vise IP-Adresse ved et trykk
Jeg har lyst til å ha 1 text boks og 1 komandoknapp.
I text boksen vil jeg at Ip-adressen på maskinen skal vises.
Dette skal skje når jeg trykker på Knappen.
Jeg tenkte på shell Ipconfig men åssen skal jeg få bare ip adressen i den boksen og ikke alt annet.
Takker for alle svar
MVH
Kengdal
Fant denne på nettet
Option Compare Database
Option Explicit
' Copyright ©1996-2004 VBnet, Randy Birch, All Rights Reserved.
' Some pages may also contain other copyrights by the author.
' Distribution: You can freely use this code in your own
'               applications, but you may not reproduce
'               or publish this code on any web site,
'               online service, or distribute as source
'               on any media without express permission.
Public Const MAX_WSADescription As Long = 256
Public Const MAX_WSASYSStatus As Long = 128
Public Const ERROR_SUCCESS       As Long = 0
Public Const WS_VERSION_REQD     As Long = &H101
Public Const WS_VERSION_MAJOR    As Long = WS_VERSION_REQD \ &H100 And &HFF&
Public Const WS_VERSION_MINOR    As Long = WS_VERSION_REQD And &HFF&
Public Const MIN_SOCKETS_REQD    As Long = 1
Public Const SOCKET_ERROR        As Long = -1
Public Type HOSTENT
  hName      As Long
  hAliases   As Long
  hAddrType  As Integer
  hLen       As Integer
  hAddrList  As Long
End Type
Public Type WSADATA
  wVersion      As Integer
  wHighVersion  As Integer
  szDescription(0 To MAX_WSADescription)   As Byte
  szSystemStatus(0 To MAX_WSASYSStatus)    As Byte
  wMaxSockets   As Integer
  wMaxUDPDG     As Integer
  dwVendorInfo  As Long
End Type
Public Declare Function WSAGetLastError Lib "wsock32" () As Long
Public Declare Function WSAStartup Lib "wsock32" _
 (ByVal wVersionRequired As Long, _
  lpWSADATA As WSADATA) As Long
Public Declare Function WSACleanup Lib "wsock32" () As Long
Public Declare Function gethostname Lib "wsock32" _
 (ByVal szHost As String, _
  ByVal dwHostLen As Long) As Long
Public Declare Function gethostbyname Lib "wsock32" _
 (ByVal szHost As String) As Long
Public Declare Sub CopyMemory Lib "kernel32" _
  Alias "RtlMoveMemory" _
 (hpvDest As Any, _
  ByVal hpvSource As Long, _
  ByVal cbCopy As Long)
Public Function GetIPAddress() As String
  Dim sHostName    As String * 256
  Dim lpHost    As Long
  Dim HOST      As HOSTENT
  Dim dwIPAddr  As Long
  Dim tmpIPAddr() As Byte
  Dim i         As Integer
  Dim sIPAddr  As String
  If Not SocketsInitialize() Then
     GetIPAddress = ""
     Exit Function
  End If
 'gethostname returns the name of the local host into
 'the buffer specified by the name parameter. The host
 'name is returned as a null-terminated string. The
 'form of the host name is dependent on the Windows
 'Sockets provider - it can be a simple host name, or
 'it can be a fully qualified domain name. However, it
 'is guaranteed that the name returned will be successfully
 'parsed by gethostbyname and WSAAsyncGetHostByName.
 'In actual application, if no local host name has been
 'configured, gethostname must succeed and return a token
 'host name that gethostbyname or WSAAsyncGetHostByName
 'can resolve.
  If gethostname(sHostName, 256) = SOCKET_ERROR Then
     GetIPAddress = ""
     MsgBox "Windows Sockets error " & str$(WSAGetLastError()) & _
             " has occurred. Unable to successfully get Host Name."
     SocketsCleanup
     Exit Function
  End If
 'gethostbyname returns a pointer to a HOSTENT structure
 '- a structure allocated by Windows Sockets. The HOSTENT
 'structure contains the results of a successful search
 'for the host specified in the name parameter.
 'The application must never attempt to modify this
 'structure or to free any of its components. Furthermore,
 'only one copy of this structure is allocated per thread,
 'so the application should copy any information it needs
 'before issuing any other Windows Sockets function calls.
 'gethostbyname function cannot resolve IP address strings
 'passed to it. Such a request is treated exactly as if an
 'unknown host name were passed. Use inet_addr to convert
 'an IP address string the string to an actual IP address,
 'then use another function, gethostbyaddr, to obtain the
 'contents of the HOSTENT structure.
  sHostName = TRIM$(sHostName)
  lpHost = gethostbyname(sHostName)
  If lpHost = 0 Then
     GetIPAddress = ""
     MsgBox "Windows Sockets are not responding. " & _
             "Unable to successfully get Host Name."
     SocketsCleanup
     Exit Function
  End If
 'to extract the returned IP address, we have to copy
 'the HOST structure and its members
  CopyMemory HOST, lpHost, Len(HOST)
  CopyMemory dwIPAddr, HOST.hAddrList, 4
 'create an array to hold the result
  ReDim tmpIPAddr(1 To HOST.hLen)
  CopyMemory tmpIPAddr(1), dwIPAddr, HOST.hLen
 'and with the array, build the actual address,
 'appending a period between members
  For i = 1 To HOST.hLen
     sIPAddr = sIPAddr & tmpIPAddr(i) & "."
  Next
 'the routine adds a period to the end of the
 'string, so remove it here
  GetIPAddress = Mid$(sIPAddr, 1, Len(sIPAddr) - 1)
  SocketsCleanup
End Function
Public Function GetIPHostName() As String
       GetIPHostName = ""
       Exit Function
   End If
       GetIPHostName = ""
       SocketsCleanup
       Exit Function
   End If
   GetIPHostName = Left$(sHostName, InStr(sHostName, Chr(0)) - 1)
   SocketsCleanup
End Function
Public Function HiByte(ByVal wParam As Integer) As Byte
 'note: VB4-32 users should declare this function As Integer
  HiByte = (wParam And &HFF00&) \ (&H100)
End Function
Public Function LoByte(ByVal wParam As Integer) As Byte
  LoByte = wParam And &HFF&
End Function
Public Sub SocketsCleanup()
   If WSACleanup() <> ERROR_SUCCESS Then
       MsgBox "Socket error occurred in Cleanup."
   End If
End Sub
Public Function SocketsInitialize() As Boolean
  Dim WSAD As WSADATA
  Dim sLoByte As String
  Dim sHiByte As String
  If WSAStartup(WS_VERSION_REQD, WSAD) <> ERROR_SUCCESS Then
     MsgBox "The 32-bit Windows Socket is not responding."
     SocketsInitialize = False
     Exit Function
  End If
  If WSAD.wMaxSockets < MIN_SOCKETS_REQD Then
       MsgBox "This application requires a minimum of " & _
               CStr(MIN_SOCKETS_REQD) & " supported sockets."
       Exit Function
   End If
  If LoByte(WSAD.wVersion) < WS_VERSION_MAJOR Or _
    (LoByte(WSAD.wVersion) = WS_VERSION_MAJOR And _
     HiByte(WSAD.wVersion) < WS_VERSION_MINOR) Then
     sHiByte = CStr(HiByte(WSAD.wVersion))
     sLoByte = CStr(LoByte(WSAD.wVersion))
     MsgBox "Sockets version " & sLoByte & "." & sHiByte & _
            " is not supported by 32-bit Windows Sockets."
     Exit Function
  End If
 'must be OK, so lets do it
  SocketsInitialize = True
End Function
Lim denne koden inn i en ny module, og bruke funskjonen GetIPAddress.
du kan legge til winsock, for så å skrive text1.text = winsock1.localip
LocalIp, som navnet sier, viser den lokale ip'en din. Det man kunne ha gjort var å lastet ned en IP side. Her er et eksempel:
Private Declare Function GetTickCount Lib "kernel32" () As Long
Private Declare Function URLDownloadToFile Lib "urlmon" Alias "URLDownloadToFileA" (ByVal pCaller As Long, ByVal szURL As String, ByVal szFileName As String, ByVal dwReserved As Long, ByVal lpfnCB As Long) As Long
Private Sub Command1_Click()
URLDownloadToFile 0, "http://checkip.dyndns.org/", "c:\myip.txt", 0, 0
Wait 100
Dim Tekst As String, MyIp As String
Open "c:\myip.txt" For Input As #1
Line Input #1, Tekst
Close #1
MyIp = Left(Right(Tekst, Len(Tekst) - 76), Len(Right(Tekst, Len(Tekst) - 76)) - 14)
Text1.Text = MyIp
End Sub
Private Sub form_unload(unload As Integer)
On Error Resume Next
Kill "c:\myip.txt"
End Sub
Private Sub Form_Load()
Kill "c:\myip.txt"
End Sub
Public Sub Wait(milliSekunder As Long)
Dim tidFerdig As Long
tidFerdig = GetTickCount + milliSekunder
Do
   DoEvents
Loop Until GetTickCount >= tidFerdig
End Sub
