hei, har denne koden:
import java.sql.*;	//DriverManager, Connection, SQLException
import javax.swing.*;
import java.awt.*;
import java.awt.event.*;
import org.gjt.mm.mysql.Driver;
public class sqlw extends JFrame
   private JLabel postnr;
   private JTextField postnrin;
   private JTextArea tekstomr;
   private JScrollPane roll;
   private JPanel panel;
   private String passord;
   private String bruker;
   public sqlw(String user, String passw)
       super("OBLIG 1");
       panel = new JPanel();
       postnr = new JLabel("Postnr");
       panel.add(postnr);
       postnrin = new JTextField(10);
       panel.add(postnrin);
       getContentPane().add(panel,BorderLayout.NORTH);
       tekstomr = new JTextArea(10,5);
roll = new JScrollPane(tekstomr);
getContentPane().add(roll,BorderLayout.CENTER);
setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
setSize(400,200);
show();
       bruker = user;
       passord = passw;
       postnrin.addActionListener(new ActionListener(){
           public void actionPerformed(ActionEvent e){
   int nr = Integer.parseInt(e.getActionCommand());
   kjor(nr);
   private void kjor(int postn)
    try
           Class.forName("org.gjt.mm.mysql.Driver");  //1)
           Connection forbindelse = DriverManager.getConnection("jdbc:mysql:mysql.hosted.servetheworld.net:3306:db",bruker, passord);	//2)
           Statement setning = forbindelse.createStatement();
           ResultSet radsett = setning.executeQuery("select * from kunde where postnr = " + postn);
           radsett.next();
           tekstomr.setText("");
           while (radsett.next())
               tekstomr.append(radsett.getInt("KUNDEID") + " " +
                                       radsett.getString("FORNAVN") + " " +
   	radsett.getString("ETTERNAVN") + "\t" +
   	radsett.getString("EPOST") + "\t" +
                                       radsett.getString("PASSORD") + "\t" +
                                       radsett.getString("SENDINF") + "\t" +
                                       radsett.getString("ADRESSELINJE1") + "\t" +
                                       radsett.getString("ADRESSELINJE2") + "\t" +
                                       radsett.getString("ADRESSELINJE3") + "\t" +
                                       radsett.getString("ADRESSELINJE4") + "\t" +
   	radsett.getInt("POSTNR") + "\t" +
                                       radsett.getInt("POSTSTED") + "\t" +
                                       radsett.getInt("TLF") + "\t" +
   	radsett.getString("MOB") + "\n");
 	forbindelse.close();	//3) – lukk alltid når du er ferdig med DB
 	System.out.println("Forbindelsen med DBMS er avsluttet");
catch ( ClassNotFoundException cnfex)
       {	//koblet til 1)
           System.out.println("Feilet med å laste driveren: " + cnfex.getMessage());
           System.exit(1);
catch ( SQLException sqlex)
       {	//koblet til 2) og 3)
           System.out.println("Tilkobling ikke mulig: " + sqlex.getMessage());
           System.exit(1);
public static void main(String[ ] Bitch)
    sqlw app = new sqlw(Bitch[0], Bitch[1]);
jeg får denne feilmeldingen:
"Tilkobling ikke mulig: No suitable driver"
Og jeg har både lagt til den nyeste driveren, *.jar og øverst med import, så jeg vet ikke hva som er galt her jeg.. noen som har peil?
Jeg har brukt mysql-connector-java-3.0.9-stable fra MySQL og denne fungerer fint
hvordan legger du den inn? kompilator bruker du? sdk har du?
Jeg bruker JBuilder. Men når jeg laget selve jar filen så la jeg med denne mysql-connector i jarfilen. Husker ikke helt hvordan jeg gjør det.. er en stund siden
Postgres banker jo MySQL på alle områder.
Hvorfor er da mySQL så mye mer utbredt?
Tjah.. Si det. Var vel på riktig sted til riktig tid, med feature-settet som var nødvendig for superenkle web-apps.
Postgres har vel vært litt trøblete å sette opp tidligere, og at den ikke kom til windows før nå nylig (ok, kjørte under cygwin men det holder ikke) har vel hatt en del å si.
Dessuten er jo MySQL et kommersielt produkt som markedsføres aktivt.
  • 2 uker senere...
mysql er gratis det også..
men skal du ha enterprise versjonen som tar over 1 000 000 transaksjoner, så koster det litt..
Jeg mente ikke at MySQL ikke er gratis, men at MySQL AB har interesse av at databasen har størst mulig utbredelse, da de lever av å selge support, tilleggstjenester og lisenser til visse typer bruk.
