ZirZ Skrevet 31. august 2004 Del Skrevet 31. august 2004 Hei jeg er ny med linux.. hadde tenkt å instalere amsn.. HVORDAN? filen er en rpm? Mvh Anders Lenke til kommentar
pgdx Skrevet 31. august 2004 Del Skrevet 31. august 2004 (endret) Du må ihvertfall ha en distro som støtter RPM, som Red Hat eller Fedora. Deretter er det bare til å dobbelklikke på filen, skrive root-passord og alt skal gå sin gang. I tillegg ligger det info om installen på http://amsn.sourceforge.net INSTALLING AND RUNNING===================== Q: What do I need to run amsn? A: Amsn is written in tcl/tk, so you just need a working tcl/tk interpreter (version 8.3 or later). You can get it at http://tcl.sourceforge.net. The interpreter is available for linux, windows and macintosh.Some additional features might require extra programs or libraries, like the docking icon, the Display Pictures or the SSL connection for MSN Protocol 9. Q: How do I install and run amsn on unix/linux? A: Just download the amsn-x_xx.tar.gz file. Untar it with the command: gzip -d amsn-x_xx.tar.gz tar xvf amsn-x_xx.tar It will create an msn/ directory, and amsn is installed and ready to run. To launch it, do: cd msn ./amsn or if this doesn't work, try wish amsn If wish command doesn't exist, then you don't have tcl/tk correctly installed. If "wish amsn" works, but "./amsn" doesn't, edit 'amsn' file and set the correct path to 'wish' in the first line. By default it's set to: /usr/bin/wish Endret 31. august 2004 av drange_net Lenke til kommentar
