Skrive ut et dokument
CommonDialog.ShowPrinter 'Shows Printer Setup
ShowPrinter: The following are some flags for using the Printer dialog boxes. &H4 - Makes it so they cant choose to print only selected text. &H8 - Does not allow you to choose to print certain pages like 4-7. &H800 - This shows the help button. &H40 - This shows the print setup dialog box rather than the printer dialog box. &H100000 - This gets rid of the print to file option box. Printing Landscape - Printer.Orientation = 2 Printing Portrait - Printer.Orientation = 1
fant dette på www.planet-source-code.com/vb/scripts/ShowCode.asp?txtCodeId=32070&lngWId=1
