Earl87 Skrevet 15. september 2004 Del Skrevet 15. september 2004 sjekket med belarc advisor og fikk opp at jeg har dette hket . Board: MICRO-STAR INTERNATIONAL CO., LTD MS-6577 030 Serial Number: 3A10505410 Bus Clock: 100 megahertz BIOS: Phoenix Technologies, LTD 3.26 10/16/2003 har også denne cpuen: 2,80 gigahertz Intel Celeron 8 kilobyte primary memory cache 128 kilobyte secondary memory cache har 512 MB DDR pc 2700 cl2.5 samsung ram det jeg da lurte på er om det er mulig å sette inn en p4 cpu på dette kortet . eller om det bare er beregnet på celeron. de er jo sockel 478 både p4 og celeron men det har vell med andre ting enn bare om man får trykt cpuen nedi slotn. har ikke noe peiling på dette .så hvis dette høres helt på trynet ut så vet dere hvorfor. Lenke til kommentar
Spragleknas Skrevet 15. september 2004 Del Skrevet 15. september 2004 The MicroStar MS-6577 is a microATX Socket 478 motherboard for the Intel Pentium 4 processors with 400 and 533 MHz front side bus. The MS-6577 may look compact, but it is loaded with features such as three Bus Mastering PCI slots and UltraDMA 100/66 IDE capabilities. The Intel 845G chipset provides onboard Intel 3D graphics and Realtek AC'97 Sound. CPU: Supports Socket 478 for Intel P4 Willamette and Northwood processors. Supports 1.4 GHz to 2.8 GHz. Chipset: Intel 845G chipset FSB 400/533 MHz Supports DDR PC2100/PC1600 4x AGP Interface Integrated Intel 3D Video Intel ICH4 chipset Realtek AC '97 Codec supported High-Speed USB 2.0 Controller Main Memory: Two 184-pin DIMM sockets supporting PC2100/1600 DDR SDRAM Supports up to 1 GB of system memory Expansion Slots: One AGP 4X slot Three 32-bit Bus Master PCI slots Onboard IDE: IDE controller supports IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 100/66 operation modes Can connect up to four IDE devices Onboard Peripherals: 2x PS/2 Ports 6x USB 2.0 Ports ( Rear x4 / Front x2 ) 1x Parallel Port 1x VGA Port 1x Serial Port 1x RJ-45 LAN Port Vertical Audio Ports ( Line_in, Line_out, Mic_in ) Audio: AC’97 link controller integrated in ICH4. Realtek ALC 202A Codec Video Onboard Intel Extreme Graphics 3D Up to 48 MB shared memory Ethernet LAN Onboard Realtek RTL8101L 10/100 Mbps Ethernet Form Factor: microATX, 9.3" x 8.7" Lenke til kommentar
Earl87 Skrevet 16. september 2004 Forfatter Del Skrevet 16. september 2004 (endret) takk for hjelpen. emn lurer på en ting når jeg ser på det du fant ut om pcen min. det står i teksten der .Supports Socket 478 for Intel P4 Willamette and Northwood processors. Supports 1.4 GHz to 2.8 GHz. betyr det at jeg ikke kan bruke denne ? Intel CPU Pentium 4 S-478 2.8GHz 533MHz 1M Boxed "Prescott" og siden det står at hket tar opptill 2,8ghz vill det da si at man ikke kan bruke kraftigere cpu? eller er det bare det hket er testet opptil? som sagt jeg har null peiling er det ingen som har peiling på om det har noe å si om man bruker en "prescott" p4 cpu på dette kortet. Endret 16. september 2004 av killer puma Lenke til kommentar
