OleBrumHonning Skrevet 19. september 2004 Del Skrevet 19. september 2004 (endret) Hei Har ett problem med enten opera eller norton. Dette er feilmeldingen jeg får. Unauthorized download We're sorry, but this downlod request cannot be authorized. There could be several reasons for this: 1) You clicked on a link on an *unofficial* mirror. We do not allow that kind of external hotlinking. This site creates a great deal of traffic and it's hard to find a good hosting. We will not provide the bandwith for other sites. Please visit and you can download all the torrents you want. 2) You're using a download manager. But there's a solution to this problem: Set up your download manager to send a HTTP referer, and when you click on a link on the .org site the download will be authorized. Here's how you can do this in Getright: Go to Getright Configuration, under Advanced/Protocol check Send "Referer" in HTTP Request and then select Calculated from open web browser page. The setup should be similar for other download managers. 3) Your browser did not send a referer. This normally happens if you right click on a link and select save-as, or if you copy and paste a link into a new browser window and press Enter. It may also be that your browser is set up to not send any referer. But left clicking on a link works just fine and has been tested in IE6, Netscape 6, Opera6, Firefox and Safari Some software firewalls, for instance the Norton Personal Firewall (which is also part of Norton Internet Security) or ZoneAlarm remove the referer from HTTP requests which will block any downloads on any site that does a referer check. Hence such options should always be turned off. In Norton you have to go to the Privacy Settings and disable browser privacy (which doesn't really protect your privacy anyway as your IP address will always be logged regardless of that setting), in ZoneAlarm you have to go to Privacy -> Cookie Control -> Custom and uncheck "remove private header information". Software like AdSubstract also blocks the referer and makes downloads impossible. We're sorry for any inconvenience this may cause and hope you understand our reasons for doing so. Bandwith doesn't come cheap and we have to do all we can to keep the bandwith usage down. Er det noen som kan guide meg for å løse dette problemet Endret 21. september 2004 av OleBrumHonning Lenke til kommentar
dostojevski Skrevet 19. september 2004 Del Skrevet 19. september 2004 Er ikke helt sikker på om dette er løsningen, men har du på "refferer logging"? I 7.54 ligger det under Tools->Quick preferences->Enable refferer logging, Tools-menyen er vel ny for denne versjonen, men undermenyen er gammel, lå vel i File-menyen tidligere tror jeg. Samme emny hvor du stiller inn popup-blocker, Java Script av/på etc. Evt. kan du sikkert velge dette i preferences også. Lenke til kommentar
OleBrumHonning Skrevet 19. september 2004 Forfatter Del Skrevet 19. september 2004 Hei Jeg fikk det ikke til med dette tipset, noen andre? Lenke til kommentar
