Earl87 Skrevet 17. september 2004 Del Skrevet 17. september 2004 har dette hket... The MicroStar MS-6577 is a microATX Socket 478 motherboard for the Intel Pentium 4 processors with 400 and 533 MHz front side bus. The MS-6577 may look compact, but it is loaded with features such as three Bus Mastering PCI slots and UltraDMA 100/66 IDE capabilities. The Intel 845G chipset provides onboard Intel 3D graphics and Realtek AC'97 Sound. CPU: Supports Socket 478 for Intel P4 Willamette and Northwood processors. Supports 1.4 GHz to 2.8 GHz. Chipset: Intel 845G chipset FSB 400/533 MHz Supports DDR PC2100/PC1600 4x AGP Interface Integrated Intel 3D Video Intel ICH4 chipset Realtek AC '97 Codec supported High-Speed USB 2.0 Controller Main Memory: Two 184-pin DIMM sockets supporting PC2100/1600 DDR SDRAM Supports up to 1 GB of system memory Expansion Slots: One AGP 4X slot Three 32-bit Bus Master PCI slots Onboard IDE: IDE controller supports IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 100/66 operation modes Can connect up to four IDE devices Onboard Peripherals: 2x PS/2 Ports 6x USB 2.0 Ports ( Rear x4 / Front x2 ) 1x Parallel Port 1x VGA Port 1x Serial Port 1x RJ-45 LAN Port Vertical Audio Ports ( Line_in, Line_out, Mic_in ) Audio: AC’97 link controller integrated in ICH4. Realtek ALC 202A Codec Video Onboard Intel Extreme Graphics 3D Up to 48 MB shared memory Ethernet LAN Onboard Realtek RTL8101L 10/100 Mbps Ethernet Form Factor: microATX, 9.3" x 8.7" det jeg lurer på er om denne cpuen http://www.psdata.no/prodsearch.asp?it=105...lAction=detailspasser på dette hket?? Lenke til kommentar
fredriku Skrevet 17. september 2004 Del Skrevet 17. september 2004 Nei, den passer ikke, grunnet at det er prescott-kjerne. Da må du kjøpe nytt hovedkort som støtter den, eventuelt 533/800 fsb proessorer, og et Intel 865P/PE/875P brikkesett Lenke til kommentar
Earl87 Skrevet 17. september 2004 Forfatter Del Skrevet 17. september 2004 oki takker. får tenke på om jeg skal kjøpe nytt hovedkort da. Lenke til kommentar
