rvenes Skrevet 27. september 2004 Del Skrevet 27. september 2004 (endret) Kva er dette her? Tviler på at det er noke alvorlig Fikk det opp da eg logga meg på min SMC 2084 router 2004/09/27 07:22:50 : 192.168.1.2 login successfully 2004/09/27 06:27:38 : Blocked intrusion "Land Attack" from 0.1.0.5 - email alert sent to [email protected] 2004/09/27 06:27:38 : **Land Attack** <TCP> Source IP:0.1.0.5 Port:3376 Dest IP:0.1.0.5 Port:3375 2004/09/27 06:27:32 : Blocked intrusion "Land Attack" from 0.1.0.5 - email alert sent to [email protected] 2004/09/27 06:27:32 : **Land Attack** <TCP> Source IP:0.1.0.5 Port:3376 Dest IP:0.1.0.5 Port:3375 2004/09/27 06:27:29 : Blocked intrusion "Land Attack" from 0.1.0.5 - email alert sent to [email protected] 2004/09/27 06:27:29 : **Land Attack** <TCP> Source IP:0.1.0.5 Port:3376 Dest IP:0.1.0.5 Port:3375 2004/09/27 06:25:25 : Blocked intrusion "Land Attack" from 0.1.0.5 - email alert sent to [email protected] 2004/09/27 06:25:25 : **Land Attack** <TCP> Source IP:0.1.0.5 Port:3373 Dest IP:0.1.0.5 Port:3372 2004/09/27 06:25:19 : Blocked intrusion "Land Attack" from 0.1.0.5 - email alert sent to [email protected] 2004/09/27 06:25:19 : **Land Attack** <TCP> Source IP:0.1.0.5 Port:3373 Dest IP:0.1.0.5 Port:3372 2004/09/27 06:25:16 : Blocked intrusion "Land Attack" from 0.1.0.5 - email alert sent to [email protected] 2004/09/27 06:25:16 : **Land Attack** <TCP> Source IP:0.1.0.5 Port:3373 Dest IP:0.1.0.5 Port:3372 2004/09/27 06:20:30 : Blocked intrusion "Land Attack" from 0.1.0.5 - email alert sent to [email protected] 2004/09/27 06:20:30 : **Land Attack** <TCP> Source IP:0.1.0.5 Port:3347 Dest IP:0.1.0.5 Port:3346 2004/09/27 06:20:24 : Blocked intrusion "Land Attack" from 0.1.0.5 - email alert sent to [email protected] 2004/09/27 06:20:24 : **Land Attack** <TCP> Source IP:0.1.0.5 Port:3347 Dest IP:0.1.0.5 Port:3346 2004/09/27 06:20:21 : Blocked intrusion "Land Attack" from 0.1.0.5 - email alert sent to [email protected] 2004/09/27 06:20:21 : **Land Attack** <TCP> Source IP:0.1.0.5 Port:3347 Dest IP:0.1.0.5 Port:3346 Ipaddresser og slikt : Windows IP-konfigurasjon Vertsnavn . . . . . . . . . . . : Cornel Primær DNS-suffiks . . . . . . . : Nodetype . . . . . . . . . . . . : Blandet IP-ruting aktivert . . . . . . . : Nei WINS Proxy aktivert. . . . . . . : Nei Ethernet-kort Satelitt: Tilkoblingsspesifikt DNS-suffiks : Beskrivelse . . . . . . . . . . : B2C2 Broadband Receiver PCI Adapter Fysisk adresse . . . . . . . . . : 00-D0-D7-04-6B-E0 DHCP aktivert. . . . . . . . . . : Nei IP-adresse . . . . . . . . . . . : 192.168.238.238 Nettverksmaske . . . . . . . . . : 255.255.255.0 Standard gateway . . . . . . . . : Ethernet-kort LAN: Tilkoblingsspesifikt DNS-suffiks : Beskrivelse . . . . . . . . . . : Intel(R) PRO/1000 CT Network Connecti on Fysisk adresse . . . . . . . . . : 00-0C-6E-B8-CC-FD DHCP aktivert. . . . . . . . . . : Ja Automatisk konfigurasjon aktivert: Ja IP-adresse . . . . . . . . . . . : 192.168.1.2 Nettverksmaske . . . . . . . . . : 255.255.255.0 Standard gateway . . . . . . . . : 192.168.1.1 DHCP-server. . . . . . . . . . . : 192.168.1.1 DNS-servere. . . . . . . . . . . : 192.168.1.1 Leasingavtale mottatt. . . . . . : 21. september 2004 18:39:38 Leasingavtale utgår. . . . . . . : 19. januar 2038 05:14:07 Ethernet-kort Lokal tilkobling 3: Tilkoblingsspesifikt DNS-suffiks : Beskrivelse . . . . . . . . . . : Microsoft TV/Video Connection Fysisk adresse . . . . . . . . . : 00-00-00-00-00-00 DHCP aktivert. . . . . . . . . . : Ja Automatisk konfigurasjon aktivert: Ja Automatisk konfigurasjon av IP-adresse. . . : 0.1.0.5 Nettverksmaske . . . . . . . . . : 255.255.255.255 Standard gateway . . . . . . . . : C:\> Ser eg har den ip'n på Microsoft Tv/Video saken der, kva er den til? Eg får heller ikkje epost da! (ja eg har rett epostaddresse) Det og er litt merklig, får vel sjekke dei innstillingane. Noken som veit? Endret 27. september 2004 av Cornel Lenke til kommentar
BioAcid Skrevet 27. september 2004 Del Skrevet 27. september 2004 Land Attack A Land Attack is an attempt to slow down a computer or network connection. In a Land Attack, a packet is sent with identical source and destination IP addresses which match an IP address of a computer on the network. Because this is theoretically impossible, Windows goes into an infinite loop trying to resolve these illegal connections, causing the whole network performance to be degraded. Lenke til kommentar
sumptrollet Skrevet 27. september 2004 Del Skrevet 27. september 2004 Ethernet-kort Lokal tilkobling 3: Tilkoblingsspesifikt DNS-suffiks : Beskrivelse . . . . . . . . . . : Microsoft TV/Video Connection Fysisk adresse . . . . . . . . . : 00-00-00-00-00-00 DHCP aktivert. . . . . . . . . . : Ja Automatisk konfigurasjon aktivert: Ja Automatisk konfigurasjon av IP-adresse. . . : 0.1.0.5 Nettverksmaske . . . . . . . . . : 255.255.255.255 Standard gateway . . . . . . . . : C:\>[/code] Ser eg har den ip'n på Microsoft Tv/Video saken der, kva er den til? Det er TV-kortet ditt antageligvis. Hvorfor det dukker opp som et nettverkskort for du spørre MS om. Under nettverk i task manager så kan du også se TV-kort. Lenke til kommentar
rvenes Skrevet 27. september 2004 Forfatter Del Skrevet 27. september 2004 Eg har eit pci kort, dvb kort, og det er den B2C2 Broadband Receiver PCI Adapter saken. Den andre greia har ikkje eg sett før! Lenke til kommentar
