O D D Skrevet 25. september 2004 Del Skrevet 25. september 2004 (endret) har et problem,prøver å laste ned fra -fjernet-, men får bare følgene feilmelding: Unauthorized download We're sorry, but this downlod request cannot be authorized. There could be several reasons for this: 1) You clicked on a link on an *unofficial* .org mirror. We do not allow that kind of external hotlinking. This site creates a great deal of traffic and it's hard to find a good hosting. We will not provide the bandwith for other sites. Please visit .org and you can download all the torrents you want. 2) You're using a download manager. But there's a solution to this problem: Set up your download manager to send a HTTP referer, and when you click on a link on the .org site the download will be authorized. Here's how you can do this in Getright: Go to Getright Configuration, under Advanced/Protocol check Send "Referer" in HTTP Request and then select Calculated from open web browser page. The setup should be similar for other download managers. 3) Your browser did not send a referer. This normally happens if you right click on a link and select save-as, or if you copy and paste a link into a new browser window and press Enter. It may also be that your browser is set up to not send any referer. But left clicking on a link works just fine and has been tested in IE6, Netscape 6, Opera6, Firefox and Safari Some software firewalls, for instance the Norton Personal Firewall (which is also part of Norton Internet Security) or ZoneAlarm remove the referer from HTTP requests which will block any downloads on any site that does a referer check. Hence such options should always be turned off. In Norton you have to go to the Privacy Settings and disable browser privacy (which doesn't really protect your privacy anyway as your IP address will always be logged regardless of that setting), in ZoneAlarm you have to go to Privacy -> Cookie Control -> Custom and uncheck "remove private header information". Software like AdSubstract also blocks the referer and makes downloads impossible. We're sorry for any inconvenience this may cause and hope you understand our reasons for doing so. Bandwith doesn't come cheap and we have to do all we can to keep the bandwith usage down har pøvd å bruke både bittorent og Azaresus noen som har peiling Endret 25. september 2004 av Afseth Lenke til kommentar
Goophy Skrevet 25. september 2004 Del Skrevet 25. september 2004 Dessverre ulovlig å hjelpe til med ting relatert til warez her. Det er i bunn og grunn det problemet ditt dreier seg om, få fatt i warez that is... Lenke til kommentar
Dr3as Skrevet 25. september 2004 Del Skrevet 25. september 2004 Kan ikke hjelpe.. men les det som står der.. det burde da fungere? reboote etter du har gjort ting kan også hjelpe Lenke til kommentar
JuBi Skrevet 25. september 2004 Del Skrevet 25. september 2004 (endret) har et problem,prøver å laste ned fra -fjernet-, men får bare følgene feilmelding: Unauthorized download har pøvd å bruke både bittorent og Azaresus noen som har peiling løsningen er enkel! kjøp heller det du har tenkt og download'e Endret 25. september 2004 av Afseth Lenke til kommentar
jonnor Skrevet 25. september 2004 Del Skrevet 25. september 2004 (endret) Dette omhandler warez og er etter forumets rettningslinjer ikke lov her. (ihvertfall på kanten, men om tråden bør stenges eller ikke får mod stå for) *rapportert* Endret 25. september 2004 av NorthWave Lenke til kommentar
SupremeX Skrevet 25. september 2004 Del Skrevet 25. september 2004 som andre påpeker, dette var lite lurt å legge ut på forumet. Har du i det hele tatt lest retningslinjene? Har du firewall forresten? Lenke til kommentar
O D D Skrevet 25. september 2004 Forfatter Del Skrevet 25. september 2004 som andre påpeker, dette var lite lurt å legge ut på forumet. Har du i det hele tatt lest retningslinjene? Har du firewall forresten? har brannmur ja. skjønner ikke helt hvorfor det er så stregt spør egentlig bare om hva problemet er ,oppfordrer ingen til å bruke det Lenke til kommentar
-ɐMoԀ- Skrevet 25. september 2004 Del Skrevet 25. september 2004 Av med brannmur før du går inn på den addr Lenke til kommentar
Black Star Skrevet 25. september 2004 Del Skrevet 25. september 2004 Ingen oppfordring nei, men adressen legges ut. Normalt blir slike adresser sensurert, men du omgår denne sensureringen med viten og vilje, ved å bruke mellomrom mellom hver bokstav. Stenges og sensureres manuelt Lenke til kommentar
