Fredrik90 Skrevet 9. september 2004 Del Skrevet 9. september 2004 (endret) har et proplem får ikke sendt en melding fra serveren til client. så det er bare serveren som ser hva som skjer. her er koden int startupClient(unsigned short port, const char* serverName); // ----------------------------------------------------------------------------------- // shutdownClient() - will close the socket specified and clean up winsock. void shutdownClient(int clientSocket); // winsock for our network communication #include <winsock2.h> // stdio for I/O #include <stdio.h> HANDLE threadHandle; HANDLE mutexHandle; int main() { printf("-Welcome to Networking com !\n"); printf("-created by fredrik\n-special thanks to www.gametutorials.com \n\n- this is theClientSide\n\n"); // my socket int mySocket; // create our client mySocket = startupClient(7654, "localhost"); if (mySocket == -1) { // hmm an error occurred // shutdown our client and bail printf("an error has ocurred in mysocket, closing porgram now"); shutdownClient(mySocket); return 0; } mutexHandle = CreateMutex(NULL, false, NULL); // number of bytes sent int nBytes; int Bytes; // I will define a message size so we will know how much data we will send and receive #define MAX_MESSAGE_SIZE 4096 char buffer[MAX_MESSAGE_SIZE]; char Message[MAX_MESSAGE_SIZE]; printf("Input text to send and press Enter\nType 'quit' to exit\n"); // the main loop for (;;) { // get some input from the command line gets(buffer); // check if quit was typed, then exit if (strcmp(buffer, "quit") == 0) { break; } // get our message size unsigned long messageSize = strlen(buffer); // fix our byte ordering messageSize = htonl(messageSize); // send the message size if ((nBytes = send(mySocket, (char*)&messageSize, sizeof(messageSize), 0)) == SOCKET_ERROR) { printf("Send Failed!\n"); } // re-fix our byte ordering messageSize = ntohl(messageSize); // send the actual message if ((nBytes = send(mySocket, buffer, messageSize, 0)) == SOCKET_ERROR) { printf("Send Failed!\n"); } //recive the message Bytes = recv(mySocket, Message, sizeof(Message), 0); if ((nBytes = recv(mySocket, buffer, messageSize, 0)) == SOCKET_ERROR) { printf("recive failed.\n"); } } // shutdown our client shutdownClient(mySocket); } int startupClient(unsigned short port, const char* serverName) { // an error code we will use to get more information about our errors int error; // the winsock data structure WSAData wsaData; // startup winsock if ((error = WSAStartup(MAKEWORD(2, 2), &wsaData)) == SOCKET_ERROR) { printf("Could Not Start Up Winsock!\n"); return -1; } // create my socket int mySocket = socket(AF_INET, SOCK_STREAM, 0); // make sure nothing bad happened if (mySocket == SOCKET_ERROR) { printf("Error Opening Socket!\n"); return -1; } struct hostent *host_entry; // setup the host entry if ((host_entry = gethostbyname(serverName)) == NULL) { printf("Could not find host!\n"); } struct sockaddr_in server; // fill in the server socket info server.sin_family = AF_INET; server.sin_port = htons(port); server.sin_addr.s_addr = *(unsigned long*) host_entry->h_addr; // connect to the server if (connect(mySocket, (sockaddr*)&server, sizeof(server)) == SOCKET_ERROR) { printf("Error connecting to server!\n"); } printf("Client Started\n"); return mySocket; } void shutdownClient(int clientSocket) { // close our socket closesocket(clientSocket); // shut down winsock WSACleanup(); printf("Client Shutdown\n"); } dette var client. nå kommer server. #include <winsock2.h> // stdio for I/O #include <stdio.h> int startupServerForListening(unsigned short port); void shutdownServer(int socket); HANDLE threadHandle; HANDLE mutexHandle; FD_SET masterSet; bool gQuitFlag = false; void acceptingThreadProcedure(int* serverSocket) { // copy my socket over to a local variable int mySocket = *serverSocket; // run forever for (;;) { // accept a client like normal unsigned int clientSocket = accept(mySocket, 0, 0); // make sure things are ok if (clientSocket == SOCKET_ERROR) { // just stop of we received any errors printf("Accept Failed!\n"); // signal to quit the application gQuitFlag = true; // and quit this thread return; } else { // lock the mutex WaitForSingleObject(mutexHandle, INFINITE); FD_SET(clientSocket, &masterSet); ReleaseMutex(mutexHandle); // a quick message printf("client on %d connected\n", clientSocket); } } } int main() { printf("Welcome to Networking com !\ncreated by Fredrik \nspecial thanks to"); printf(" www.gametutorials.com \n\n\nthis is the serverSide\n\n"); // Startup our network as usual. // the socket my server will use for listening int serverSocket; int nBytes; int Bytes; // startup my network utilities with my handy functions serverSocket =startupServerForListening(7654); // check for errors if (serverSocket == -1) { printf("Network Startup Failed!\nProgram Terminating\n"); return 0; } // create the mutex mutexHandle = CreateMutex(NULL, false, NULL); if (mutexHandle == NULL) { printf("Error creating mutex\n"); shutdownServer(serverSocket); return 0; } // create the thread int threadId; threadHandle = CreateThread(NULL, 0, (LPTHREAD_START_ROUTINE)acceptingThreadProcedure, &serverSocket, 0, (LPDWORD)&threadId); if (threadHandle == NULL) { printf("Could not start acceptance thread\n"); shutdownServer(serverSocket); return 0; } // sleep the main() so the acceptance thread has time to start ... this is cheesy Sleep(100); // Now that that is all over with, it's down to business. // It's always a good idea to initialize our structures before we access them, so let's zero our masterSet. FD_ZERO(&masterSet); // the main loop ... run forever for (;;) { if (gQuitFlag) { break; } // lock the mutex WaitForSingleObject(mutexHandle, INFINITE); Remember, FD_SET pollingSet = masterSet; // unlock the mutex ReleaseMutex(mutexHandle); // check if our set is empty if (pollingSet.fd_count == 0) { continue; } // the wait time timeval waitTime; waitTime.tv_sec = 0; waitTime.tv_usec = 0; int result = select(pollingSet.fd_count, &pollingSet, NULL, NULL, &waitTime); if (result == 0) { // no sockets have data continue; } // check for errors if (result == SOCKET_ERROR) { printf("Error in select()\n"); continue; } // Now that we have the polling set that contains just the sockets that have data, let's step through // the list of sockets and read from them all. // for every socket in my polling set for (unsigned int i = 0; i < pollingSet.fd_count; i++) { // We can access the socket list directly using the fd_array member of the FD_SET unsigned int clientSocket = pollingSet.fd_array[i]; // a buffer to hold my data #define MAX_MESSAGE_SIZE 4096 char buffer[MAX_MESSAGE_SIZE]; // the size of the message that is being sent unsigned long messageSize; // receive the message size first nBytes = recv(clientSocket, (char*)&messageSize, sizeof(messageSize), 0); // check for errors if (nBytes == SOCKET_ERROR) { // Uh Oh! We have our first real use of error handling! Something can happen here that is // pretty significant. Let's grab the error number from winsock. int error = WSAGetLastError(); // handle the dropped connection if (error == WSAECONNRESET) { // When we receive this error. Just get a lock on the master set, and remove this socket from // set using the FD_CLR() macro. // lock our mutex WaitForSingleObject(mutexHandle, INFINITE); // remove the socket from our master set FD_CLR(clientSocket, &masterSet); // unlock our mutex ReleaseMutex(mutexHandle); // close the socket on our side, so our computer cleans up properly closesocket(clientSocket); // a quick message printf("client on %d disconnected\n", clientSocket); // move on to the next client continue; } else { // we failed, but it wasn't an error we were expecting ... so kill the server printf("Recv Failed!\n"); gQuitFlag = true; break; } } if (nBytes == 0) { // lock our mutex WaitForSingleObject(mutexHandle, INFINITE); // remove the socket from our master set FD_CLR(clientSocket, &masterSet); // unlock our mutex ReleaseMutex(mutexHandle); // close the socket on our side, so our computer cleans up properly closesocket(clientSocket); // a quick message printf("client on %d disconnected\n", clientSocket); // move on to the next client continue; } messageSize = ntohl(messageSize); // receive the reset of the message nBytes = recv(clientSocket, buffer, messageSize, 0); Bytes = send(clientSocket, (char*)&messageSize, sizeof(messageSize), 0); // check for error if (nBytes == SOCKET_ERROR) { printf("Recv Failed!\n"); gQuitFlag = true; break; } // remember this is a string, so terminate the buffer so we can print it buffer[messageSize] = '\0'; // print the message printf("Message Received from client on %d : %s\n", clientSocket, buffer); } } // cleanup shutdownServer(serverSocket); printf("Press Enter to Exit ...\n"); getchar(); } // ----------------------------------------------------------------------------------- // startupServerForListening() - a function to startup winsock, and open a socket for listening int startupServerForListening(unsigned short port) { // an error code we will use to get more information about our errors int error; // the winsock data structure WSAData wsaData; // startup winsock if ((error = WSAStartup(MAKEWORD(2, 2), &wsaData)) == SOCKET_ERROR) { printf("Could Not Start Up Winsock!\n"); return -1; } // create my socket int mySocket = socket(AF_INET, SOCK_STREAM, 0); // make sure nothing bad happened if (mySocket == SOCKET_ERROR) { printf("Error Opening Socket!\n"); return -1; } // the address structure struct sockaddr_in server; // fill the address structure with appropriate data server.sin_family = AF_INET; server.sin_port = htons(port); server.sin_addr.s_addr = INADDR_ANY; // and now bind my socket if (bind(mySocket, (sockaddr*)&server, sizeof(server)) == SOCKET_ERROR) { printf("Bind Failed!\n"); closesocket(mySocket); return -1; } // mark my socket for listening if (listen(mySocket, 5) == SOCKET_ERROR) { printf("Listen Failed!\n"); closesocket(mySocket); return -1; } printf("Server Started\n"); return mySocket; } // ----------------------------------------------------------------------------------- // shutdownServer() - a function to shutdown a socket and clean up winsock void shutdownServer(int socket) { // kill my thread and my handle WaitForSingleObject(threadHandle, INFINITE); CloseHandle(threadHandle); CloseHandle(mutexHandle); // close our socket closesocket(socket); // shut down winsock WSACleanup(); printf("Server Shutdown\n"); } edit:vet at det er litt klip fra andre sin kode. eller lettere sakt fra den tutorialen jeg brukte. edit 2: fant feilen det var så enkelt som at jeg ikke skreiv ut stringen. Endret 11. september 2004 av Fredrik90 Lenke til kommentar
