Hva er ndisuio.sys
Arve28
Klipp og lim...... ;)
NDISUIO is a connection-less, NDIS 5.1 compliant protocol driver. It allows user-mode applications to establish and tear-down bindings to network adapters (Ethernet, WLAN etc.) Further, it also supports setting packet filters, sending and receiving data, and handling plug-and-play events. Therefore, as an NDIS_aware component, NDISUIO can directly open an NDIS miniport driver (i.e. network card driver) to send requests, set, and query information. NDISUIO provides an interface between a user-mode application and NDIS using DeviceIoControl (similar to the Unix ioctl).
I know that ndisuio.sys is often used in File and Printer Sharing, as well as Remote desktop. Maybe try going to your command promt and typing:
net stop ndisuio
If you have a wireless gatway you cannot do this. I'm not fully certain, but check to see if you have File and Printer sharing enabled. I'm not sure if you're networking any files though.
