operaman Skrevet 2. oktober 2004 Del Skrevet 2. oktober 2004 har ikke fått til å installere make så jeg bestemte å installere fra gnu sine web-sider men ./configure virker ikke [code]This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by GNU make configure 3.80, which was generated by GNU Autoconf 2.54. Invocation command line was $ ./configure ## --------- ## ## Platform. ## ## --------- ## hostname = debian uname -m = i686 uname -r = 2.6.8-1-686 uname -s = Linux uname -v = #1 Sat Aug 28 14:11:39 EDT 2004 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = i686 /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /usr/local/bin PATH: /usr/local/sbin PATH: /sbin PATH: /usr/sbin PATH: /bin PATH: /usr/bin PATH: /usr/bin/X11 PATH: /usr/games ## ----------- ## ## Core tests. ## ## ----------- ## configure:1317: checking for a BSD-compatible install configure:1371: result: /usr/bin/install -c configure:1382: checking whether build environment is sane configure:1425: result: yes configure:1458: checking for gawk configure:1474: found /usr/bin/gawk configure:1484: result: gawk configure:1494: checking whether make sets ${MAKE} configure:1518: result: no configure:1669: checking whether make sets ${MAKE} configure:1693: result: no configure:1746: checking for gcc configure:1762: found /usr/bin/gcc configure:1772: result: gcc configure:2014: checking for C compiler version configure:2017: gcc --version </dev/null >&5 2.95.4 configure:2020: $? = 0 configure:2022: gcc -v </dev/null >&5 Reading specs from /usr/lib/gcc-lib/i386-linux/2.95.4/specs gcc version 2.95.4 20011002 (Debian prerelease) configure:2025: $? = 0 configure:2027: gcc -V </dev/null >&5 gcc: argument to `-V' is missing configure:2030: $? = 1 configure:2050: checking for C compiler default output configure:2053: gcc conftest.c >&5 /usr/bin/ld: cannot open crt1.o: No such file or directory collect2: ld returned 1 exit status configure:2056: $? = 1 configure: failed program was: #line 2033 "configure" #include "confdefs.h" int main () { ; return 0; } configure:2083: error: C compiler cannot create executables check `config.log' for details. ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_env_CC_set= ac_cv_env_CC_value= ac_cv_env_CFLAGS_set= ac_cv_env_CFLAGS_value= ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_CPP_set= ac_cv_env_CPP_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_build_alias_set= ac_cv_env_build_alias_value= ac_cv_env_host_alias_set= ac_cv_env_host_alias_value= ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ac_cv_path_install='/usr/bin/install -c' ac_cv_prog_AWK=gawk ac_cv_prog_ac_ct_CC=gcc ac_cv_prog_make_make_set=no ## ----------------- ## ## Output variables. ## ## ----------------- ## ACLOCAL='${SHELL} /make-3.80/config/missing --run aclocal-1.7' ALLOCA='' AMDEPBACKSLASH='' AMDEP_FALSE='' AMDEP_TRUE='' AMTAR='${SHELL} /make-3.80/config/missing --run tar' AR='' AUTOCONF='${SHELL} /make-3.80/config/missing --run autoconf' AUTOHEADER='${SHELL} /make-3.80/config/missing --run autoheader' AUTOMAKE='${SHELL} /make-3.80/config/missing --run automake-1.7' AWK='gawk' CC='gcc' CCDEPMODE='' CFLAGS='' CPP='' CPPFLAGS='' CYGPATH_W='echo' DEFS='' DEPDIR='' ECHO_C='' ECHO_N='-n' ECHO_T='' EGREP='' EXEEXT='' GETLOADAVG_LIBS='' GLOBINC='' GLOBLIB='' GMSGFMT='' INSTALL_DATA='${INSTALL} -m 644' INSTALL_PROGRAM='${INSTALL}' INSTALL_SCRIPT='${INSTALL}' INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s' INTLLIBS='' KMEM_GROUP='' LDFLAGS='' LIBICONV='' LIBINTL='' LIBOBJS='' LIBS='' LTLIBICONV='' LTLIBINTL='' LTLIBOBJS='' MAKEINFO='${SHELL} /make-3.80/config/missing --run makeinfo' MAKE_HOST='' MKINSTALLDIRS='' MSGFMT='' MSGMERGE='' NEED_SETGID='' OBJEXT='' PACKAGE='make' PACKAGE_BUGREPORT='[email protected]' PACKAGE_NAME='GNU make' PACKAGE_STRING='GNU make 3.80' PACKAGE_TARNAME='make' PACKAGE_VERSION='3.80' PATH_SEPARATOR=':' PERL='' POSUB='' RANLIB='' SET_MAKE='MAKE=make' SHELL='/bin/sh' STRIP='' USE_CUSTOMS_FALSE='' USE_CUSTOMS_TRUE='' USE_LOCAL_GLOB_FALSE='' USE_LOCAL_GLOB_TRUE='' USE_NLS='' VERSION='3.80' XGETTEXT='' ac_ct_CC='gcc' ac_ct_RANLIB='' ac_ct_STRIP='' am__fastdepCC_FALSE='' am__fastdepCC_TRUE='' am__include='' am__quote='' bindir='${exec_prefix}/bin' build='' build_alias='' build_cpu='' build_os='' build_vendor='' datadir='${prefix}/share' exec_prefix='NONE' host='' host_alias='' host_cpu='' host_os='' host_vendor='' includedir='${prefix}/include' infodir='${prefix}/info' install_sh='/make-3.80/config/install-sh' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' localstatedir='${prefix}/var' mandir='${prefix}/man' oldincludedir='/usr/include' prefix='NONE' program_transform_name='s,x,x,' sbindir='${exec_prefix}/sbin' sharedstatedir='${prefix}/com' sysconfdir='${prefix}/etc' target_alias='' ## ------------- ## ## Output files. ## ## ------------- ## MAINT_MAKEFILE='' ## ----------- ## ## confdefs.h. ## ## ----------- ## #define PACKAGE "make" #define PACKAGE_BUGREPORT "[email protected]" #define PACKAGE_NAME "GNU make" #define PACKAGE_STRING "GNU make 3.80" #define PACKAGE_TARNAME "make" #define PACKAGE_VERSION "3.80" #define VERSION "3.80" configure: exit 77 [/code] noen som vet noe Lenke til kommentar
Velmont Skrevet 2. oktober 2004 Del Skrevet 2. oktober 2004 (endret) Jøss, du har ikke make? Trodde det var standard på absolutt alt :| configure:2083: error: C compiler cannot create executables check `config.log' for details. Hmm, det er denne som er feil altså? Funker ikke gcc'en din? Prøv å lag et eget lite "hei verden" program og test.... #include <stdio.h> int main() { printf("hei verden\n"); return 0; } (har ikke testa det selv, - er trøtt - men tror det skulle være rett) Endret 2. oktober 2004 av Velmont Lenke til kommentar
kattemat Skrevet 2. oktober 2004 Del Skrevet 2. oktober 2004 apt-get install make ?? Lenke til kommentar
operaman Skrevet 3. oktober 2004 Forfatter Del Skrevet 3. oktober 2004 apt-get install make ?? det virker ikke Lenke til kommentar
ratix Skrevet 3. oktober 2004 Del Skrevet 3. oktober 2004 det virker ikke Hvordan virker det ikke? Lenke til kommentar
operaman Skrevet 3. oktober 2004 Forfatter Del Skrevet 3. oktober 2004 kjørte apt-get install make $apt-get install makeLeser pakkelister... Utført Skaper oversikt over avhengighetsforhold... Utført Følgende ekstra pakker vil bli installert. fileutils Følgende NYE pakker vil bli installerte: fileutils make 0 upgraded, 2 newly installed, 0 å fjerne og 0 ikke oppgradert. Trenger å skaffe 0B/1097kB med lagre. Efter utpakking vil 2773kB mere diskplass bli brukt. Vil du fortsette? [Y/n]y (Reading database ... 62748 files and directories currently installed.) Unpacking fileutils (from .../fileutils_4.1-10_i386.deb) ... dpkg: error processing /var/cache/apt/archives/fileutils_4.1-10_i386.deb (--unpack): trying to overwrite `/bin/chgrp', which is also in package coreutils dpkg-deb: subprocess paste killed by signal (Røret ble brutt) Errors were encountered while processing: /var/cache/apt/archives/fileutils_4.1-10_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1) Lenke til kommentar
