Is something wrong with my Canon G3 ?
Hi everyone,
I just bought a second-hand Canon G3.
I am very pleased with it so far, but I noticed one thing that I am a bit concerned about:
When I hold the camera aprox. 15 cm from my eyes and look into the little "seacher-hole" in top of the camera I can see a very thin black horisontal line - is that line supposed to be there, or is something broken inside the camera?
It should be noted, that if I put my eye right up to the hole (as you are supposed to do in order to use it), the line is no longer visible at all.
I hope I haven't bought a broken camera :cry:
