal festes.. BLASFEMI !!! :hrm:
Quote fra silentpcreview.com
Once you understand what's going on the process is pretty simple:
1. Fill all the mounting holes on the motherboard with the plastic standoffs, except for the hole on the center right. That hole you leave empty for the one standard screw-type standoff, which you install into the corresponding hole on tray as you would in a normal case.
2. Align the motherboard with the square openings on the tray. Once aligned, you slide it to the left, and the standoffs engage in their slots with a reassuring click.
3. A single screw into the one remaining hole provides the final bit of security.
>Although I'm sure some people will be made nervous by only using one screw to install their motherboard, this is very secure, very fast, and really pretty slick. As I am always swapping motherboards about, I wish all cases would adopt a system like this.<
Endret av zandro
Det er ganske bra ja....13 kg.....det er jo mer enn de fleste, skulle vel tyde på at det støydempingsmessig er bra ihvertfall med tanke på tykkelse av platene...
