musicmixer04 Skrevet 17. september 2004 Del Skrevet 17. september 2004 TIL DERE SOM LURER PÅ OM HVILKE BRENNEPLATER, ELLER HVORDAN MAN FÅR BEST RESULTAT NÅR MAN BRENNER ET MEDIUM SE HER. I DIGITALVERDEN ER DET SÅNN AT DET IKKE FINNE NOE DEGRADERING AV EKS MUSIKK, FILM ETC. HER GJELDER EN REGEL. ENTEN FUNKER DET ELLER FUNKER DET IKKE. DVS HVIS DU HAR BRENT EN FILM, MUSIKK ETC OG DEN FUNKER ETTERPÅ HAR DU BRENT DEN EKSAKTE KOPI AV ORIGINALEN DU BRANT FRA. KLARER IKKE SPILLEREN DIN Å LESE DISKEN HAR BRENNINGEN MISLYKTES, ALTSÅ ENTEN FUNKER DET ELLER IKKE.. DET SOM AVGJØR KVALITETEN PÅ DET DU HAR PÅ DIN CDR DVDR ETC ER HVILKEN SPILLER DU BRUKER. ALLE SPILLERE(CD DVD )HAR EN D/A CONVERTER, ALTSÅ NOE SOM KONVERTERER FRA DIGITALT TIL ANALOGT SIGNAL. DETTE ER EN "DINGS" SOM ER VANSKELIG Å LAGE, OG KOSTER MYE PENGER Å LAGE, ALTSÅ ET SVÆRT KRITISK PUNKT NÅR DET KOMMER TIL KVALITET--DVS. SAMMENLIGNER VI EN BILLIG OG EN DYR SPILLER VIL SANSYNELIGHETEN FOR AT DEN DYRE SPILLEREN HAR EN BEDRE A/D CONVERTER ERGO BEDRE KVALITET... (CHASSIS OG ANNET JÅLERRI UTSEENDEMESSIG KOSTER SLIKK OG INGENTING Å PRODUSERE) MED TANKE PÅ HVILKE BRENNEPLATER MAN KJØPER ER DET INGEN FORSKJELL NÅR DET KOMMER TIL KVALITET PÅ DET DU SKAL BRENNE, PLATENE VIL ENTEN FUNKE(MED NØYAKTIG SAMME KVALITET SOM NEVNT OVER) ELLER FUNKER DE IKKE. HUSK .DET ER BARE TALL SOM BLIR LAGRET PÅ EN CD PLATE(0ELLER1) DET MAN BETALER FOR ER HVOR SOLID BELEGG MAN VIL HA SOM LIGGER OPPÅ PLATEN SLIK AT PLATEN TÅLER MER, SOM MANGE VET, FÅR MAN EN RIPE OPPÅ PLATEN VIL CD BLI ØDELAGT, IKKE UNDER SOM DE FLESTE TROR(LES EN AV GUIDENE PÅ HARDWARE.NO OM DETTE) KONKLUSJON ER AT MAN IKKE FÅR NOEN BEDRE KVALITET OM MAN KJØPER DYRERE BRENNEPLATER... DETTE ER BULLSHIT, OG MANGE SELGERE ER DESVERRE IKKE OBS PÅ DET SELV.DE BURDE KANSKJE LESE MER PÅ FORUMET TIL HARDWARE.NO ELLER JOBBET MED NOE ANNET PS: FORSKJELLEN PÅ DVD-R OG DVD+R ER BASERT PÅ HVILKE SPILLER DU SKAL SPILLE DEN I, IKKE NOE OM KVALITET. HÅPER DET KLARNET OPP I TING: MUSICMIXER04 Lenke til kommentar
Blib Skrevet 17. september 2004 Del Skrevet 17. september 2004 Posten stenges grunnet overdreven caps-bruk. Lenke til kommentar
