hvordan kan jeg få ut cd rom?
Mekk en kode sånn som den under.. så skal det funke. Denne har jeg bare funnet.. vet ikke om den fungerer..
Private Declare Function mciSendString Lib "winmm.dll" Alias "mciSendStringA" (ByVal _
lpstrCommand As String, ByVal lpstrReturnString As String, ByVal uReturnLength As Long, ByVal _
hWndCallback As Long) As Long
Private Sub Command1_Click()
Dim Dummy As String
Dummy = vbmciSendString("set cdaudio door open", 0)
End Sub
Private Sub Command2_Click()
Dim Dummy As String
Dummy = vbmciSendString("set cdaudio door closed ", 0)
End Sub
Function vbmciSendString(ByVal Command As String, ByVal hWnd As Long) As String
Dim Buffer As String
Dim dwRet As Long
Buffer = Space$(100) ' Create a buffer
dwRet = mciSendString(Command, ByVal Buffer, Len(Buffer), hWnd)
vbmciSendString = Buffer
End Function
